Ciambot
ethernet tx/rx too long
Mon Sep 29, 2014 1:17 pm
since some months I'm seeing "tx/rx too long" statistic grow a lot (ethernet -> overall stats). I don't know why.
All my routers (RB1100AHx2) have this problem, often in the interface that connects to the backhaul.
I think the cause may be sought in the border router. It is a CCR1036-12g4s, but i cannot read tx too long parameter (see in picture).
So I've have two questions:
1) Why have I this issue?
2) Can this issue cause problem in my network, like speed?
Info:
CCR
MTU: 1500
L2MTU: 1767
RB1100
MTU: 1500
L2MTU: 1598
Customer's connection: PPPoE
Ros: 6.19 on ccr, 6.7 on RB1100
adairw
Re: ethernet tx/rx too long
Sat Dec 13, 2014 4:39 pm
I'm having the exact same problem. I have an 1100AHx2 with an airFiber24 plugged in to ether 11.
Robinson
Fri Sep 25, 2015 3:53 pm
What RoS version? And I see it at Omnitik, ether1 RoS 6.19
InoX
Fri Sep 25, 2015 4:54 pm
My RB1100AHx2 have 0 on all interface, v6.33rc11
Robinson
Fri Sep 25, 2015 5:18 pm
Upgraded to 6.32.2 .. no changes
JimmyNyholm
Fri Jan 12, 2018 7:31 pm
Someone know what this is? I have it on in 6.41 HapACs connected with Max L2Mtu on sfp to CCRS...
sindy
Fri Jan 12, 2018 9:55 pm
Could it be that the equipment connected to the affected ports supports jumbo frames?
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: Bing [Bot], eworm, harvey, maungmaungmyatsan and 66 guests
