veaglem
2 Wan fail-tolerance configuration!
Mon Oct 27, 2014 5:12 pm
Hello I'm beginner and need some info.
I have a RouterOS machine with two WAN and one LAN interfaces. I want to provide fail tolerance to my LAN clients. How can I do this?
Thank you in advance.
flipk12
Re: 2 Wan fail-tolerance configuration!
Tue Oct 28, 2014 9:46 am
gabrielpike
Tue Oct 28, 2014 5:13 pm
If you are trying to do an easy failover then all you need to specify are 2 default gateways. The second with a higher distance than the first.
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=WAN1IPaddress
add check-gateway=ping distance=10 dst-address=0.0.0.0/0 gateway=WAN2IPaddress
Gabriel Pike
MTCNA
Users browsing this forum: No registered users and 46 guests
