renamed because different. inside there is no slot for miniPCIeI see some pictures of NetBox (renamed BaseBox) 5Ghz with support AC, and my supplier said that deliveries will begin next week (also be on sale mAP)
You can use AC with 20Mhz or 20+20MhzNothing with "ac" because if I use "80"MHz channel do not only disturb my own other devices, but all other devices from other operators, and on CEPT is forbidden (for now) the use of ore than 20+20.
I know, but I not want be a beta-tester for that products (any vendors), I want Hardware and Software where I can count...You can use AC with 20Mhz or 20+20MhzNothing with "ac" because if I use "80"MHz channel do not only disturb my own other devices, but all other devices from other operators, and on CEPT is forbidden (for now) the use of ore than 20+20.
best position ..hard tripReally hard reach the pole.
yes please!I post some photo, let me post...
Not SXT-SA r2 are auto-shielded.best position ..hard tripReally hard reach the pole.
..(again sorry) do you plan to shield sectors/(whatever) ? if yes how?
I must see the invoice, I do not remember the name of productor.Beautiful light tower, it allows you to climb on top or should be brought down for antennas/radios maintenance? Is it a product from Italy?
cetalfio
As already writed on previous post:Rextended
Do you using for mounting SXT 2x plastiс clamp ? Not original metal ring ? Why ?
Weather changes are not affected ?
I'm not using in my installation original mounting kit ... For vertical adjustment he not quite fit ...
I'm a WISP, this is another point of service, another point is where I put "PtMP 15Km" on photo and on photo are also present (not clearly visible) another point like this, 1 "Towers", and other two poles of different type. Another point is on Giglio Island. On Giglio Island are another company that buy our bandwidth for work.Being a complete novice in this area:
- Are you doing this personally or for a company ?
- Is it just to share an inet connection over the air ?
Thank you, nice setup.
Grazie!Bello Lavoro !! Complimenti !!
Which one do you use? Can you give a link please?I put also some bracket for tilt the SXT-SA, I forget that at the lab...
I use nano-braket from rf elements.Which one do you use? Can you give a link please?I put also some bracket for tilt the SXT-SA, I forget that at the lab...
Yes, finally yesterday the ENEL (Italian Company for Electricity) give me the link.Ciao rextended any news after the Holiday Break about your work,
cetalfio
I have several of these in my network. Doing very nice job. Never fail. Uptime is only 100+ days because I do regularly update software. But some units are in place way over a year and never let me down...Hi,
I've read the first post and seem to understand that you intend to power all the equipment via RB750UP unit(s). Have you actually tried this method on a long term basis? The reason I ask is that I have had some problems with excessive power draw and subsequent port resets on a small relay point (1 PtP backhaul (Sextant) and 1 sector (UBNT panel + Rocket M5)). The setup worked perfectly for about six months but then started playing up. Troubleshooting pointed to the RB750UP unit. I admit that this RB was one of the very early production models but even after replacing the whole setup with new equipment and taking into consideration all the maximum power requirements, I still have issues with port resets. I monitor the unit via SNMP and it does not seem to be temperature/CPU related. Looking at the PoE power draw also does not give any concrete result.
BTW, nice setup and even I would be interested in knowing the supplier for the mast.
Auguri,
Mark.
this might be associated with the fact that as conditions are worsening radios switch to lower data rates and in turn crank up the output power of the radios, thus getting larger usage spikes. If router power chain capacitance is too low to compensate for these spikes, you get the spike out to PSE (RB750UP) and over the ethernet power loss increases quadratically and you get an overload detected.Hi,
Yes. 750up are very useful. With .ac I would need a gigabit version now. I had only one dying. This was a lightning stroke which removed the casing from the board ...I have several of these in my network. Doing very nice job. Never fail. Uptime is only 100+ days because I do regularly update software. But some units are in place way over a year and never let me down...Hi,
Auguri,
Mark.
You have done very nice job..Even I would love to install these panels soon..Grazie!Bello Lavoro !! Complimenti !!
Appena mi arrivano i pannelli lo finisco e lo provo.
When I receive the solar panels, I try it and I public other photo and test details.
