ibm
Ping to the router itself too high
Fri Oct 03, 2014 2:07 pm
Why my router when pinging itself have this ping?
macgaiver
Re: Ping to the router itself too high
Fri Oct 03, 2014 2:47 pm
Why not? :) Pinging itself is hardy highest priority traffic :)
RouterOS is all about traffic throughput - traffic to router itself and from router is lower priority to your client traffic through router.
ibm
Fri Oct 03, 2014 5:11 pm
If I ping it from another router directly connected with a ethernet cable I have max 1ms and an average of 0ms so I thinked that pinging itself must have anaverage of 0 or 1 ms.
johnsmith
Thu Sep 15, 2022 6:44 pm
same problem, router ping to itself (or from switch directly connected) is 2-5ms, ping between anything else in the network <1ms,
it's not the a hardware issue - router has been changed and restored from export. Different Cat patches or DAC.
Router load 2-3%. Time is correct.
rextended
Thu Sep 15, 2022 6:46 pm
Try to ping 127.0.0.1 and see the differencies...
johnsmith
Thu Sep 15, 2022 7:15 pm
no difference to ping to router IP
rextended
Thu Sep 15, 2022 9:26 pm
ok, sorry for curiosity...
johnsmith
Fri Sep 16, 2022 3:37 pm
I eliminated any external hardware and router itself (had the same issue on previous one - different model), when I ping any device on the same subnet to itself, ping is 0ms.
Ping is increased from the router by the difference, e.g. ping to 1.1.1.1 from the router is 6ms, from switch directly connected to the router to 1.1.1.1 is 4ms.
Users browsing this forum: GoogleOther [Bot] and 76 guests
