MUM Europe 2020
scampbell
Trainer
Trainer
CAPSMAN Interface Naming
Thu Oct 09, 2014 9:52 am
We are now using CapsMan for many sites but one thing appears to be missing - hopefully we have not missed it ?
Is it possible to incorporate the "/system identity" as a prefix when the interfaces are auto-provisioned ?
You can certainly specify a manual "Name Prefix" but I've not seen the ability to add the routers actual identity other than manually going through and matching mac addresses to system identity.
A script could do it but it would be a nice if it we a standard option ? Any input welcome :-)
uldis
Re: CAPSMAN Interface Naming
Fri Oct 10, 2014 6:31 pm
we will try to make this feature future releases of the RouterOS.
scampbell
Trainer
Trainer
Mon Oct 13, 2014 1:26 am
:D I look forward to this - thank you !!
BrianHiggins
Long time Member
Long time Member
Mon Oct 13, 2014 6:04 pm
an option to auto add a comment to the interface with the remote Identity name would be a nice way of handling it.
-Brian
http://www.aditumims.com
Complete web based ISP in-a-box solution, designed specifically for Multi-Tenant properties, works great for WISPs too.
uldis
Tue Oct 14, 2014 1:56 pm
BrianHiggins, this will not be needed as you will be able to specify an option to use system identity in the configuration when creating a interface name.
Users browsing this forum: Zupp and 42 guests
