OriiOn
Determine traffic going over individual switch ports
Sun Aug 31, 2014 2:40 am
I am using a RB750GL as a switch, where one port is the master port and ports 2-5 are configured as slaves. As a result I can only see the traffic going in and out of the master port (Interfaces List in WinBox), but I can't see how much traffic is transmitted on the individual (switch ports).
Basically I want to determine the amount of "load" (of the available theoretical 1Gbit/sec) that is going through the switch.
jarda
Re: Determine traffic going over individual switch ports
Sun Aug 31, 2014 3:00 pm
Release the ports from switch and set all ports to bridge. It will utilise cpu so it can limit the transfer speeds but you will have the statistics.
