ovdeathiam
DDNS script for no-ip dyndns ipchange
Wed Jul 16, 2014 12:13 pm
I've seen some ddns scripts around here but usually these were having some compatibility issues on on newer RouterOS. I'd like to share what I use.
It works even if you're behind 2nd nat since it relies on an external service to get your ip.
DynDNS
ros code
:local DDNSuser "login"
:local DDNSpass "password"
:local DDNShost "domain.dyndns.info"
:local CURRip [/tool fetch url="http://myip.dnsomatic.com/index.html" mode=http dst-path=CURRip; :delay 1; /file get CURRip contents; /file remove CURRip]
if ([:resolve $DDNShost] != $CURRip) do={
    /tool fetch url="http://members.dyndns.org/nic/update?ho ... ip=$CURRip" mode=http user=$DDNSuser password=$DDNSpass dst-path=DDNShost keep-result=no;
    /log info message=("DDNS: Updating $DDNShost to:$CURRip")
NO-IP
ros code
:local DDNShost "domain.no-ip.com"
    /tool fetch url="http://dynupdate.no-ip.com/nic/update?h ... ip=$CURRip" mode=http user=$DDNSuser password=$DDNSpass dst-path=DDNShost keep-result=no;
ChangeIP
ros code
:local DDNShost "domain.changeip.com"
    /tool dns-update name=$DDNShost address=$CURRip key-name=$DDNSuser key=$DDNSpass
rextended
Re: DDNS script for no-ip dyndns ipchange
Wed Jul 16, 2014 1:16 pm
I fix some minor errors.
:local DDNSuser value="login";
:local DDNSpass value="password";
:local DDNShost value="domain.dyndns.info";
# possible value are DynDNS, No-IP, ChangeIP;
:local DDNStype value="DynDNS";
/tool fetch mode=http keep-result=yes url="http://myip.dnsomatic.com/index.html" dst-path="CURRip";
/delay delay-time=2s;
:local CURRip value=[:toip [/file get "CURRip" value-name=contents]];
/file remove "CURRip";
:if ([:resolve $DDNShost] != $CURRip) do={
 :if ($DDNStype = "DynDNS") do={ /tool fetch mode=http keep-result=no url="http://members.dyndns.org/nic/update?hostname=$DDNShost&myip=$CURRip" user=$DDNSuser password=$DDNSpass; };
 :if ($DDNStype = "No-IP") do={ /tool fetch mode=http keep-result=no url="http://dynupdate.no-ip.com/nic/update?hostname=$DDNShost&myip=$CURRip" user=$DDNSuser password=$DDNSpass; };
 :if ($DDNStype = "ChangeIP") do={ /tool dns-update name=$DDNShost address=$CURRip key-name=$DDNSuser key=$DDNSpass; };
 /log info message=($DDNStype.": Updating ".$DDNShost." to:".$CURRip);
I'm Italian, not English. Sorry for my imperfect grammar.
ovdeathiam
Wed Jul 16, 2014 1:34 pm
Any chances that there will be a feature implemented to use
:local CURRip [/tool fetch url="http://myip.dnsomatic.com/index.html" mode=http dst-path=CURRip keep-file=no;]
instead of
rextended
Wed Jul 16, 2014 2:05 pm
it's norma behaviour, because fetch is one command to get file, not one remote variable.
At max add one paramater like continue-script-when-done=true/false
wcsnet
Wed Jul 30, 2014 9:23 am
This is the no-ip script I use:
:global scriptemail
:global ddnsurl1
:global ddnsurl2
:local wanipchecklast
:local wanipchecknow
:local wanipchanged "no"
:local ddnsuser "xxx"
:local ddnspass "xxx
:local ddnshost1 "xxx"
:local ddnshost2 "xxx"
:log info "******************** starting - ddns********************"
:log info "-"
/tool fetch url="http://www.ipmon.co.za/ip.php" dst-path="ddns wan ip address.txt"
:log info "checkking for wan ip address"
:set wanipchecklast [/ip firewall address-list get value-name=comment number=[find list="my wan ip"]]
:set wanipchecknow "$[/file get "ddns wan ip address.txt" contents] "
:log info "current wan ip address: $wanipchecknow"
:log info "prevouis wan ip address: $wanipchecklast"
:log info "$[/system identity get name] wan ip address http://$wanipchecknow"
:if ($wanipchecknow != $wanipchecklast) do={
:log info "wan ip address has chaged"
:set wanipchanged "yes"
/ip firewall address-list set comment=$wanipchecknow number=[find list="my wan ip"]
:log warning "$[/system identity get name] wan ip address changed: $wanipchecklast -> $wanipchecknow"
:log info "updateing ddns host $ddnshost"
/tool fetch mode=http user=$ddnsuser password=$ddnspass url="http://dynupdate.no-ip.com/nic/update\3 ... ipchecknow" dst-path="ddns update result.txt" keep-result=yes
:delay 15s;
:set ddnsurl1 "http://dynupdate.no-ip.com/nic/update\3 ... ipchecknow"
:set ddnsurl2 "http://dynupdate.no-ip.com/nic/update\3 ... ipchecknow"
:log info "ddns result: $[/file get "ddns update result.txt" contents] "
:if ($wanipchanged = "yes") do={
:log info "generating ddns email report"
:global scriptemail
:local logcontenttemp ""
:local logcontent ""
:set logcontenttemp "Good Day \n\r"
:set logcontent ("$logcontent
" ."$logcontenttemp")
:set logcontenttemp "This is an automated notification, please do not reply to this email"
:set logcontenttemp "Please see below ddns update email report: \n\r"
:set logcontenttemp "*****************************************ddns report***********************************"
:set logcontenttemp "Current wan ip address: $wanipchecknow \n\r"
:set logcontenttemp "Prevouis wan ip address: $wanipchecklast \n\r"
:set logcontenttemp "Update url: $ddnsurl1 \n\r"
:set logcontenttemp "Update url: $ddnsurl2 \n\r"
:set logcontenttemp "Update url result: $[/file get "ddns update result.txt" contents] \n\r"
:set logcontenttemp "\n\r"
:set logcontenttemp "***************************************************************************************"
:set logcontenttemp "KEY: \n\r"
:set logcontenttemp "Should you have any queries, please contact your account manager"
:set logcontenttemp "Kind Regrads"
/tool e-mail send to=$scriptemail subject="$[/system identity get name] ddns report" body="$logcontent" start-tls=yes
:log info "******************** ending - ddns ********************"
Kind Regards
WERNER VENTER
Technical Support Engineer
Werner.venter.mail@gmail.com
kei888
Fri Aug 29, 2014 4:40 am
Hi folks!
Can you re-post the whole working update script for 6.18/ 6.19?
Kindly highlight the fields that needs to be edited.
Thank you.
wcsnet
Fri Aug 29, 2014 9:27 pm
Send me a email and ill send it to you werner.venter.mail@gmail.com
Kind Regards
WERNER VENTER
rextended
Fri Aug 29, 2014 10:09 pm
Why not post it here instead requre the email?
kei888
Tue Sep 02, 2014 2:53 pm
Hi folks!
Below is the script shared to me by Mr. Werner:
:global lastddnsupdate
:global ddnsurl1
:local ddnsuser "user"
:local ddnspass "password"
:local ddnshost1 "x.zapto.org"
:log info "-"
address.txt"
:log warning "$[/system identity get name] wan ip address http://$wanipchecknow"
ip"]
url="http://dynupdate.no-ip.com/nic/update\3 ... ost1&myip=
$wanipchecknow" dst-path="ddns update result.txt" keep-result=yes
:delay 15s;
:set ddnsurl1 "http://dynupdate.no-ip.com/nic/update\3Fhostname=
$ddnshost1&myip=$wanipchecknow"
Mr. Werner's note: "Just remember to add a address list item list = my wan ip as this is used to store the wan ip
add comment=0.0.0.0 list="my wan ip" "
Can someone verify the script?
Thank you.
wcsnet
Tue Sep 02, 2014 3:10 pm
Initially you just have to add
/ip firewall address-list add comment=0.0.0.0 list="my wan ip"
Kind Regards
WERNER VENTER
freemannnn
Long time Member
Long time Member
Tue Sep 02, 2014 8:40 pm
Cloud ip in mikrotik firewall works great for me and i forgot all about those like dydns sites!
kei888
Wed Sep 03, 2014 3:33 am
O yeah!
Thanks, men. No script needed. I was able to obtain a DNS Name.
I'm just wondering with the security of this feature?
Kampfwurst
Sat Nov 22, 2014 12:08 am
has anyone a working script for dyndns.org?
wcsnet
Sun Nov 23, 2014 2:53 pm
Check my script futhet up
Kind Regards
WERNER VENTER
lustyffh
Fri Jan 09, 2015 12:34 pm
Hi Folks,
an original script posted on Mikrotik wiki was based on comparing interface IP.
The new scripts posted above rely on web services. This new method doesn't work if one have multiple ISPs.
Can anyone share a script that works for specific WAN interface for multiple ISP environment?
Users browsing this forum: igaunis and 26 guests
