dbdom
User Manager Crash after 6.19 to 6.20
Fri Oct 17, 2014 6:56 pm
After upgrade 6.19 to 6.20 on x86 my user-manager database "disappered". Can't login to userman via web, etc (now is over 20 min after restart). When I try to restore database I've got
> tool user-ma data load
Restore user-manager database? [y/N]:
y
Loading user-manager database backup
Failed to load user-manager database backup
failed to open file for writing: No such file or directory
>tool user-ma data pri
database is not acceseble, yet
I've also removed and reinstalled userman package.
Any idea how to reinstall userman? It may be with empty database.
Stillhard
Re: User Manager Crash after 6.19 to 6.20
Sun Oct 19, 2014 5:56 am
First check the db-path
ros code
/tool user-manager database print
If not exist
ros code
/tool user-manager database set db-path=/user-manager1
rebuild - downgrade to 6.19 - check if the database ok - re-upgrade to 6.20
mahnet
Long time Member
Long time Member
Sun Oct 19, 2014 12:30 pm
same thing happened with me and these guys say to restore the backup. but it says no backup file found even though the backup exists. i tried downgrade and restore but nothing happened.
Mikrotik always comes up with a new set of bugs and they even said that they are not focusing on any development wrt the user manager.
The only way to get user-manager working is to system reset ur x86
dbdom
Sun Oct 19, 2014 10:42 pm
Stillhard -> thanks a lot ! It helps. I didn't know "set db-path=" option. After "set db-path=user-manager1" the "user-manager1.old" directory appered in "Files ". So I set db-path this .old dir, rebuilt db (because it did not show old session and something else) and now I have my old database fully accessible!
Stillhard
Mon Oct 20, 2014 5:24 pm
You're welcome :D i know, i just cheated their undocumented document(s) :lol:
Users browsing this forum: Bing [Bot], prus, sambo521, sindy, spr41178 and 171 guests
