MUM Europe 2020
adyb76
Trainer
Trainer
MRTG Not reporting accurately
Sat Sep 20, 2014 10:40 am
I recently reinstalled mrtg onto a new server and set it up to monitor the traffic for our CCR edge router running ros 6.19.
I used the cfgmaker to create the config file, and having reviewed it I am happy that it is monitoring the correct interfaces.
The problem is that there is a magnitude of difference between the stats mrtg produces vs the routerboard graphs available on the web gui.
Mrtg reports a max of 173.1 mbit/s whereas the web gui graph reports 880.89 mbit/s whilst I am not expecting these to be the same, I was expecting them to be much closer.
Any ideas?
Ade
CyberTod
Long time Member
Long time Member
Re: MRTG Not reporting accurately
Mon Sep 22, 2014 8:55 am
Maybe you are using 32bit counters. Use 64bit counters.
aacable
Thu Sep 25, 2014 10:11 am
I recently reinstalled mrtg onto a new server and set it up to monitor the traffic for our CCR edge router running ros 6.19. I used the cfgmaker to create the config file, and having reviewed it I am happy that it is monitoring the correct interfaces. The problem is that there is a magnitude of difference between the stats mrtg produces vs the routerboard graphs available on the web gui. Mrtg reports a max of 173.1 mbit/s whereas the web gui graph reports 880.89 mbit/s whilst I am not expecting these to be the same, I was expecting them to be much closer.
Any ideas? Ade
If you have a fast router you might want to try to poll the 64bit counter. To adjust your target config in MRTG for 64 bit counter, you need to add :::::2 to the end (note: five colons).
Sample:
Target[10.0.0.1]: 2:community@10.0.0.1:::::2
or you can use interface oid too.
_____________
Regard's
Syed Jahanzaib
Web: http://aacable.wordpress.com
Email: aacable [at] hotmail.com
jfvelamoscoso
Trainer
Trainer
Thu Oct 30, 2014 9:20 pm
The problem is that your graphs on mrtg are on bytes and on webgui are on bits.
I am facing the same problem now, any advice?
jfvelamoscoso@gmail.com
Network Engineer Noc Department
MTCNA, MTCTCE
If it helps please give some karma
joegoldman
Long time Member
Long time Member
Sun Nov 02, 2014 11:17 am
Unlikely - the figures do not even closely match for this to be a possibility.
I like the idea of 32 bit vs 64 bit counters, If you are only polling every 5 minutes, it is possibly at 800+mbit/s the 32 bit counter is 0'ing out and starting from scratch making it back up to 170mbit before you poll it again, then continues.
At the end of your peak period (if you have one) does it suddenty jump up to match the right value? Or do you keep a pretty constant 600mbit/s + going through the interface?
jfvelamoscoso
Trainer
Trainer
Thu Nov 27, 2014 6:23 pm
I made it work just changing from this:
Options[_]: growright,bits
To this:
Options[_]: bits,growright
MTCNA, MTCTCE
Users browsing this forum: dioeyandika, Google [Bot] and 51 guests
