+1With 80mhz we need a spectrum analyzer. When can we have this feature. Its hard to find the best channel if we cant look. I use spectral scan all the time. Its so important.
Please prioritize items like this as we (WISP's) need every tool today to deal with channel congestion and signal interference.It looks like we can implement Spectral Scan on existing devices, but it will take some time. It is on our to-do list
This spectral scan is not to confused with a spectrum analyzer which give a total view of the RF present on the frequencies it scans.Yeah this is very important. Our company just bough $80 grand in the last 2 months of airfiber 5. I am still waiting on the spectrum analyzer for the 802.11ac. We are expanding a couple states wide.
+1I made a similar feature request about a month ago, about the "Constellation Diagram" coming to RouterOS.
I assume you are talking about PTP and not PTMP and what is your recommended settings for Nstreme?yeah I dont use NV2. Nstreme is so solid. Its better than any other protocol out there. As long as you know how to use it.
Would it not make more sense for the development of radios that have very high rejection to unwanted frequencies (interference) when in listen mode rather than sales spin of "Constellation Diagram" of how good it is.+1I made a similar feature request about a month ago, about the "Constellation Diagram" coming to RouterOS.
Yeah try fitting them into a integrated sector or PTP link that has the board in the antenna and also unless you happen to use a frequency which gives optimum impedance load the insertion losses can be quite high on the N connectors?Rejection of the same frequency? If not just use a cavity filter. Its already out there. Works great.
I tried both 802.11 and Nstreme for PTP links and when there is co-location interference NV2 is the most stable choice when using OSPF routing.yeah I dont use NV2. Nstreme is so solid. Its better than any other protocol out there. As long as you know how to use it.
I have seen high signals levels of -30dbm at 5200 effecting units running on 5800, spectral scan will show you that you have a clean channel at 5800 and yet CCQ takes a nosedive because the input stage of the of the 5800 device is overloaded by -30dbm at 5200, the real question is how do we reduce when elimination is much harder to achieve, normally moving devices further physically apart helps but to compound the problem, more and more sectors are required as customers internet usage has resulted in fewer clients capacity per sector so what do you do when moving cannot be done and to add to this you cannot move frequencies either on a busy mast.Yeah that is correct. I love the spectral scan. Because if nstreme dont work, then you have a problem. Use the spectral scan to find a clear channel on both side and boom. Nstreme works and you just tune a little and you get very fast link.
As mentioned I cannot on a busy mast move AP's or PTP's or even frequencies, there is a fundamental flaw in how wireless transmissionYeah, I call them problem customers. Adjusting power or moving the antenna fixes those customers. I sometimes put up a second antenna and move one customer at a time to find some problem customers. But a better tool would be cooler.
What's CCQ? And makes it so good?I agree. I have been just using the CCQ and this product is better than anything else out there thats AC so I am forcing my self to use it even though we have no spectrum analyzer. Please mikrotik. We need it.
a total step back for mikrotik from being a leader offering spectrum analysis when many vendors do not offer it.
now that spectrum analysis is a common feature offered by many vendors mikrotik decide to left this feature out.
sincerely is hard to understand mikrotik strategy
I still love them. Pretty fast and reliable. I had ubnt. Mikrotik is way more stable. I ended up removing all ubnt ac.
While I agree a spectral scan can be a worthwhile additional to us WISP's but this type of scan does not give the complete picture of what devices in the licence exempt bands are actually present, another poster did say on this forum that even though you cannot see the other device(s) on the scan the operational noise floor will reveal its presence.I have to constantly go to tower sites, take down the MIkrotik radio, install UBNT radio, do an AirView spectral scan, then put the MIkrotik back up because MIkrotik STILL does not have any spectral scan tool, which almost renders the device worthless. This is SOOO necessary!!!! And I'm actually shocked they do not have anything available yet. The "freq usage" and whatever else is worthless, because it ONLY shows usage on 802.11 devices, and on the same channel width, etc., doesn't show just ALL noise on the band. How do ya'll figure out what channel to use?
After we got used to AirView with UBNT, I can't ever go back!
+1 10mhz channelwe have 3 issues (and counting) with ac equipment:..
Its is on your to-do list from 12/2014, its a very long time and we need this feature.It looks like we can implement Spectral Scan on existing devices, but it will take some time. It is on our to-do list
No answer here, no answer to [Ticket#2015092466000985] with same question from 24.9.2015Its is on your to-do list from 12/2014, its a very long time and we need this feature.It looks like we can implement Spectral Scan on existing devices, but it will take some time. It is on our to-do list
Will this row on the "to do" list, getting closer or getting farther? It's been a while ....isn't it?It looks like we can implement Spectral Scan on existing devices, but it will take some time. It is on our to-do list
You tried UBNT AC to early. They need 6-12 Months from release until it is usable. Live Spectrum Scan of AP + all CPES in one table is a great feature. With MT HW this is not possible without interruption. At the moment it does not possible at all.I still love them. Pretty fast and reliable. I had ubnt. Mikrotik is way more stable. I ended up removing all ubnt ac.
This is major feature of MikroTik RouterOS wireless devices. Please resolve this quandary.a total step back for mikrotik from being a leader offering spectrum analysis when many vendors do not offer it.
I had a true, dude is reborn and spectral scan will be implmented for some months. I hope, that I will have a true in this again.No answer here, no answer to [Ticket#2015092466000985] with same question from 24.9.2015Its is on your to-do list from 12/2014, its a very long time and we need this feature.It looks like we can implement Spectral Scan on existing devices, but it will take some time. It is on our to-do list
Hey, Guys, I know, that you had a MUM, but your answer is necessary!!!
At MUM 03/2015 Prague Uldis told me, that ss (spectral scan) on ac chipset will be first thing, which will be implemented about next 3 months, next will be implemented support for custom frq for chipsets AR93xx and all newer one!
Go On, hear for some time ISPes. Mikrotik Go ON! You products is beautifle BUT......
It seems, that you will must release the new version of dude, because its seems to be a hard problem to reproduce your very beautiful thinks to new chipsets!
Do you affraid to release new (old) features for ISP or There Is another problem?
That's the reason I'm not upgrading to NetMetal5 or RB922 yet. I'd do that instantly if they had spectral history feature..Spectrum analyzer is a must for a wireless device!
I hope to see with ROS 7 gps sync and NV3Looks like routeros 7 should be coming very soon. Please, at least get spectral history working for AC. I want to start converting whole network to AC once its out. Not just for backhauls.
If you are wishing for 7.x in order to use spectral scan, think again. If and when 7.x comes out, it being Mikrotik, will take at least a solid year of development until the major bugs are ironed out. So, the early adopters, will probably have spectral, but will also face issues that will most probably outweigh the spectral scan joy.Looks like routeros 7 should be coming very soon. Please, at least get spectral history working for AC. I want to start converting whole network to AC once its out. Not just for backhauls.
Same here... all our network is ac. ... but we still have metal grooves up on each hub site to be able to do a spectral scan... it's not a perfect scan but it work.Yeah, it's a bit annoying. We've upgraded lots of APs to NetMetal5 for AC, so lost ability to do spectral scans. For installations in some busy places I keep buying good old RB912s just for that feature.. :/
+1 spectral scanwe have 3 issues (and counting) with ac equipment:
no 10mhz channel
no spectral scan
no tx power control
But why?You only cannot see those values.
Me too.RB6.37 RC with wireless package, still no spectral history. Will probably join others in abandoning MikroTik. This feature is a necessity.
LOL yeah but you know as well as I do, as soon as your competitor changes channels your gunna be right back out there on a service call,With 80mhz we need a spectrum analyzer. When can we have this feature. Its hard to find the best channel if we cant look. I use spectral scan all the time. Its so important.
Which routerboard? nstreme or nv2? Did you test ptmp?Well, I know one thing for sure. Mikrotik will have a surprise for us. The new 6.37 has super fast wireless. With only 2 chains I can put 1 connection tcp at 300Mbps. Udp is over 400Mbps. This is a four-mile link. Nice work mikrotik.
This only works with the 2.4 GHz WLAN interface.Although this doesn't help most people with this issue, the hAP AC (full, not lite) can do spectral scan w/AC. (Therefore it seems the lack of the function is something to do with the chip itself rather than whether it is AC or N)
just that's the problem, here in my city the spectrum is very polluted and the snooper is very limited, as it has many here who use 3,5,8,10,30,60,80,160mhz of channel-width with owners protocols often are not detected by the snooper, and every week I have to monitor the spectrum, so I downloaded all mantbox and other AC devices and put back the old equipmentYou can guess and try according to the wireless snooper.
And still nothingWe are waiting more than 2 years for spectral scan
Seems to be The only wayany news? i recently bought six dynadishes to make ptp links and discovered this awfull truth!!!! moving to another brand?
@rtacheny,based on your experience, where to look for good AP's/WiFi devices that deliver better results ? Probably I'm going to use MT devices for routing only, at least till MT get back into expected level.The issue isn't with Mikrotik's programming capabilities. Unfortunately they are choosing to be tight lipped as to why this feature is absent. Qualcomm realized how important this feature was and started limiting it's support in their chipsets to more expensive chips that are for "enterprise".
In short Mikrotik decided to keep costs down and pad profits by using the chips that do not include this feature. If this ever changes, you will have to buy new equipment anyways. Stop waiting, vote with your wallet and jump the ship. Mikrotik is so far behind in the wireless market.
Either that, or someone from Mikrotik can get their butt's in here and tell us/add support for these features in a Compex or JJPlus card and you can start using M11Gs.
There is only one advice at the moment if your Wireless is working in noisy invoirement, don't by Mikrotik AC Products!Every time I got a "topic reply notification" I hope that someone from Mikrotik have some gret news. But sadly, this waiting is killing me
Ok thanks, looks like mikrotik ignoring obvious basic requirements for the modern equuipment to make it cheaper. The most nearest competitor has spectral scan in all AC devices + able to do live spectral scan. Have to stay with N equipment but really time to start looking for something modern from competitors (and very sad about that)IPQ is Atheros-Qualcomm.........
And i have SXTsq AC here with IPQ4018
no spectral scan......
viewtopic.php?f=3&t=128310#p632411
Sadly, we have been solving it since 2014....Ok thanks, looks like mikrotik ignoring obvious basic requirements for the modern equuipment to make it cheaper. The most nearest competitor has spectral scan in all AC devices + able to do live spectral scan. Have to stay with N equipment but really time to start looking for something modern from competitors (and very sad about that)
We know about ath10k features, we are using our own wireless driver, where this implementation isn't as straight forward as on ath10kSpectral scan is supported
Source https://wireless.wiki.kernel.org/en/use ... ctral_scan
