MUM Europe 2020
plisken
750up POE on/off script
Sat Sep 13, 2014 2:03 pm
What script i need to set the POE on/off from interface ether2 example
can this by done
c0d3rSh3ll
Long time Member
Long time Member
Re: 750up POE on/off script
Sat Sep 13, 2014 11:07 pm
for power off
ros code
interface ethernet poe set poe-out=off ether5
for power on
ros code
interface ethernet poe set poe-out=auto-on ether5
or
ros code
interface ethernet poe set poe-out=forced-on ether5
nothing
InoX
Sat Sep 13, 2014 11:12 pm
Thats realy funny.
These are terminal commands not scripts.
marizo
Sun Sep 14, 2014 11:03 am
make script with these commands and schedule when you want it to run.
plisken
Sun Sep 14, 2014 11:50 am
Thanks guys, this will definitely work.
I'll try it out when I have the rb750up
plisken
Sat Oct 04, 2014 7:42 pm
Working like a charm
Thanks c0d3rSh3ll
for power off
ros code
for power on
ros code
or
ros code
tlallmand
Sat Sep 05, 2015 5:44 am
I'm trying to do something similar here and I am brand new to scripting. I am wanting to turn the poe power on and off at designated times on a per port basis. Would you be willing to share your actual scripts and/or does anyone else have a good way of doing this. There are certain devices attached to some of these ports and everything is running on solar power so I am looking at ways to conserve power when devices are not needed.
Users browsing this forum: No registered users and 4 guests
