mmgareth
LEDs on cAP-2n board
Wed Nov 12, 2014 2:27 pm
Is it possible to disable the LEDs the cAP-2n ceiling access point?
I know they aren't particularly bright, but for some rooms (such as bedrooms) it would be preferable if they could be turned off.
normis
Re: LEDs on cAP-2n board
Wed Nov 12, 2014 2:53 pm
yes, all of the leds in this device can be turned off, including power
mmgareth
Wed Nov 12, 2014 3:39 pm
I cannot figure out how to do this in WinBox (v3.0beta3) on cAP-2n v6.20.
In 'System > LEDs' there are no LEDs listed. I've added all six (1 to 5, and 'user-led' ) and tried set them to type 'ap cap' - and tried with them enabled and disabled.
Can you share the commands needed to disable them?
mmgareth
Tue Nov 25, 2014 10:45 am
Still haven't been able to figure this out :(
On UniFi AP kit its a simple change in system settings.
Can anyone (especially MikroTik spport!) provide the commands?
CR24
Fri Feb 20, 2015 8:20 pm
I would like to know how to disable the Power LED as well. I was able to disable every LED except the Power.
normis
Mon Feb 23, 2015 10:06 am
you can do it with this command:
/system leds add led=all-leds type=off
