davidreaton
RB951G-2HnD as AP with 2 VLANs
Tue Oct 07, 2014 4:41 am
We recently upgraded the network in our church with a CCR-1016-12G cloud core router and a RB951G-2HnD used as an access point. I configured 2 VLANs (SSIDs=Prayer and KBCfreewifi) in addition to the primary network (SSID = KBC). These are trunked together to the CCR. There are separate IP pools set up for the VLANs, and a hotspot splash page for the public wifi.
Everything works as intended, for a few minutes. Initially, the wireless clients get the proper IP addresses from the correct pool, and the public wifi users see the splash page before they get on the internet. After about 5 minutes, the connection stops. The clients are still connected to the AP, but there's no internet access. Nothing can be pinged, internal network or external. Walk away and come back 30 minutes later, you can connect again, but with the same behavior. I logged wireless events and you can see that the AP lowers the connection speed until it just gives up and disconnects due to 'excessive data loss'.
Any help will be much appreciated! The 951 config is listed below.
Thanks,
Dave
# oct/06/2014 13:18:26 by RouterOS 6.4
# software id = X3Z0-1NV6
add l2mtu=1594 name=Prayer
add l2mtu=1594 name=Public
add admin-mac=D4:CA:6D:CC:7F:C1 auto-mac=no l2mtu=1598 name=bridge-local \
protocol-mode=rstp
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 master-port=ether2-master-local name=ether5-slave-local
/interface vlan
add interface=ether1-gateway l2mtu=1594 name=vlanPrayer vlan-id=10
add interface=ether1-gateway l2mtu=1594 name=vlanPublic vlan-id=20
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik wpa-pre-shared-key=\
xxxxxxxxxxxxxxyyyyyyyyyyyyzz wpa2-pre-shared-key=\
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-key-update=1h \
management-protection=allowed mode=dynamic-keys name=KBC \
supplicant-identity="" wpa-pre-shared-key=xxxxxxxxxxxxxxy \
wpa2-pre-shared-key=xxxxxxxxxxxxxxy
add authentication-types=wpa2-psk eap-methods="" group-key-update=1h \
management-protection=allowed mode=dynamic-keys name=Prayer \
supplicant-identity="" wpa2-pre-shared-key=xxxxxxxxxxxxxxyyyyyyyyyyyyzz
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
management-protection=allowed name=Public supplicant-identity=""
/interface wireless
set 0 band=2ghz-b/g/n country="united states" disabled=no distance=indoors \
ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=ap-bridge \
security-profile=KBC ssid=KBC tx-power-mode=all-rates-fixed \
wireless-protocol=802.11
add disabled=no l2mtu=2290 mac-address=D6:CA:6D:CC:7F:C5 master-interface=\
wlan1 name=wlanPrayer security-profile=Prayer ssid=Prayer wds-cost-range=\
0 wds-default-cost=0
add disabled=no l2mtu=2290 mac-address=D6:CA:6D:CC:7F:C6 master-interface=\
wlan1 name=wlanPublic security-profile=Public ssid=KBCfreewifi \
wds-cost-range=0 wds-default-cost=0
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
mac-cookie-timeout=3d
add address-pool=default-dhcp interface=bridge-local name=default
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=ether1-gateway
add bridge=Prayer interface=vlanPrayer
add bridge=Public interface=vlanPublic
add bridge=Public interface=wlanPublic
add bridge=Prayer interface=wlanPrayer
add address=192.168.50.237/24 interface=wlan1 network=192.168.50.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=\
bridge-local
add address=192.168.88.0/24 comment="default configuration" dns-server=\
192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=forward comment="default configuration" connection-state=\
established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration" disabled=\
yes out-interface=ether1-gateway to-addresses=0.0.0.0
add distance=1 gateway=192.168.50.1
/system clock
set time-zone-name=America/Chicago
/system identity
set name="Lower Level Hall Under Sanctuary"
/system leds
set 0 interface=wlan1
/system ntp client
set enabled=yes mode=unicast primary-ntp=129.6.15.28 secondary-ntp=\
128.138.141.172
Users browsing this forum: Bing [Bot], pieterp and 23 guests
