markom
MRTG dynamic PPPoE or PPTP interface
Sun Nov 16, 2014 2:18 pm
My Mikrotik is PPoE and PPtP concentrator. Is there any way to MRTG pppoe interface constantly.
The problem is, when some customer restart router (client side) PPPoE get different OID and MRTG stop working.
kgninfos
Re: MRTG dynamic PPPoE or PPTP interface
Thu Feb 19, 2015 11:21 am
i have been also asking the same question
and seems mikrotik is not going to answer it
magnavox
Thu Oct 08, 2015 10:16 am
Helo, a solution is described in this post http://forum.mikrotik.com/viewtopic.php ... &t=43#p188
We are some issue:
- interface-number (or OID) change every user connection
- using cfgmaker whit option
-ifref=nr -ifdescr=name
MRTG work fine and create graphs... but after user reconnection, MRTG loose history because MRTG use interface-name in .html e .log file... and don't match...
-ifref=name, -ifdescr=name
MRTG/SNMP seem not able to read data; I suppose the problem is name of PPPoE interfaces, like <pppoe-user0002>...
A solution can be modifiy cfgmaker (when using option -ifref=nr ifdescr=name) to use interface-name (like <pppoe-user0002>) as namefile of .html and .log file where MRTG store data and interface-number for target (readed by SNMP). So after user disconnect/connect MRTG will store data always in a file named like <pppoe-user0002>.log
cfgmaker -ifref=nr -ifdescr=name
need to retur for target line a code like:
Target[router_<pppoe-user0002>]: 15744109:public@router:
instead of:
Target[router_15744109]: 15744109:public@router:
Someone can help me? :)
Sorry for m poor english...
Best Regards...
soamz
Sat Jul 23, 2016 7:32 pm
Anu succeess yet ?
I need it asap!!!
pe1chl
Sat Jul 23, 2016 7:38 pm
Should not be a problem with the proper MRTG configuration!
Is not a MikroTik issue, it is about knowing how to configure and use MRTG.
I have used MRTG with many different devices and this issue always occurs.  You need to find and use the proper interface reference.
soamz
Sat Jul 23, 2016 7:42 pm
Have you done it ?
can you share some images ?
How will MRTG know you connected 3 new customers today and you want to see their graph as well ?
pe1chl
Sat Jul 23, 2016 11:38 pm
I have not done this for that particular application but I faced the same issue in other cases.
Of course you need to write a program/script that adds MRTG config for every new interface (customer in your case).
But that is quite easy as it is only the addition of a fixed section with simple parameter substitution (the name).
soamz
Sun Jul 24, 2016 1:49 am
Your email address please.
lambert
Long time Member
Long time Member
Tue Aug 30, 2016 8:10 am
I'm working on this today....
Target[username]: \<pppoe-username\@udomain.net>:community@router.domain.net
seems to work.
magnavox
Tue Aug 30, 2016 12:15 pm
seems to work.
Are you sure?
Can you post a real example?
Best Regards...
soamz
Tue Aug 30, 2016 1:08 pm
Logout and login again. And see.
I doubt.
And screenshots upload please.
magnavox
Tue Aug 30, 2016 1:20 pm
Seems to work:
#Target[username]: \<pppoe-username\@udomain.net>:community@router.domain.net
Target[t000287]: \<pppoe-t000287\@xxxxxx.yy>:community@xxx.yyy.zzz.kkk::5::2:2
Best Regards...
soamz
Tue Aug 30, 2016 1:24 pm
screenshots please.
magnavox
Tue Aug 30, 2016 1:29 pm
screenshots please.
Sorry, I just tried for test and deleted.
I m using other way to generate .cfg because customers can login into multiple PPPoE server,
so a script perform a query from RADIUS and generate .cfg file for "current connected" users for each NAS.
If you have only a NAS or customers are locked to a NAS, use this.
Try, its work.
Best Regards...
docmarius
Tue Aug 30, 2016 8:29 pm
In mrtg config, you can use interface names instead of interface numbers.
e.g. instead of something like
Target[host_2]: 2:public@192.168.1.1:
one could use the interface name prefixed by #:
Target[host_2]: #eth0:public@192.168.1.1:
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
kgninfos
Fri Apr 13, 2018 1:45 pm
can anyone post a sample mrtg config for the PPPoE or PPTP interface
docmarius
Sat Apr 14, 2018 3:57 pm
Adapt fields to yout needs... Interface name (ppoe_interface in the example), IP's(interface is assumed on 192.168.1.1), speeds.
localhost_11 is just a label and needs to be unique in the config.
Target[localhost_11]: #pppoe_interface:public@192.168.1.1:
SetEnv[localhost_11]: MRTG_INT_IP="192.168.1.1" MRTG_INT_DESCR="PPPoE"
MaxBytes[localhost_11]: 125000000
Title[localhost_11]: Traffic Analysis for PPPoE Interface
PageTop[localhost_11]: <h1>Traffic Analysis for PPPoE Interface</h1>
		<div id="sysdetails">
			<table>
				<tr>
					<td>System:</td>
					<td>Router</td>
				</tr>
				<tr>
					<td>Maintainer:</td>
					<td>Admin &lt;admin@localhost&gt;</td>
				</tr>
				<tr>
					<td>Description:</td>
					<td>PPPoE Interface </td>
				</tr>
				<tr>
					<td>ifType:</td>
					<td>pppoe</td>
				</tr>
				<tr>
					<td>ifName:</td>
					<td>pppoe_interface</td>
				</tr>
				<tr>
					<td>Max Speed:</td>
					<td>125.0 Mbytes/s</td>
				</tr>
				<tr>
					<td>Ip:</td>
					<td>192.168.1.1</td>
				</tr>
			</table>
		</div>
kgninfos
Sat Apr 14, 2018 4:10 pm
ok i was able to get the value
but is a non existent interface is there in config it takes a long time before exiting the check
any solution for that??
docmarius
Sat Apr 14, 2018 9:25 pm
If you use the interface number, that's faster. But then this number changes if the interface goes down and up again, depending on the system.
If it stays the same, you can use something like 3:public@192.168.1.1: (you need to find it via a snmp walk...)
kgninfos
Sun Apr 15, 2018 6:49 am
What i want is to graph all available interface at once including dynamic one by name.
Some wildcard kind of thing like #ether-*:public@192.168.1.1: is it possible ??
pe1chl
Sun Apr 15, 2018 10:56 am
It is not useful to graph dynamic interfaces this way because they will be in use by different customers at different times.
You will need to do something that makes it possible to identify them, maybe rename the interface in the up-script (don't know if that is possible)
karlos1973
Tue May 29, 2018 3:36 pm
cfgmaker --ifref=name --ifdesc=name --use-16bit '--if-filter=$if_is_dialup' --noreversedns --snmp-options :::::2 --global "WorkDir: /var/www/html" --global "Options[_]: growright, bits " public@192.168.0.1 --output=/root/mrtg.cfg
env LANG=C /usr/bin/mrtg /root/mrtg.cfg
indexmaker /root/mrtg.cfg --output=/var/www/html/index.html
This is my code for dinamic PPPoE.
Users browsing this forum: No registered users and 20 guests
