brianlewis
6.16 import stops when there is a duplicate entry
Wed Nov 19, 2014 10:13 pm
A duplicate entry in the import will cause RouterOS to stop and not process further down the list (v6.16)
ie (dshield.rsc below)
/ip firewall address-list
add list=DShield address=122.226.73.131/32 timeout=2h
add list=DShield address=85.13.160.11/32 timeout=2h
add list=DShield address=50.23.113.146/32 timeout=2h
add list=DShield address=122.225.109.212/32 timeout=2h
add list=DShield address=176.31.251.200/32 timeout=2h
add list=DShield address=218.2.0.137/32 timeout=2h
It will import 50.23.113.146 and stop processing the import. Bug in RouterOS?
Using /import file-name=dshield.rsc; to import list
mrz
Re: 6.16 import stops when there is a duplicate entry
Thu Nov 20, 2014 10:08 am
You cannot add the same entry twice, console throws an error and quits.
brianlewis
Thu Nov 20, 2014 5:12 pm
How can we not quite the 'script'? Linux doesn't quit a script. Windows doesn't quite a CMD/BAT file. They both continue to execute the commands. The duplicate entry isn't an error it should just be an informational warning that the entry already exists so RouterOS should be continue execution of the script.
mrz
Fri Nov 21, 2014 4:43 pm
It IS an error
[admin@MikroTik] /ip firewall address-list> add list=test address=1.1.1.1
failure: already have such entry
brianlewis
Sat Nov 22, 2014 6:54 am
We should have the ability to import with continue on failure toggle. And adding a duplicate 'address list' entry should be a warning not an error
rwrocket
Fri Jan 15, 2016 3:09 am
Strongly agree
this is just silly
such a time waster to have to edit all duplicate interface names out of a config file to do a clone backup
Percanta
Wed Feb 10, 2016 12:09 am
also strongly agree , at least it will be nice to know which is the duplicate item.
edit: could do that with verbose=yes
_saik0
Wed Feb 17, 2016 12:50 am
Thank you!
Was also thinking the same - add an option (or make it default) to continue executing/importing the config after an error.
pants6000
Thu Feb 18, 2016 3:23 am
If you pay attention to what line of the config it stopped on, you can continue the import with "import from-line=", just increment the line number that it stopped on by 1.
But something like "continue import on error" would be a nice feature. +1
tomba
Tue May 24, 2016 1:26 am
+1
this option will be helpful when importing large blacklist from different sources and urgently need it
Deantwo
Tue May 24, 2016 3:34 pm
I have yet to see a way to get the error message from an imported script returned to the script doing the import. And simply skipping the one line that failed wouldn't be a good idea, if you have { } cases in the imported script and it fail inside one, you wouldn't want it to attempt to start in the middle of it.
Something along the lines of an option that makes the import function simulate the behavior of copy-pasting into the CLI.
Possibly dump the whole CLI output (and input) into a specified text file.
MikeBooker
Mon Jun 27, 2016 8:25 pm
+100
this option will be very helpful when importing large blacklist from different sources and urgently need it
tomba
Sun Aug 21, 2016 12:44 pm
bump
+1
omega-00
Thu Sep 01, 2016 11:26 am
My recommendation is to build a script that clears all the items you don't need prior to running then adds everything it requires back.
IE: Clear all IP addresses at the start then just add the ones you need.
Something like this can be achieved by using a non-interactive initiation of the script (running as an .auto.rsc)
OR
"system reset, on reset run .. <script name>"
OR
:global cmdfinish
:execute {command that will potentially fail goes here; :set cmdfinish "true";}
loop around a bit waiting for a "true" value otherwise log that the command failed and continue on..
This is a very simple overview so if there's more interest I can supply some better explanations and examples.
BartoszP
Thu Sep 01, 2016 3:11 pm
Could you prepare the script that way
do { /ip firewall address-list add address=111.251.111.129 list=blackmail timeout=3h } on-error={}
instead of
I have no 6.16 so it is only my guess that such solution works.
dadaniel
Thu Sep 29, 2016 12:58 pm
instead of
works like a charm, as a side effect log is not spammed by address list entry messages :)
Thank you very much!
Users browsing this forum: baragoon, BinaryTB, raphaps, rplant and 66 guests
