ahbutler
Unifi Discovery
Tue Dec 02, 2014 4:49 am
Greetings,
I have an RB2011 running 6.19 ROS. Super simple configuration with port 1 being connected to the WAN and port 2-10 connected as a bridge for local ethernet access. NAT masquerade to WAN port. I have several workstations connected to ports 2-8. I have a Ubiquiti UniFi Access point connected to port 9. When I try use the UniFi Discovery
tool to find the AP, it always fails to discover anything. It is using L2 multicast/broadcast for discovery. However, if
I connect the AP and the one workstation with the discovery tool to a generic Netgear switch the discovery tool finds the AP without difficulty. So, is there something I need to do to allow this discovery traffic to transition across the switch?
Thank you,
Aaron
lyberis1979
Re: Unifi Discovery
Tue Dec 02, 2014 9:39 am
Good Morning,
Im using also UBNT as access point in work and home environment, have you tried to remove the controller and re-installing it. The other thing with UBNT is the adopting o network, try to reset the AP then connect it to your Network through an other Lan port on your MK.
Best regards.
gabrielpike
Re: Unifi Discovery
Tue Dec 02, 2014 9:50 pm
My way of doing this is to create a static DNS entry for unifi pointing to my controller IP address. That way when the unifi try to dial home they get pointed to the controller server.
/ip dns static
add address=ControlerIPAddress name=unifi
ryandenis
Re: Unifi Discovery
Tue Dec 09, 2014 4:05 pm
wouldn't it be easier to just option 43 for dhcp options?
gabrielpike
Re: Unifi Discovery
Tue Dec 09, 2014 4:26 pm
Two ways of accomplishing the same thing. I don't know that ease has anything to do with it. Probably just a matter of preference.
jarda
Re: Unifi Discovery
Tue Dec 09, 2014 5:05 pm
Have you set proxy-arp to the bridge? It could help.
ebreyit
Re: Unifi Discovery
Thu Dec 11, 2014 5:43 pm
Which port are you plugging the unifi into on the 2011. I've had problems with a few pieces of equipment (openreach VDSL Modems mostly) which flap on the gigabit ports (1-5) but are solid on the 10/100 ports (6-10).
Also have you tried making ports 2 and 6 masters for 3-5 and 7-10 respectivley, just bridging port 2 and 6, using them as switched..?
