3r3d1
Script job killer
Tue Aug 12, 2014 12:23 pm
Hi everyone I'm trying to create a script that kill all the jobs.
# Set var
:local count 0
:local i 0
:local listid [:toarray [/system script job find]]
# Count number of jobs
:foreach id in $listid do {
    :set count ($count+1);
    :log info $count;
# Set count -1 to prevent that the scipt kills himself
:set count ($count-1);
# in case that are present 3 jobs or more the killer start to delete
:if ($count > 3) do {
    :while ($i != $count) do {
        :system script job remove $i;
        :set i ($i+1);
:log warning "The stuck spripts has been killed!";
The problem that I have is that the script doesn't execute this line:
The script is working since that point, is that line wrong? on the terminal is working.
Thanks in advance.
rextended
Re: Script job killer
Tue Aug 12, 2014 8:14 pm
Solution:
/system script job remove [find];
Explanation:
$i is only a number, you must provide the ID, use "foreach".
I'm Italian, not English. Sorry for my imperfect grammar.
3r3d1
Wed Aug 13, 2014 12:57 pm
Is working but it remove all the entry and the script is killing himself.
I used the variable $i to prevent this, when all the scripts that are stuck has been deleted the script i want to show a message in the log.
Via terminal i can do "/system script job remove 0" and i thought that i could do it in a script.
How i can delete the script of row $i?
If i use a foreach it will still delete all of them
:foreach id in [/system script job find] do {
    /system script job remove $id;
rextended
Wed Aug 13, 2014 3:53 pm
Inside foreach you must check the script name to prevent killing himself:
:if ([/system script job get $id value-name=script] != "myscriptname") do={ <killing instructions> };
3r3d1
Wed Aug 13, 2014 7:49 pm
I have tried like this but is not working
# Set var
:local count 0
# Set count -1 to remove this scipt from the count
:if (count > 3) do {
    :foreach id in [/system script job find] do{
        :if ([/system script job get $id value-name=script] != "jobs_killer") do={
            /system script job remove [find id=$id];
:log warning "The stuck scripts has been killed!";
Where is the mistake?
rextended
Wed Aug 13, 2014 8:06 pm
/system script job remove [find id=$id]; ??????????
/system script job remove $id; !!!!!!!!!!!!!!
3r3d1
Mon Aug 18, 2014 7:05 pm
Sorry about that the fact is that i tried different way as that /system script job remove $id; wasn't working.
# Set var
:local count 0
I'm using RB2011 with in RouterOS 6.7.
Any idea why is not working?
eworm
Thu Feb 21, 2019 7:14 pm
Even easier:
:foreach id in=[ / system script job find where script!="myscript" ] do={
  / system script job remove $id;
Or even more simple:
/ system script job remove [ find where script!="myscript" ]
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Users browsing this forum: No registered users and 8 guests
