MUM Europe 2020
lcrhea25
Wireless Connection Problem
Tue Dec 02, 2014 10:41 pm
I have a tower with 3 sectors on it. Running channel 1, 6 and 11. I have a few customers whose signals are around -74 to -77. For awhile now they have been dropping lots of pings at times. If I turn off my other 2 sectors the problem appears to go completely away. Every time I sent Mikrotik info about this, even once I sent them some output files I just get told to try and upgrade to the latest version. Right now I am running 6.19 with NV2. TDMA Period size is 2. I haven't seen anything in the change logs for the latest versions that would lead me to believe anything has been done to the wireless. Does anybody have any ideas about what is going on here?
Larry
bleblas
Re: Wireless Connection Problem
Wed Dec 03, 2014 10:17 am
hello
this 3 wireless card is on one routerboard ?
lcrhea25
Thu Dec 04, 2014 4:40 pm
No these are 3 separate boards. One board per sector. Units are in metal cases. To me it is obvious that they are somehow interfering with each other but this used to not be the case and correct me if I am wrong but being on channel 1, 6 and 11 should not be interfering with each other like this.
hgonzale
Thu Dec 04, 2014 4:50 pm
Has you tried the software Insidder to look the frequency usage and channel size?
lcrhea25
Thu Dec 04, 2014 8:58 pm
hgonzale What is it that you are talking about? I'm not sure what you mean.
Bonz123
Thu Dec 04, 2014 9:00 pm
I was the same problem with ch11, after few hours of finding problems, changing configurations etc. just change to 9 and problem disapire!
Try this one!
lcrhea25
Thu Dec 04, 2014 9:13 pm
I am seeing this problem on all 3 units though. Not just the one that is on channel 11.
Bonz123
Fri Dec 05, 2014 11:10 am
For each unit u have same dhcp pool or different?
just try change 11-9 Don't rush with small overlap!
lcrhea25
Fri Dec 05, 2014 5:23 pm
I am not using dhcp. We are doing pppoe. I changed 11 to 9 and I am still seeing the same problem. With one sector on ping times and connection looks good. Turn the other 2 back on it get weak again. I wish someone from Mikrotik would see this and respond. Clearly they are interfering with each other when they shouldn't be.
lcrhea25
Fri Dec 05, 2014 6:17 pm
This spectral scan shows what I am talking about. If you look you can see where I turned off the APs on channel 1 and 11 off and then turned them back on. You can see how far outside the range they are going. And how much of a change there is on channel 6.
lcrhea25
Mon Dec 08, 2014 11:26 pm
Does anybody have an answer for this?
Bonz123
Mon Dec 15, 2014 10:32 pm
Users browsing this forum: Google [Bot] and 34 guests
