jetsystems
User led on 532?
Thu Jun 15, 2006 12:27 am
I have small trouble:
RB532 can't start, serial console don't running, power led and user led are lightning....
Where can be problem?
Thank for your help
VicNet
Mon Jun 19, 2006 5:32 pm
We have same problem.
We have RB 532A with ..23 version of RouterOS
After another hard reset problem disappear.
We are afraid to do remote upgrade. Because after that we usualy must go to base and make power reset.
sergejs
Mon Jun 19, 2006 6:38 pm
jetsystems, Try to access router via MAC-Winbox,
http://wiki.mikrotik.com/wiki/First_time_startup
VicNet
Mon Jun 19, 2006 11:36 pm
There is no contact with board in any way ( winbox mac, win box ip, ssh and other). It seems to hang up. Only another reset take him alive.
sergejs
Thu Jun 22, 2006 8:39 am
which leds are on ?
VicNet
Fri Jun 23, 2006 11:16 am
Power and user led are on. (Blue and red)
sergejs
Fri Jun 23, 2006 11:57 am
If blue and red leds are on all the time, than board looks like RMA.
VicNet
Fri Jun 23, 2006 12:02 pm
What is mean RMA :( .
And why board goes to RMA after reboot command.
sergejs
Fri Jun 23, 2006 12:08 pm
Blue and red leds are on for a moment after reboot, than only blue led is on.
Is your board red and blue leds on for all the time on only for the moment ?
VicNet
Fri Jun 23, 2006 12:31 pm
I now that.
But leds are on for all the time, router don't answer.
Only another power reset ( unplug and plug again power line ) take him back alive.
sergejs
Mon Jun 26, 2006 1:17 pm
VicNet
Does the router work after this reset ?
what console output you get ?
Are you able to reisntall router with netinstall ?
VicNet
Mon Jun 26, 2006 2:28 pm
Yes, it work normal after reset.
I don't check it.
I don't try this, it is work well after power reset.
normis
Tue Jun 27, 2006 8:45 am
RMA means Return Material Authorisation, so you have to return it to the vendor. See what warranty you have
sergioc
Red & Blue LED's on and no console output
Thu Oct 26, 2006 2:51 am
We had a similar situation where we were integrating a GPS unit and were plugging in the GPS output to the console port of the RB532. Both the Red and Blue LED's would stay lit and we were unable to log into the Router while this console cable was plugged in. It turned out that the GPS module was outputing information to the console port causing the Router to go into the BIOS set up. We resolved this by going into the BIOS set up and changing the keystoke required to access the BIOS while booting. We changed it from "any key" to "delete" key. Now when the Router boots up, it ignores all the GPS output to the console port and allows the Router to boot up.
