azurtem
Trainer
Trainer
RB2011U burning hot
Tue Aug 12, 2014 8:23 pm
Hi
I just installed an RB2011UAS-2Hnd and when I was about to leave I touched it
It was burning hot; I checked the health monitor and saw 82C
Config: 2 active Gig Eth ports, and two Fast Eth, that's all
12 routes, 69 F/W rules, 6 NAT rules, no mangling, no queues
The CPU was only around 4-6% at the time
I removed the rubber pads underneath it and placed it on top of metal cabinet so as to help dissipate the heat
Ten minutes later and the temp is steady at 80C, CPU 0-2%
The box feel very warm top side, and hot (not as hot as before) on its underside
Is the system faulty ?
thanks
yann
azurtem
Trainer
Trainer
Re: RB2011U burning hot
Wed Aug 13, 2014 3:31 am
Well, several hours later and we are down to 45 C
ouf !
yann
normis
Wed Aug 13, 2014 10:47 am
the most common cause for overheating RB2011 are damaged radio amplifiers U700, U701, or soldering problems with U100 AR8327 chip, but
in those cases they never cool down. So much heat can give only damaged components, so most likely you need to return it for RMA. When board heats
up again, he can check wich component is hottest and it is worth a look in Routeros commands: "tool profile" (if usage is normal) and
"interface ethernet switch port print stats" , there is columns "switch1-cpu switch2-cpu", if there are problems with CPU or PHY chip,
they always give thousands of "rx-fcs-error".
azurtem
Trainer
Trainer
Thu Aug 14, 2014 1:12 pm
Thanks Normis
Today 37C (yeah !)
Could it be that I had scheduled the disabling the wireless module (not rebooted though) ?
yann
romanmazur
Tue Nov 08, 2016 3:35 pm
Similar issue here, but I find a solution. In my case, this is faulty power source. When I replaced default power source with one of 24V/1.25A, RB temperature went down from 92C то 45С and router never heats up again :D
Users browsing this forum: jvanhambelgium and 27 guests
