shed
SSTP Server error...(x86)
Wed Jul 30, 2014 9:32 am
what is the problem?
wenasong
Re: SSTP Server error...(x86)
Thu Aug 07, 2014 7:21 pm
Same problem. My Win 8 throws me Error 619 if trying to connect the x86 SSTP Server.
zojka
Tue Aug 12, 2014 12:36 pm
I upgraded ROS x86 from 5.26 to 6.18 and I have a problem witch connection via SSTP.
I received error 619, is it bug ?
\\EDIT_1
I made some tests and:
5.26 - sstp works fine
6.12 - sstp works but it's the last version where sstp works well.
From 6.13 to 6.18 - connection via sstp doesn't work
I noticed that in 6.13 some fields changed in Certificat -> Advanced tab.
I use wildcard certificate.
\\EDIT_2
I received information from MikroTik support and this problem occurs on x86 routers only
They will try to fix this in v6.19
shed
Wed Aug 27, 2014 9:47 am
It solved at 6.19.
Thanks...
zojka
Thu Aug 28, 2014 1:47 pm
It solved at 6.19.
Thanks...
Yes, this *) sstp - make sstp work on i386 as well; fixed the problem with connection.
Users browsing this forum: Google [Bot] and 177 guests
