Azendale
How do I know what fiber a Mikrotik SFP will work with?
Mon Nov 10, 2014 6:24 am
I have some orange and some aqua fiber. From what I've read, the aqua should be able to do 1.25G and 10G. The orange, I'm not so sure. (It's an already installed senario that I've inherited). So, how do I know if an SFP is for 50 or 62.5 core fiber?
Thalid
Re: How do I know what fiber a Mikrotik SFP will work with?
Mon Nov 10, 2014 7:15 am
First you have to know if you have multi ore single mode. orange is normaly multi.
50 vs 62.5 have whit core diameter on the cable and the speed.
For 850-nm Gigabit Ethernet, these bandwidth values support link lengths of 220 meters over 62.5-micron fiber and 550 meters over 50-micron fiber
http://www.cablinginstall.com/articles/ ... etter.html
CelticComms
Mon Nov 10, 2014 7:19 am
What distances are you considering and are you talking about patch cables or premises fibre?
Interlynx | Networking and Information Security Consultants & Trainers | Email: routerlynx@gmail.com
BGP | EIGRP | OSPF | MPLS | Firewall | VPN | IPsec | Multicast | QOS | IPv4/6 | STP | VLAN | PON | AE | M2M | and more!
Azendale
Mon Nov 10, 2014 5:50 pm
I know it's not single mode. I was able to talk to one the of the people there when it was set up, and he says it's 62.5.
The thing I'm not sure of is how to know what the various SFP's mikrotik makes are able to be connected to. I imagine if I connect a 50um cable to a 62.5 SFP (or vice versa) that it will either not work, or it will have poor performance.
Thalid
Mon Nov 10, 2014 6:17 pm
not 100% shure about this but i was told just hours ago that SFP is the same unit for both 50 and 62.5 micron but need to use the same patch cable type as the fiber itself.
We just changeing a cable at work and this was what my colleague told the custumers It guy.
Petzl
Tue Nov 11, 2014 12:59 am
Most common types :
Orange OM1 62.5 micron multimode mostly BNC type connector (ST)
Orange OM2 50 micron multimode
Light blue OM3 50 micron multimode (laser optimised)
You need a multimode fiber SFP (mostly 550meter, some up to 2km)
Multimode mostly uses grey connectors
Yellow blue connectors single mode 9 micron
Yellow green connectors single mode 9 micron (angled connector)
You need a single mode SFP (10 or 20 km or more version)
Best is to not mix fiber types (microns)
The most common patch panel plug is a SC connector, in order to connect a SFP module you need a SC - LC cable
jkarras
Wed Nov 12, 2014 4:53 am
If you read the text on the side of the fiber jumper and/or cable it should mention what micron it is and possibly even if its OM3 or OM4. OM1 and OM2 typically don't say. If its infrastructure cable it may have a manufacturer and model number that can be looked up.
For patch cords as has been mentioned earlier the color code is typically thus.:
Orange with 6.25um printed on fiber would be OM1 MM
Orange with 50um printer on fiber will likely be OM2 MM
Aqua is typically OM3 or OM4 50um MM.
Yellow is typically single-mode
Don't worry too much about mixing OM3 and OM4 jumpers. Mixing 6.25 with 50um fiber will cause signal loss and should be avoided. All sizes of MM fiber can run 10G its just a matter of what distance you are planning on running that 10G link at.
luiskrdenas
Tue Mar 15, 2016 10:59 pm
This is a great guide for identifying kinds of multimode cables by the ISO/IEC 11801 standard:
Multimode fibers are described by their core and cladding diameter, which usually is 50/125 µm and 62.5/125 µm. OM1, OM2 and OM3 performance criteria is determined by ISO 11801 standard, while OM4’s standard was approved by TIA/EIA 492AAAD, this means each OM has a minimum Modal Bandwidth requirement.
https://beyondtech.us/blogs/beyond-blog ... -om4-fiber
Usually Orange is OM1, OM2:
OM3 and OM4 comes is AQUA:
https://cdn.shopify.com/s/files/1/0855/ ... grande.jpg
Good Luck!
Users browsing this forum: eworm, redroom, sindy, Znevna and 83 guests
