karyal
RB532 Kernel panic no init found
Tue Jun 20, 2006 12:26 pm
Hi, i have a boot problem with an rb532:
RouterBOOT booter 1.3
RouterBoard 532
CPU frequency: 266 MHz
  Memory size:  32 MB
Press any key within 1 seconds to enter setup.
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Kernel panic: No init found.  Try passing init= option to kernel.
Searching around i've found what i guess is the answer to solve the problem:
http://www.mikrotik.com/docs/ros/2.9/guide/netinstall
I'm just worried about the license... does it keep it?
Thanks,
Ricky
sergejs
Tue Jun 20, 2006 12:35 pm
Yes, use netinstall license will be kept, leave 'use_the_previous_key' in key window for netinstall.
Users browsing this forum: Baidu [Spider] and 101 guests
