MUM Europe 2020
SvenWR
l2tp Client not reachable
Wed Sep 17, 2014 1:46 pm
i have established successfully a l2tp connection. :) now i try to access a ftp server on my l2tp client (10.0.1.9) from the other side of the tunnel (10.0.0.2). the l2tp server (10.0.1.1) is reachable from the 10.0.0.2, the client is not. i am able to establish a telnet connection from the client (10.0.1.9) to the 10.0.0.2....
does this forum have any suggestions?
thanks in advance.. :)
NAB
Trainer
Trainer
Re: l2tp Client not reachable
Wed Sep 17, 2014 4:39 pm
You need to ensure that you are routing the correct networks up and down the L2TP link. Do a packet trace or watch the network to see where your packets are going. You will probably find they're not going where you want!
Nicholas Barnes BSc(hons)
Certified Mikrotik Consultant
Certified Mikrotik Trainer
Vitell - Asterisk, Linux and network consultants
Unofficial IRC channel: #routerboard on irc.z.je
SvenWR
Wed Sep 17, 2014 5:02 pm
Hi, thanks for your Reply...
Routing? I thought there is only one subnet- no routing, no gateway?
SvenWR
Wed Sep 17, 2014 5:31 pm
When i make a (telnet) connection from the 10.0.1.9. to the 10.0.0.2, the telnet server tells me: "connection to this unit established from 10.0.1.1:1896". May be this additional information is usefull.
Users browsing this forum: No registered users and 16 guests
