So the situation is like this. I have two RB951G connected over around 50m of FTP cable. The link is established as 1Gbps Ethernet.
Starting a bandwidth test between them, over UDP I've got around 250 Mbps, over TCP I've got around 120-130 Mbps.
I guess this is the maximum capacity of the routerboards. I can't seem to find what is the expected throughput for RB951G though....
What I'm interested in is, whether it's possible to terminate this line with Routerboards that are able to utilize the full capacity of the link? RB2011 perhaps... but I think RB2011 is essentially the same like RB951G with one additional switch chip.
Is there a SOHO Routerboard that is able to handle 1Gbps line rate, or close to that? Even if it is more expensive, it would still worth it....
