javajox
Error booting RouterOS on ESXi libucrypto.so
Sat Oct 04, 2014 4:02 pm
I tried to install RouterOS 6.20 on ESXi, but got this exception when I tried to boot up the VM :
/init: can't load library 'libucrypto.so'
How to fix this ?
syadnom
Re: Error booting RouterOS on ESXi libucrypto.so
Sun Oct 05, 2014 12:22 am
same issue, v6.20 virtualbox
overdrv
Sun Oct 05, 2014 3:04 pm
Same problem here using qemu.
Víctor De La Nuez
WiFi Canarias
http://www.wificanarias.com
aleh
Mon Oct 06, 2014 7:10 pm
Hi! Same here on Kvm, btw 6.19 works flawless. best wishes
peektoseen
Thu Oct 09, 2014 9:28 am
I also have this issue with virtualbox and RouterOS 6.20
scottniven
Thu Oct 09, 2014 8:14 pm
Same issue on a fully dedicated machine - I can install 6.19 but can't upgrade to 6.20 or 6.21. It says its upgrading on restart but comes back to version 6.19. Did anyone work this out?
Scott.
scottniven
Thu Oct 09, 2014 8:46 pm
Ok, I fixed my problem with it by editing the ISO file. For anyone that wants a copy of it, it's here;
http://niven.me.uk/mikrotik/mikrotik-6.20-edited.iso
Obviously I accept no responsibility for using this and something going wrong - use at your own risk!
Hope this helps.
Scott.
milonurv88
Fri Oct 10, 2014 5:04 pm
What did you modify, is it outstanding for the OS? I'm downloading the iso you posted.
javajox
Sat Oct 11, 2014 4:43 pm
scottniven, What do you mean "I fixed my problem with it by editing the ISO file" ? What exactly did you changed in the .iso file ?
No one will use your "custom modified" .iso file, probably you placed some malware in there.
scottniven
Sat Oct 11, 2014 4:57 pm
Hello javajox,
Fully understand the predicament there. It was simply given for you or anyone else to use at will, hence the warning. If you extract the contents of the original ISO file you will see the Linux subsystem for the installer and the *.NPK packages. I replaced the Linux system for the working 6.19 version as 'libucrypto.so' is part of that.
Scott.
aleh
Sun Oct 12, 2014 9:27 am
One week gone, something from official side available at the moment? Would be helpful to get some info, otherwise in my eyes bit strange to invest in x86 license. best wishes,
macW0rm
Mon Oct 20, 2014 8:28 pm
Probably he just removed the services that use the library libucrypto.so like VPN.
Have you checked what is missing on this custom ISO?
internetolog
Wed Oct 22, 2014 2:24 pm
Can't install 6.20 on a q6600 pc.
Any update would be helpful. Does it help to change the .so file?
eduardosilva
Wed Oct 22, 2014 5:16 pm
Same issue here with mikrotik-6.20.iso
I compared the local md5 to mikrotik.com/download and they are the same.
silvertip257
Thu Oct 23, 2014 3:19 am
Found the same problem when trying to quickly spin up a VM in VirtualBox to do some brief testing.
I'm guessing nobody pinged Mikrotik on this problem with the 6.20 ISO image?
Screenshot:
Edit on 2014/10/28 @ 23:01 GMT: Fixed my typo with the version number...
silvertip257
Sat Oct 25, 2014 6:50 pm
I contacted Mikrotik and received the following response.
(This was the 23 October, so although I read it within a few hours of receipt, I am late posting it here.)
yes, we are aware of this problem with v6.20 x86 installation iso. It will be
corrected for next web release version.
Regards,
Krisjanis P.
Users browsing this forum: arachman, Bing [Bot], JawadSikandaryHerat, LegendKillerBV, MSN [Bot], RobWFS, vjs and 103 guests
