rextended
TDMA with GPS sync: NV3
Mon Jul 28, 2014 1:00 am
When you think to develop some like NV2 with GPS sync (NV3)?
One competitor, using atheros chipset, already do that.
If I do not have any hope to see that on the future, I'm forced to slowly move the AP to other competitors tecnologies.
Other competitors interface and CPE sucks, but 120 client on same AP and with frequency reusing......
I'm Italian, not English. Sorry for my imperfect grammar.
skynets
Re: TDMA with GPS sync: NV3
Fri Aug 01, 2014 12:56 pm
Yes. Subscribe to the issue
rextended
Fri Aug 01, 2014 8:46 pm
I hope on one plublic reply.
ste
Fri Aug 01, 2014 9:43 pm
I know 2 and a third trying to do. The first is expensive and we use it only for business. But the second with the now better interface is affordable and we start to use it.
rextended
Sat Aug 02, 2014 12:03 am
I'm try some Changium but at the end I'm forced to put one RB951 for the lack of features...
bajodel
Long time Member
Long time Member
Sat Aug 02, 2014 9:39 am
.. 120 client on same AP and with frequency reusing......
what? ..where is that jewel?
rextended
Sat Aug 02, 2014 9:47 am
Do not be excessively entusiast, the routing feature sucks, is only good to do Layer 2 link between backhaul and CPE, for have a good Layer 3, as I'm wont from MikroTik, you MUST use one RouterBoard at the end...
The trick are on the using GPS for sync all AP.
On this way you can also reuse frequencies, have more prerformant TDMA, and unbalance rx/tx.
ibm
Sat Aug 02, 2014 11:08 am
+1
ste
Sat Aug 02, 2014 12:18 pm
Most time there is an additional Device at the customer site. For residentials we have a box with telephony/DECT included which does all the tasks. Companies usually connect their own firewall. So we dont need advanced features at the customers site.
These software based tdma (airmax/nv2) protocols suffer from cpu speed. The faster the wireless cards/rates are the more work has to be done by the cpu. As standard 802.11 protocol is handled by the wireless chipset we will see nv2/3 cant keep up with the packet rate the chipsets produce. One competitor announced special additional chips to handle the load.
I guess MT has to invest in HW-Design or it will fall short handling the speeds 802.11ac produces.
I see SXT SA gets >250MBit/s on a 40MHz Channel with plain .ac. Doing additional TDMA processing with the 720MHz atheros cpu may be too much to assemble the packets just in time for the next timeslot.
bajodel
Long time Member
Long time Member
Tue Aug 05, 2014 6:50 pm
..The trick are on the using GPS for sync all AP.
If I understand well ..gps sync means accurate time sync, so radios can send/receive in sync (eventually unbalanced ..say .. 30/70%).
But.. what if I have a single board with 4 radio onboard each one driving its sector ..I wonder it wouldn't need any 'time sync' to drive its 4 onboard radio..
Surely I'm wrong, but please tell me why :D
rextended
Tue Aug 05, 2014 7:28 pm
GPS sync is more accurate than NTP sync...
bajodel
Long time Member
Long time Member
Wed Aug 06, 2014 9:36 am
my bad, I'm a big idiot :lol:
Every radio talk to ANOTHER ..and they need to be in perfect time sync.. (holiday need.. sorry) :D
server8
Wed Aug 06, 2014 3:59 pm
I think this is the easy way to use the same channel on the same tower, no gps sync, just software sync, MT guys is this possible?
rextended
Wed Aug 06, 2014 4:31 pm
And the other tower? GPS sync syncronize all tower...
server8
Wed Aug 06, 2014 5:54 pm
Uan is megl che nient :-)
sonny
Fri Jan 23, 2015 8:05 pm
Mikrotik, now it´s time to get the GPS sync working!
When?
How?
Majklik
Sat Jan 24, 2015 8:24 pm
Yes, it will be nice have APs in the sync for transmit. But this can be done without GPS. We need to have the same time on all towers but this time do not must be in sync with world time (UTC). And this is work for PTPv2 protocol (precise time protocol - IEEE1588).
If you have infrastructure where the towers have uplinks builded on the fiber Ethernet or full duplex radios, then can be very precisely synchronized the APs without GPS. PTPv2 protocol is capable with normal hardware a microsecond precision which probably is sufficient (with network cards and Ethernet switches with PTPv2 hardware support then is precision about 20 nanoseconds).
So we can have (gor example) one CCR1036 in the region, it have links to the towers (fiber, metalic, full duplex radios) and it runs as grandmaster clock for this region (PTPv2 server), the APs synchronize as PTPv2 clients to the master's time. This CCR can be synchronized with normal NTP. It is not important, that CCR do not have exactly correct world time but the APs with PTPv2 supports will have the same time as master.
Ofcourse, if the towers uplinks use normal half duplex wifi links then PTPv2 will not be more precise that NTP.
So Mikrotik, please take look on the software PTPv2 implementation for unixes: http://ptpd.sourceforge.net/ :-)
ste
Sat Jan 24, 2015 8:48 pm
It is much simpler to put GPS into the AP. Providing an exact ether sync to all APs every component on the path (switch, wireless bridge, ...) has to be part of the sync solution.
Users browsing this forum: DitaSoft, Google [Bot], Janncsi, sindy, smyers119, tdw and 182 guests
