emeralddata
reboot the router when PPPoE blinks
Thu Nov 06, 2014 5:04 pm
So my ISP seems to drop/reset the PPPoE connection about once a week for just a few moments. Whenever this happens, the router cannot seem to renegotiate IPSec for some reason. I am thinking something with a kernel route gets messed up, don't really know.
What is the method to add a script to the Mikrotik to cause the unit to reboot once it detects the PPPoE connection going down/back up?
marioclep
Trainer
Trainer
Re: reboot the router when PPPoE blinks
Sun Nov 09, 2014 4:50 pm
Try using tool > traffic monitor. You could add a script that reboots your router if traffic to pppoe-out is 0kbps...
Ing. Mario D. Clep
CTO - MKE Solutions
MikroTik Certified Trainer
plisken
Mon Nov 10, 2014 1:59 pm
The question is how to do this.
Any idee?
ronix
Mon Nov 10, 2014 5:29 pm
this will help:
http://wiki.mikrotik.com/wiki/Manual:To ... ic_Monitor
also you can use Netwatch ( you can ping Google DNS 8.8.8.8 or the ISP DNS...etc):
http://wiki.mikrotik.com/wiki/Netwatch
Users browsing this forum: No registered users and 22 guests
