MUM Europe 2020
Gregg
new home network
Sun Aug 24, 2014 8:28 pm
Hi everyone,
I'm currently setting a new home network with main router Mikrotik RB2011L-IN and two Mikrotik RB911G-2HPND.
At first I set main routers 10th port to pppoe, to reach the internet, but now I don't know how to change 1st port from gateway to normal one.
then I tried to hook up wifi routers and they just didn't work. I really don't know how to set them up :(
Sorry I am really new to mikrotik.
Marconet
Re: new home network
Mon Aug 25, 2014 11:02 am
first rule : each machine different ip
mainTAP
Mon Aug 25, 2014 1:33 pm
What do you mean by changing it from gateway to normal one? Are you doing NAT on that router ? If yes, change masquerade rules to your new 'gateway' interface. Check your DHCP, IP addressing and bridge to swap 1st port with 10th.
Gregg
Mon Aug 25, 2014 1:48 pm
yes I changed all that, but when I plug another device, it just can't connect
Edit: I forgot to add it in bridge.. now it works like a charm :)
Users browsing this forum: Andrejm, msatter and 42 guests
