boardman
RB112 useless after upgrade to 2.9.25 broken package I guess
Sat Jun 10, 2006 8:15 pm
I upgraded one RB112 from 2.9.24 to 2.9.25 and now its not working any suggestions how to fix this mess?
I guess the package was broken, now how do I fix it?
Here's the terminal output
Reboot, yes? [y/N]:
system will reboot shortly
Rebooting...
Stopping services...
ERROR: installation of routeros-rb500-2.9.25 failed: broken package132
WARNING: package system-2.9.25 onuninstall script failed
11 packets tra
/etc/rc.d/rc.stop: 34: /etc/rc.d/rc.postinstall: not found
round-trip m
/etc/rc.d/rc.stop: 36: /bin/umount: not found
Now it keeps rebooting:
RouterBOOT booter 1.13
RouterBoard 112
CPU frequency: 175 MHz
Memory size: 16 MB
Press any key within 1 seconds to enter setup.
kernel not found
trying bootp protocol..........................................................d
kernel loading failed
C¡HHõÕÑ•É ==Q
sergejs
Sat Jun 10, 2006 8:34 pm
try to reinstall your board using netinstall.
boardman
Thks sergejs that did the trick
Sat Jun 10, 2006 11:36 pm
Thks a lot sergejs, that did the trick.
boardman
Why mikrotik does not ZIP the .npk?
Sun Jun 11, 2006 6:09 pm
Does anybody has an idea why Mikrotik guys does not ZIP .npk files in order to avoid this "damaged" packages downloads in the future?
Is a lot easier to re-download a damaged ZIP that netinstall again a router, dont you think so?
Best
Jorge
sergejs
Sun Jun 11, 2006 7:23 pm
Jorge, there are alreade zip package for both version x86 and 'ns'.
DirectWireless
Mon Jun 12, 2006 7:59 am
I had to netinstall 3 2.9.18 to 2.9.25 upgrades this week on RB112's. I did not change the file or redownload it, it worked on 3 of them, and 3 of them it failed on. Some I used FTP, others I used Winbox drag and drop, and it didn't seem to matter (3 good ones were combinations of both also), and 1 was lost with a direct ethernet connection.
All the same downloaded file. Does MT have a checksum on the NPK file, or does it blindly install it?
boardman
Mon Jun 12, 2006 8:44 pm
Thks sergejs, but I guess you mean the "all packages" file isnt it?
And I guess the file that is or was damaged was the one hosted at Mikrotiks USA server; because I downloaded it again and upgrade again the RB112 and had the same result, then I tried to netinstall that same .npk and netinstall crashed, then I downloaded the .npk from Latvia server and everything just went OK.
Best
Jorge
DirectWireless
Mon Jun 12, 2006 11:08 pm
That does make sense, I think I might have redownloaded the file after I had a problem from the first one now that you mention it.
nowoxi
Tue Jun 13, 2006 1:48 pm
well personnally i usually upgrade with ftp clients like smartftp other methods always give me some sort of error or the other. you guys should try that out too
boardman
Tue Jun 13, 2006 6:54 pm
Well ... it was upgraded using a FTP client....
The Netinstall method was used after the routerOS got screwed up by the damaged .npk file.
Best
Jorge Boardman
Users browsing this forum: ptolm and 31 guests
