gnulab
Winbox: could not create file
Tue Oct 21, 2014 10:51 am
I tried logging into Mikrotik via Winbox v3.0b3. It gives me error message ERROR: Could not create file.
I've tried running it as Administrator and it still comes out with that error message.
I've tried googling for this problem, no answer comes up. What is missing?
Thank you
Henry
emil31
Re: Winbox: could not create file
Thu Apr 09, 2015 3:31 pm
I have the same error with winbox 3.0beta3 and 3.0rc6, the version of routeuros is 5.25.
Thank You.
jarda
Tue Apr 14, 2015 8:03 am
Use winbox 2.x instead of the unstable v. 3
brainz
Sun Aug 30, 2015 11:02 pm
Since you try running as administrator and your OS still stops winbox from creating file then I guess you have install another OS
normis
Mon Aug 31, 2015 11:23 am
don't use BETA
use RC which is much better
This one http://download2.mikrotik.com/routeros/ ... winbox.exe
mirbo
Fri Jun 03, 2016 10:08 am
any body can solve this issue .???
i have this issue , please help me .
normis
Fri Jun 03, 2016 11:55 am
This topic is pretty old. What kind of issue do you have and what Winbox version are you using ?
mirbo
Fri Jun 03, 2016 3:02 pm
i resolve it
i have Kasper end point
and i stop this service and i can connect to router board
fbenavides
Mon May 15, 2017 10:37 pm
Every time happen this problem i have to reinstall all the SO of my windows OS
I check with all the version of winbox 3.X
can you tell me how can i resolve this..?
amelec2
Fri Dec 15, 2017 5:04 am
I could resolve the problem executing winbox.exe as administrator.
:D
WirtelPL
Tue Jan 23, 2018 8:58 pm
Check your antivirus settings -> ransomware protection. Maybe it blocks access to folders when WinBox create files.
WinBox must have access to folder:
c:\users\USERNAME\appdata\roaming\mikrotik\winbox\6.41-3395350936
(WinBox: 3.11, ROS: 6.41 current)
RB951G-2HnD for home production
RBmAP2nD | RB952Ui-5ac2nD-TC for home lab
STEPHANVS
Fri Mar 16, 2018 10:27 am
Had this problem today. My windows profile was once corrupt, and was located to C:\Users\TEMP. Though I solved the issue back then, this setting was still present today in several registry entries.
Winbox tried to access c:\users\TEMP\appdata\roaming\mikrotik\winbox unsuccessfully. Once the registry entries were fixed, Winbox was able to save the current configuration to the proper profile folder without admin rights.
lindend
Fri Jun 15, 2018 7:08 pm
Just ran into this problem. After an Win 10 update, I got some profile errors logging in. Rebooted and everything was restored to normal except Winbox complains that it can't create a file.
If I run as an administrator, the program works. I'd rather not have to run as an admin. Do you remember what registry keys needed to be updated? I searched the registry and couldn't find any appdata registry related errors.
Also, is there any way to complete reset Winbox so its settings are cleared?
Stream
Sat Jul 14, 2018 11:28 am
Hello. Winbox 3.16 create session files inside "C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\Mikrotik\Winbox".
In my case, after happened user profile corruption, MS Windows removed "C:\Windows\System32\config\systemprofile\Desktop" directory.
I just created Desktop folder and setup full access permission for me and system user.
Users browsing this forum: Cheese, eworm, gemesif, Google [Bot], spr41178 and 70 guests
