spaxton
Routing multiple static address
Wed Dec 03, 2014 11:44 am
Dear all,
I have searched forum before posting this and I have found similar thing but there were nothing to explain how to do next thing:
I have 3 subnets in my mikrotik router and one ISP able to give 3 public addresses via single interface. For ISP I am using one of 3 ethernet ports.
Subnets are 192.168.1.0/24 for wifi
10.100.0.0/24 one group of PCs
10.10.0.0/24 second group of PCs
What I need is to separate public IPs for all 3 subnets. Wifi should go to one and those two subnets to other two. How to do this if public IPs are all in the same interface?
Best Regards!
rmmccann
Re: Routing multiple static address
Wed Dec 03, 2014 4:57 pm
Assign the 3 public IP addresses from your ISP to your MT. From there, create srcnat rules and don't use action=masquerade. Use action=srcnat. Doing this will allow you to specify which public IP should be used for each subnet.
Eg:
add action=src-nat chain=srcnat comment="Subnet 1" out-interface=WAN src-address=192.168.1.0/24 to-addresses=x.x.x.x
add action=src-nat chain=srcnat comment="Subnet 2" out-interface=WAN src-address=10.10.0.0/24 to-addresses=x.x.x.y
add action=src-nat chain=srcnat comment="Subnet 3" out-interface=WAN src-address=10.100.0.0/24 to-addresses=x.x.x.z
The x.x.x IPs are the IPs that would be provided by your ISP.
spaxton
Wed Dec 03, 2014 11:40 pm
Eg:
Thanks, friend! I'll try this.
