Anirey
How split the variable?
Wed Dec 10, 2014 8:51 am
Hi!
How to split this value ^HCSQ:"LTE",56,47,101,18 ?
I would like to get 5 value by script:
Signal = LTE (maybe WDMA)
RSSI = 56 (the first)
RSSP = 47 (the second)
SINR = 101 (the next)
RSRQ = 18 (only for LTE).
ex.:
^HCSQ:"WDMA",45,147,60
^HCSQ:"LTE",58,39,99,32
Thanks!
skot
Long time Member
Long time Member
Re: How split the variable?
Wed Dec 10, 2014 6:41 pm
You can split the string to get rid of the prefix, and then convert the remaining string into an array.
:local var "^HCSQ:\"LTE\",56,47,101,18"
:local myArray [:toarray [:pick $var ([:find $var ":"]+1) [:len $var]]]
:local signal [:pick $myArray 0]
:put "Signal: $signal"
:local rssi [:pick $myArray 1]
:put "RSSI: $rssi"
etc...
I don't need any karma... I have Ιησους Χριστος!
Anirey
Wed Dec 17, 2014 1:33 pm
Thanks!
It works.
Do you know how to send "Q" using script?
interface ppp-client info ppp-out1 user-command="AT^HCSQ\?"
modem-status: ready
pin-status: no password required
functionality: full
manufacturer: ^HCSQ:"LTE",52,47,156,26
model: E3372
revision: 21.285.01.02.143
serial-number: 864346021423076
current-operator: Beeline (cellid bc4ae05)
access-technology: Evolved 3G (LTE)
signal-strengh: -69 dBm
frame-error-rate: n/a
-- [Q quit|D dump|C-z pause]
skot
Long time Member
Long time Member
Thu Dec 18, 2014 8:48 pm
I don't think you can send Q from a script, but you can tell it to just run once. And from there you can get data. Paste this in the terminal and it should output ^HCSQ:"LTE",52,47,156,26.
:local mf
/interface ppp-client info ppp-out1 user-command="AT^HCSQ\?" once do={
  :set mf $manufacturer
:put $mf
Anirey
Fri Dec 19, 2014 11:03 am
It is the problem =(
[mikatmbank@TEST2] > interface ppp-client info ppp-out1 user-command="AT^HCSQ\?"
works
modem-status:
pin-status:
functionality:
manufacturer:
model:
revision:
serial-number:
current-operator: (cellid )
access-technology:
signal-strengh:
frame-error-rate:
nterface ppp-client info ppp-out1 user-command="AT^HCSQ\?" once do={:delay 10}
modem-status:
pin-status:
functionality:
manufacturer:
model:
revision:
serial-number:
access-technology:
signal-strengh:
frame-error-rate:
doesn't work
skot
Long time Member
Long time Member
Fri Dec 19, 2014 6:05 pm
For the one that works, does it take some time before the information shows up?
Anirey
Fri Dec 19, 2014 9:09 pm
Yes.
But delay doesn't help.
skot
Long time Member
Long time Member
Mon Dec 22, 2014 10:20 pm
You could try just sending the letter, or echoing it with :put, but I doubt either of these will work...
/interface ppp-client info ppp-out1 user-command="AT^HCSQ\?" do={
  :if ([:len $manufacturer] > 0) do={
    :put $manufacturer
    q
    :put $manufacturer
    :put "q"
Anirey
Tue Dec 23, 2014 9:36 am
Thanks for your help!
It works!
My script has name QTY_Signal
  :if ([:len $manufacturer] > 0 ) do={
  :set HCSQ $"manufacturer"
  /system script job remove [find script=QTY_Signal]
Anirey
Tue Dec 23, 2014 10:19 am
Sorry.
Can you hep me yet?
How do this variable add to the content of existing file?
skot
Long time Member
Long time Member
Tue Dec 23, 2014 8:25 pm
It works!
Well done, good solution.
Sorry.
Can you hep me yet?
You can add content to existing file by doing something like this:
:local fileContent [/file get myFile.txt content];
:local manufacturer "^HCSQ:\"LTE\",52,47,156,26"
/file set myFile.txt contents=($fileContent . "\n" . $manufacturer);
Anirey
Wed Dec 24, 2014 9:08 am
Thanks!
maybe, but it generates log message "script error:interrapted"
greek
Thu Jan 12, 2017 2:44 am
It works!
Try this script:
  :quit;
greek
Thu Jan 12, 2017 2:49 am
I use this variant:
/system script
add name=lte owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":local i 0;\
    \n/interface ppp-client info ppp-WAN do={\
    \n:set i (\$i+1);\
    \n:if (\$i=5) do={\
    \n:global lte \$\"access-technology\" ;\
    \n:global signalstrengh \$\"signal-strengh\";\
    \n:global itog (\$lte.\"  \".\$signalstrengh); \
    \n:log warn \$itog;\
    \n:quit;\
    \n}\
    \n}\
    \n\
    \n\
    \n"
greek
Thu Jan 12, 2017 2:55 am
And after reading this topic my final variant:
:if ([:len $"access-technology"] > 0 ) do={
:global lte $"access-technology" ;
:global signalstrengh $"signal-strengh";
:global itog ($lte."  ".$signalstrengh);
:log warn $itog;
:quit;
Users browsing this forum: Baidu [Spider], Google [Bot] and 96 guests
