normis
6.24 released
Mon Dec 29, 2014 10:27 am
What's new in 6.24 (2014-Dec-23 13:38):
*) ntp - fixed vulnerabilities;
*) web proxy - fix problem when dscp was not set when ipv6 was enabled;
*) fixed problem where some of ethernet cards do not work on x86;
*) improved CCR ethernet driver (less dropped packets);
*) improved queue tree parent=global performance (especially on SMP systems and CCRs);
*) eoip/eoipv6/gre/gre6/ipip/ipipv6/6to4 tunnels have improved per core balancing on CCRs;
*) fixed tx for 6to4 tunnels with unspecified dst address;
*) fixed vrrp - could sometimes not work properly because of advertising bad set of ip addresses;
http://www.mikrotik.com/download
or from your router via "check for updates"
honzam
Re: 6.24 released
Mon Dec 29, 2014 10:48 am
All problems reported there are fixed?
http://forum.mikrotik.com/viewtopic.php ... 80#p461826
LAN, FTTx, Wireless. ISP operator
normis
Re: 6.24 released
Mon Dec 29, 2014 11:23 am
version was released before those posts because we needed to rush the important NTP fix. v6.24 is from December 23.
honzam
Re: 6.24 released
Mon Dec 29, 2014 11:43 am
Ok. It looks like a lot of things you need to fix in 6.25
rpingar
Long time Member
Long time Member
Re: 6.24 released
Mon Dec 29, 2014 6:21 pm
any update about [Ticket#2014122366000393]
not balancing aver the cores about PPPoE and VPLS when vpls ends on the same box as pppoe concentrator.
jarda
Re: 6.24 released
Mon Dec 29, 2014 7:29 pm
Do the USB disks work correctly finally with this version? At least?
skibi82
Re: 6.24 released
Mon Dec 29, 2014 8:15 pm
After updating to 6.24 lost Hlink LTE interface.
Please, quick repair error.
This is not normal that after every update you must be wondering what mikrotik support screw up in firmware.
The same as described in [Ticket#2014122966000702] RE: To put it mildly WTF [...]
At the moment, 20 branches work on LTE connections fortunately did before updating a single test. As always shit came out.
I have nothing more to what to write. Repent Mikrotik Support
jp
Long time Member
Long time Member
Re: 6.24 released
Mon Dec 29, 2014 9:42 pm
How important is the NTP security update as it pertains to RouterOS?
http://support.ntp.org/bin/view/Main/SecurityNotice says three of the issues are crypto related, and one is a normal nasty buffer overflow. I'm guessing the crypto ones don't apply to normal RouterOS, but the buffer overflow could have bad potential?
I don't like to upgrade RouterOS immediately after a new version comes out....
steen
Re: 6.24 released
Tue Dec 30, 2014 1:06 am
l2tp does not work using rb2011uas, it dies after 32kb of data transferred, it has been broken since 6.23 possible more early, discovered today after an incident that costed one company whole day outage
jarda
Re: 6.24 released
Tue Dec 30, 2014 8:48 am
Never update ros until both conditions are met:
1. You absolutely must do it.
2. You made very exhausting testing.
If you decide to update, start with the less important devices and observe their behaviour at least for one week. Then you should know if you will proceed to intermediate important devices. Observe them for at least two additional weeks. Wait one more week and read the forum about the reported bugs. Then make the final decision about updating the core devices.
Remember. You have decided to update. It is your fault if it went bad.
zyzelis
Re: 6.24 released
Tue Dec 30, 2014 11:21 am
Hello guys,
This morning i had (due to ntp vulnerability and TX errors) to upgrade CCR-1036-4s from 6.19(stable for me) to 6.24.
The roles: few vlans, dhcp, dns servers, nat. few firewall rules, queues. So far so good.
PS. No tx errors and drops
WirelessRudy
Re: 6.24 released
Tue Dec 30, 2014 1:02 pm
Is the site down? I can't reach it, nor the main webpage.....
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
honzam
Re: 6.24 released
Tue Dec 30, 2014 1:59 pm
Same problem
Chupaka
Re: 6.24 released
Tue Dec 30, 2014 2:26 pm
fixed =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Cha0s
Re: 6.24 released
Tue Dec 30, 2014 4:11 pm
VRRP doesn't look fixed.
It still sends out packets with wrong source addresses.
jarda
Re: 6.24 released
Tue Dec 30, 2014 5:44 pm
Seems like all responses to dude probes are much faster with 6.24 comparing to 6.23. Tested on RB750 and RB133 so far.
Is this due to some undocumented change? Or what causes this behavior?
Memory consumption is again higher a bit. This is not good. Can you do something with memory consumption in future releases?
steen
Re: 6.24 released
Tue Dec 30, 2014 6:21 pm
Problem solved! It was some MTU/MRU values which had to be reduced.
Majklik
Re: 6.24 released
Tue Dec 30, 2014 7:00 pm
For which version/configuration? It looks that ROS sometimes incorrectly report problem, but packets looks OK. At least for VRRPv3/IPv6. The packet have coorect source MAC address of the virtual VRRP MAC and source IPv6 address is link local address of the Ethernet/bridge/vlan interface.
Too for VRRPv2 with AH authorization is very often signalized "received packet from 192.168.1.1 AH authentication failed", but all works OK.
There is one new bug related to the VRRP. If the IPv4/IPv6 addressess of the VRRP interface on both routers is not the same then both routers became master and this is not correct (older ROS do not have this problem).
Configuration like:
R1:
/interface vrrp
add interface=ether1 name=vrrp1 priority=101 version=2 vrid=100
add interface=ether1 name=vrrp2 priority=101 v3-protocol=ipv6 vrid=106
add address=192.168.1.1/24 interface=ether1
add address=192.168.1.100/32 interface=vrrp1
/ipv6 address
add address=2001:db8:107::1 advertise=no interface=vrrp2
R2:
/interface vrrp
add interface=ether1 name=vrrp2 priority=100 v3-protocol=ipv6 vrid=106
add address=192.168.1.2/24 interface=ether1
add address=192.168.1.200/32 interface=vrrp1
/ipv6 address
add address=2001:db8:108::1 advertise=no interface=vrrp2
Both vrrp interface on both routers become master which is not correct. They can report misconfigured IPs but not became both masters.
bryans2k
Re: 6.24 released
Tue Dec 30, 2014 8:57 pm
VRRP doesn't work correctly on Bridged interfaces, on every reboot each router tries to become master even though preemption mode is disabled.
JorgeAmaral
Trainer
Trainer
Re: 6.24 released
Wed Dec 31, 2014 12:56 am
Marvelous description, I could not agree more.
Anyone that describes him has an sys admin must, for the sake of his job, follow these rules religiously.
Thank you Jarda for an excellent "rule of thumb".
WirelessRudy
Re: 6.24 released
Wed Dec 31, 2014 1:34 am
1). Following this procedure and the speed of new releases makes you run behind about 6 versions, and running up! :lol:
2). And in the mean time you can never report any problems/issues any more to support. Because their first reply will be the request to update to last version. Otherwise they cannot help you.....
My policy is more:
1). Wait a couple of days and monitor the forum.
2). Start updating new units that are prepared for 1st usage.
3). Start updating lesser important versions that are easy to reach in case of failure.
4). Only start really important units if you really need the version, or are 95% sure you have no problem.
After all, some problems only come up after mass instalments on your routers. If you wait until all issues are evaporated from the forum topics you probably would still be using version 3.x
Sometime you just need to hit the wall to find out something is done wrong. Its not always the software. Sometimes just ill config that pop up during new installs.
I am surprised by the amount of little errors that popped up at times after upgrade sequences that in fact had nothing to do with the new version. Only by looking and updating sometimes errors submerged. (Now you can argue that it was therefore poor config from admins side, but hey, let the first one working 100% error free trow the first stone....... :shock:
Rudy R. Puister
JorgeAmaral
Trainer
Trainer
Re: 6.24 released
Wed Dec 31, 2014 2:20 am
My policy is more:
What is the problem of running an older version if it fits your needs?
I really don't get the point of updating router sw every single month. It´s a router, not a server...
By the way, I have routers running v3.30 and they have +900 days uptime and I don't even think about upgrading them. Do you know why? Because since the beginning that have been setup they full fill all the requirements.
Do you know the rule of 6dB? ( In audio, in radio signal, etc ) Apply the same rule (jump 4 versions) if you really need some new stuff from latest versions.
Debug with Mikrotik is fairly easy, update that specific router to the latest version and provide them remote access. But that does not mean upgrade the entire network...
If you really need some of the new fresh fancy features for your daily job, probably you will fail your target.
Do you know the "Pareto principle" ?
Adjust "Pareto Principle" to RouterOS and you will have a peacefully life :-)
This is just my two cents
antsh
Re: 6.24 released
Wed Dec 31, 2014 7:51 am
The no-mark parameter for queue trees is not working for me. Reboots router as well when trying to change the parameter. Please fix if possible!
jarda
Re: 6.24 released
Wed Dec 31, 2014 8:52 am
Whatever procedure with testing in lab first and then implementing by waves into network is better than blind updating and then screaming that one day was lost and customers are angry at me.
I install the new versions immediately when they are released on my lab devices first to make the test of things essential for my networks. Of course I am reporting errors if I find them. I have few opened tickets that still seem not to be solved. Even 6.18 is not enough good for me, but there is no more recent version I can use so far. 6.19, 6.21 and 6.23 was partly implemented in my networks but after few days I always rolled back.
I need working networks and my intention is not to leave them as testing environment for try-error development process.
I am big mikrotik fan. I play with networking as it is more my hobby than business, because I am SAP consultant. I also do the SAP software customer developments and I can tell you, if I did my job in the way like I see that mikrotik does, I would be without job and homeless. And those who know SAP a bit will agree with me that it is not such simple system like RouterOS is.
ste
Re: 6.24 released
Wed Dec 31, 2014 10:12 am
I am a MT fan too. But since 6.x they make only steps backward. We do no updates for a long time now. With new wireless installs we use cambium epmps with new ethernet installs we use foreign rugged switches and for backhauling we replace mt with licensed gear. We have to go forward with reliability and speed. This is not possible with MT at the moment.
Muqatil
Trainer
Trainer
Re: 6.24 released
Wed Dec 31, 2014 11:10 am
You know what?
I've no problems at all on ROS updates..
When i deploy a new router, i just run Packages update and everything works...
Sometimes i upgrade ROS in productional enviorment and i had some little issues back in 6.10 IIRC with some CCRs. Downgraded and waited for a new version to come out. Now they run 6.22.
But i agree that Mikrotik support is pretty useless when you report an issue:
"Upgrade to last version again and try this and that"
Suuure, i'm not upgrading a productional router for test sake for you. You have my supout, test it and fix!
Renato Bernardi
skype: medtech5
ste
Re: 6.24 released
Wed Dec 31, 2014 12:23 pm
You know what?
We see different problems which persist:
Nstreme is instable, nv2 has issues with tcp speed over multiple hops and does not work well with .ac. Ethernet ports tend to show autoneg problems. Sometimes some routers go down to 10Mbit. Reboot helps. Sometimes an update just rendered a device dead. We had different smaller hickups. In sum it is to much luck needed to make an install and everything works. We want devices to plug in and just work. We found switches who work exactly that way and we use SAF Integras. If there is a problem and I do not get the calculated Bandwidth I am sure I have caused it. With MT I get a mix of my Problems and Vendor problems. On the wireless side I see MT is not interested to fulfill regulatory requirements. There is still no ATPC and I am sure there are other parameters like spurios emmissions which will not stand a test. Now there are new ETSI Rules which e.g. need LBT implemented in some bands.
zlatkomajstor
NTP Client not working on CCR1036-12G-4S and on RB1000 v6.24
Fri Jan 02, 2015 12:14 pm
All packages installed and enabled(except wireless). NTP Client does not synchronize.
noyo
Re: 6.24 released
Fri Jan 02, 2015 12:19 pm
@normis Is the team Mikrotik working on the stability of AC? When can we expect a revolution?
server8
Re: 6.24 released
Fri Jan 02, 2015 4:35 pm
+1
mars
Re: 6.24 released
Fri Jan 02, 2015 6:54 pm
yes when wil it work properly
steen
Re: 6.24 released
Sat Jan 03, 2015 10:31 am
Hello Folks!
Whole network is updated to RoS6.24, after past workweek no visible problems.
However vrrp show some strange problems, it reports back that there was an authentication problem. Anyhow we did not yet take vrrp in production. It seems like it works anyway, we pinged device vrrp ip address and swith off one router, ping continued and worked after failover and failback.
Lakis
Forum Veteran
Forum Veteran
Re: 6.24 released
Sat Jan 03, 2015 3:40 pm
Does wireless-6.24.npk = wireless-fp-6.24-.npk (except add ons like CAPS Man and AC support) or in wireless-fp-6.24.npk there are much more changes like in nv2 and etc?
If we dont need CAPS-man or we dont use AC equipment which packed u prefer to use?
TikUser
Re: 6.24 released
Sun Jan 04, 2015 1:49 am
No, wireless package is NOT equal to wireless-fp package.
http://forum.mikrotik.com/viewtopic.php?t=88510#p444384
http://forum.mikrotik.com/viewtopic.php ... 98#p422522
http://wiki.mikrotik.com/wiki/Manual:Fast_Path
http://download2.mikrotik.com/news/mikr ... UN2014.pdf , page 4
In order to work properly, wireless-fp must be implemented on the ap and on the client side.
http://forum.mikrotik.com/viewtopic.php ... 87#p432494
Use wireless-fp.
http://forum.mikrotik.com/viewtopic.php?t=91828#p458910
And other info:
Link 1
Link 2
normis
Re: 6.24 released
Mon Jan 05, 2015 9:13 am
Hello noyo and mars, Do you have some issues with 802.11ac? Have you posted about them or emailed MikroTik?
noyo
Re: 6.24 released
Mon Jan 05, 2015 9:23 am
Yes, I have connectivity that works well in N (2x mANT30 & NetBox5 AC). I changed to AC and the connection is unstable. CCQ jumps up / down. Speed, ping up / down.
I have not written an email. I decided that it is still being developed.
normis
Re: 6.24 released
Mon Jan 05, 2015 9:25 am
We are not aware of any 802.11ac problems, it is not "still being developed". Most people have no problems. Please write to support about the CCQ issue that you have, maybe it can be solved with configuration changes
noyo
Re: 6.24 released
Mon Jan 05, 2015 9:32 am
Is the file supout.rif enough? Is accompanied by screenshots with the scan, freq. usage?
normis
Re: 6.24 released
Mon Jan 05, 2015 9:35 am
good for starters
noyo
Re: 6.24 released
Mon Jan 05, 2015 10:43 am
I saw the "freq. Usage" on the side of the station-bridge and is littered.
So it seems that the AC is identical to N. good
Sorry for the problem.
Are there any settings to improve performance in a cluttered area?
ibm
Re: 6.24 released
Mon Jan 05, 2015 4:03 pm
With 6.24 the auto negotiation for a 10baseT device doesn't work. I have to set 10 Mbps manually because with auto neg. the RB951G says me no link.
keithy
Re: 6.24 released
Mon Jan 05, 2015 6:09 pm
Use wireless-fp.
And other info:
Link 1
Link 2
Hmmmm! Confusion abounds?
http://forum.mikrotik.com/viewtopic.php ... 45#p461951
marizo
Re: 6.24 released
Mon Jan 05, 2015 9:06 pm
Why with QuickSet MT SXT
CPE
Configuration: Bridge
Wireless Protocol: nv2
automatically uses Wireless Mode: Station-pseudobridge, which isn't compatible to nv2?
What this incompatibility means?
Recently i configured some SXTs AP + CPE for transparent L2, but nothing goes right. If I remember correctly, with some older ROS version this worked correctly.
steen
Re: 6.24 released
Tue Jan 06, 2015 9:52 am
Hello Folks!
From the release of the product we have had problem with CCR1016-12G.
This is not anything new, it happens all the time, at least one time per every 2 months interval, we had it for almost 2 years now.
The device simply stops working, it does not pass any traffic at all on any ports, all lamps are on as usual.
There is nothing in logs, no supout file nothing, it just stops passing traffic....
We have upgraded it everytime a new firmware came out, but nothing, problem remains.
Mikrotik has been helpful giving us hints and we disabled the LED display to mitigate the problem, it made situation better, but not as stable it should be.
Unfortunately the device is out of warrancy, if it hat we would return it, because we think it is a hardware problem since no RoS release made fixing the problem, it is the same all time.
I will open a case and send in supout file, but I am in very doubt over this product now.
Anyone who have the same problem with CCR family ?
steen
Re: 6.24 released
Tue Jan 06, 2015 10:12 am
Hello Folks!
Looking little more, I can see that CCR has lost dhcp-client address on ethernet2, lease expired it says.
The Dude reported 07:53 this morning, whole that site was red in logs.
Inside CCR1016 logs it is written 08:06 dhcp lease expired.
It means in my world, that the router was working internally, but all it's ethernet interfaces was stopping passing traffic or something.
This error we have had before, but only on one ethernet port, here it was all. All internal logging at that site logs 07:53 connection to outer world lost.
As it is now, I need to cluster it, the device is fully unrealiable, that will in itself be a challenge with vrrp and so on, which we never worked with before :-) very very annoying.
keema
Re: 6.24 released
Tue Jan 06, 2015 11:31 am
Well written, I agree 100%!
rpingar
Long time Member
Long time Member
Re: 6.24 released
Tue Jan 06, 2015 12:44 pm
Hello Folks!
we have same experience too, but anly about the MT used about pppoe concetrator, all other configs are fine.
But in our case when a pppoe concentrator starts to handle more then 2k pppoe interface will became freeze in some weeks, no pass traffico on all interfaces, no logs, no supout, no display lcd. The interfaces leds are fine and working as expected when the Whole ros is freezed.
So in my opinion it is a sowftware issue and not an hardware issue.
I had this problem on x86 and CCR, so it is not Platform related.
Maybe sometingh related to frgmentation of the packets when there are too many interfaces....
regards
Ros
becs
Re: 6.24 released
Tue Jan 06, 2015 1:53 pm
We have not found any RB951G ethernet link problems with other devices when using RouterOS v6.24. This problem may not be software related.
ibm
Re: 6.24 released
Tue Jan 06, 2015 2:40 pm
I have this problem only with ATA that supports only 10baseT.
For 100 and 1000 Mbps it's all ok.
uldis
Re: 6.24 released
Tue Jan 06, 2015 3:45 pm
CPE
We will try to fix that in one of the next RouterOS version.
Nicho
Re: 6.24 released
Tue Jan 06, 2015 4:10 pm
what is about the NV2 protocol?
Look here:
http://forum.mikrotik.com/viewtopic.php ... 60#p453160
Can you pls fix this?
strods
Re: 6.24 released
Wed Jan 07, 2015 8:34 am
Hello Folks!
Could you please provide ticket number of case which you have opened for this problem? If not, then please create ticket and send supout file from your device together with description. We will try to check what is going on there.
In best case scenario please attach supout file which is generated while device is woriking incorrectly (most likely generated through serial console).
madmax
Re: 6.24 released
Wed Jan 07, 2015 10:47 am
Since a year I had a bad idea to change my old HP Proliant with FreeBSD and MPD (PPTP concentrator) with a new ,faboulous and powerfull CCR1016-12G...
Tryed all ROs and firmware, but when occur a massive disconnection/reconnection or when some users for a long time reach the speed limit
the CCR goes crazy, some users cannot reach the gateway or internet speed is very very very slow or dont respect the limit.
Any Solution ??? YES!!!!!!!!!!!!!!!!!!!!!
My script reboot the CCR every 48 hours AT 4:30AM .................................. WOWWWWWWWWWWWW :? :? :?
strods
Re: 6.24 released
Wed Jan 07, 2015 11:41 am
We are not aware about issues like this in latest versions of RouterOS. In standard environment everything works correctly with configuration similar to yours. Please create new ticket and send supout file to our support e-mail. We will definitely take a look at your configuration. Please generate file while problem is actual.
http://www.mikrotik.com/support.html
elod
Re: 6.24 released
Wed Jan 07, 2015 12:10 pm
Routerboard 433 has weird issues since upgrading to 6.24 (was flawless for around 2-3 years).
After 1-2 days the WAN (ether2) interface seems to lock up. Rebooting the RB fixes it for a couple of days. Rebooting the Allied Telesis Multiservice Gateway does not fix the issue.
Trisc
Re: 6.24 released
Wed Jan 07, 2015 7:00 pm
from v. 6.20 changelog:
eoip/gre/ipip/6to4 tunnels have dont-fragment option (inherit/no, no by default for new tunnels
If running a GRE tunnel between two routers must they both have this option enabled to prevent fragmentation? Will we see improved throughput on GRE tunnel if don't-fragment=no?
Krionix
Re: 6.24 released
Wed Jan 07, 2015 10:40 pm
After updating to 6.24 lost Hlink LTE interface. Please, quick repair error.
Did you solve your problem? I might have same problem? I did upgrade remotely via winbox (ok my fault, 6.23 did work like a harm, only pptp tunnel was slow...). I lost connection for a upgrade reboot and that was it, no more VPN connection anymore :-(.
I am so angry! I have to go to a remote location to check if I lost LTE interface like skibi82 case?
PIN check has been disabled (via hilink web setup) and I did check that modem does not ask about that and it did not. Now there is a voice mail at the SIM/LTE modem number that is connected to that problematic MT router.
My other VPN/SIM/LTE give a busy signal tone. Hmm , so if not PIN issue what could turn the modem off (so voice mail kicks in) after upgrade? Is it possible?
Please report how did you solve that issue if you did! Microtik support team - RB951g-2hnd ROS 6.23 (stable and okay) -> 6.24 , does it loose LTE interface? I own E3373 HiLink modem. More data will be posted tomorrow when I go to the MT box with a direct cable connection.
keema
Re: 6.24 released
Thu Jan 08, 2015 3:11 pm
In my experience it is very unreliable to remotely upgrade boards that run behind a mobile link. After the reboot the modem might not connect. I've seen this in many versions upgrade so I stopped doing it.
uldis
Re: 6.24 released
Thu Jan 08, 2015 3:55 pm
about lost Hi-Link issue on the Huawei modems, please go to the MikroTik download page and download the v6.25 test release to fix the problem:
becs
Re: 6.24 released
Thu Jan 08, 2015 4:15 pm
Could you tell which RouterOS version was intalled before the upgrade to v6.24?
Perhaps, you should send a supout.rif from this RB433 to MikroTik support if this problem occurs again.
Krionix
Re: 6.24 released
Thu Jan 08, 2015 7:17 pm
I can not do it now since if it fails it will costs me 30km :-/ Router has been running okay after upgrade, besides that I lost LTE interface hence VPN could not connect. So finally I lost contact with the MT device. BTW does "secure" mode in Winbox app help in such upgrade-problem case? Will it downgrade itself if winbox will not reconnect back in certain time?
I did downgrade to 6.23 (upload all modules via winscp and then system-packages-downgrade) and it did help. Included screen-shot might not show the issue, I do not know if the list here is complete or not. I lost LTE from interfaces list after reboot, that is sure. Also LTE tab did not contain any data.
elod
Re: 6.24 released
Fri Jan 09, 2015 2:43 pm
6.23 before upgrading to 6.24. After 2 lockups it's now downgraded to 6.23 again. I'm setting up an out-of-band access before testing with 6.24 and 6.25 again. I'll get back as soon as I have upgraded to 6.24 again.
THG
Re: 6.24 released
Sat Jan 10, 2015 4:44 pm
I found a bug in the X86 version of RouterOS, outbound TCP traffic shows too much.
suntelSean
Re: 6.24 released
Sat Jan 10, 2015 11:41 pm
Sounds like a memory leak where a connection doesn't released already unused resources when done.
vitalay
Re: 6.24 released
Sun Jan 11, 2015 3:21 pm
http://forum.mikrotik.com/viewtopic.php?f=2&t=81728
I have the same issue with the last 6.24 version of routeros x86 in vmware 5.5U2 in l2tp setup. and I can't find the solution to solve this problem right now. :(
savage
Re: 6.24 released
Mon Jan 12, 2015 9:52 pm
Well been running 6.24 on my CCR now for close to 12 hours... Literally half the speed / performance than what I had on 6.23
Still unable to do anything -remotely- over 1.2Gbps on a 10G interface... :evil: Pretty much at the point of using these CCR's for door stops right now - it's no where near 10G ready in terms of real world performance.
Regards,
Chris
acung
Re: 6.24 released
Tue Jan 13, 2015 6:41 am
Link from mAP to rb751g-2hnd autonegotiation set to 10mbps, change manualy to 100mbps, this is software problem
normis
Re: 6.24 released
Tue Jan 13, 2015 8:36 am
Which two ports did you connect together and what RouterOS version do you run on both?
Cha0s
Re: 6.24 released
Tue Jan 13, 2015 4:50 pm
Bandwidth test is broken on 6.24.
On 3 different routerboards (Sextant, RB433AH, Groove) with 6.24 TCP send is horrible. maximum 15mbit (over ethernet) and the whole board is lagging badly during the test (e.g.: 250ms on ethernet with 15mbit traffic).
TCP receive will fully utilize the ethernet as it should.
UDP works fine both with send and receive.
Downgrading back to 6.20 resolves the bandwidth test problems. Any other newer version has the same problem.
With 6.20 Sextant can send >50mbit TCP over ethernet without any lag.
I tried 6.21.1 to 6.24 and all 4 versions have the exact same behavior. So the bug seems to have started on 6.21.1
Here's a screeshot doing bandwidth test from an x86 mikrotik installation (v5.26) to a Sextant (v6.24)
And here's a screenshot doing a bandwidth test from the same x86 mikrotik (v5.26) to the same Sextant with version 6.20
The connection between the x86 and the Sextant is 1gbit.
Jeanluck
Re: 6.24 released
Wed Jan 14, 2015 5:23 am
Update from 5.26 to 6.24 loses the wireless settings in Omnitik / SXT. AGAIN! like older v6.xx versions... Please ... do some minimal testing ....
I update version because I am bound by problems with nv2 ... maybe a good idea to freeze a version and not develop more new functions (only fix bugs)
uldis
Re: 6.24 released
Wed Jan 14, 2015 10:27 am
Please tell us how did you made the upgrade to v6.24 - what packages you used when upgrading to that new RouterOs version?
becs
Re: 6.24 released
Wed Jan 14, 2015 11:33 am
I would appreciate if you send a supout.rif from v6.24 Sextant to MikroTik support, because I cannot reproduce it on test bench.
Jeanluck
Re: 6.24 released
Wed Jan 14, 2015 11:38 am
Thank you very much for your interest.
The problem does not exist with v.6.13 but yes with 6.24 and some earlier.
Always update the same way:
I upload the router-mipsbe-v6.xx.npk and ntp-6.xx-mipsbe.npk (only theses two files)
The second file, I upload it to avoid problems of ntp synchronization
Restarting the antenna:
- LA wireless interface is disabled and named as wlan2
- The bridge has the "unknown" interface instead of wlan1
- The SSID is equal to "System identity"
- The rest of Wireless configuration is lost too
On other hand:
V6.xx versions have serious problems with APs, once time every 1 or 2 months (I reset AP daily to minimice this), its APS-clients constantly disconnect and connect until the AP is restarted. I make a script to detect this and restart automatically
Alfabi
Re: 6.24 released
Wed Jan 14, 2015 12:00 pm
hi, im have bug with x86 from 6.13-6.24 with MTU on Intel® 82583V GbE Controller on L1 is 1500, L2 cant change but show 9014, now, im try set L1 1504-1508-15018-1522-1550 - nothing cant help.... maybe somebody know how fix problem..... ??? MTU bigger than 1500 not working....
last good work version without this bug was 6.12 and 5.26
http://www.bios-computer.com - Fastest WISP in UA
uldis
Re: 6.24 released
Wed Jan 14, 2015 12:18 pm
On other hand:
Just tried with a fresh netinstalled SXT5ND with v5.26 and configured as Bridge mode with ssid and added it to a bridge interface. Then upgraded to v6.24 with the bundle package and ntp package and all the wireless settings and bridge information is there.
Maybe you could tell us what configuration you had in v5.26?
Cha0s
Re: 6.24 released
Wed Jan 14, 2015 12:48 pm
These boards are in production. I am not willing to have any more downtime to beta test your product.
If it helps, I am using nstreme.
I am mentioning it because metarouter shows similar behavior (the whole board lags) when used with nstreme enabled.
Jeanluck
Re: 6.24 released
Wed Jan 14, 2015 12:49 pm
Yesterday, It failed again on a Omnitik with 5.26 (and 3.0x Firmware) with this configuration (only changing AP mode and noise adaptation), try with a Omnitik please (with sxt fail to for me)
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes disabled=no forward-delay=15s l2mtu=1598 max-message-age=20s mtu=1500 \
name=bridge1 priority=0x8000 protocol-mode=rstp transmit-hold-count=6
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=none interface=ether1 path-cost=10 point-to-point=auto priority=0x80
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=none interface=wlan1 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
add authentication-types=wpa-psk,wpa2-psk group-ciphers=aes-ccm group-key-update=5m interim-update=0s management-protection=allowed management-protection-key="" mode=dynamic-keys name=profile1 \
radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none \
static-algo-1=none static-algo-2=none static-algo-3=none static-key-0="" static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=none static-sta-private-key="" static-transmit-key=\
key-0 supplicant-identity="" tls-certificate=none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key=xxxxxxxxxxxxxxxxxxxxx wpa2-pre-shared-key=xxxxxxxxxxxxxxxxxxx
/interface wireless
set 0 adaptive-noise-immunity=client-mode allow-sharedkey=no antenna-gain=0 area="" arp=enabled band=5ghz-onlyn bridge-mode=enabled channel-width=20/40mhz-ht-above compression=no country=spain default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=no distance=dynamic frame-lifetime=0 frequency=\
5500 frequency-mode=manual-txpower frequency-offset=0 hide-ssid=yes \
hw-retries=15 max-station-count=2007 mode=station-bridge name=wlan1 nv2-preshared-key="xxxxxxxxxxxxxxxxxxxx" nv2-security=enabled \
rate-selection=advanced rate-set=default security-profile=profile1 ssid=MYSSID \
wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled wireless-protocol=any wmm-support=disabled
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=3200 framer-policy=none
add address=172.16.0.36/24 disabled=no interface=bridge1 network=172.16.0.0
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=512 servers=10.0.1.254
/ip firewall address-list
add address=85.18.XX.XX disabled=no list=remoteserver
/ip firewall connection tracking set enabled=no
/ip firewall nat set 0 disabled=yes
add action=accept chain=input disabled=no src-address-list=remoteserver
add action=reject chain=input disabled=no dst-port=23,8291 protocol=tcp reject-with=tcp-reset
/ip dhcp-client
set 0 disabled=yes
set 0 disabled=yes
/ip dhcp-server alert
add alert-timeout=1h disabled=yes interface=ether1 valid-server=""
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=172.16.0.1 scope=30 target-scope=10
/interface bridge filter
add action=accept chain=forward disabled=yes in-interface=ether1 out-interface=wlan1 src-mac-address=20:EF:28:16:67:6C/FF:FF:FF:FF:FF:FF
add action=drop chain=forward disabled=yes in-interface=ether1 out-interface=wlan1
/system ntp client
set enabled=yes primary-ntp=193.110.251.54 secondary-ntp=129.70.132.36
/system clock
set time-zone-name=Europe/Madrid
/tool mac-server mac-winbox disable 0
#IP NEIGHBOR
/ip neighbor discovery
set ether1 discover=no
set wlan1 discover=no
set bridge1 discover=no
#IPSERVICE
/ip service
set api-ssl disabled=yes
set telnet disabled=no port=23
set ftp disabled=yes port=21
set www disabled=yes port=80
set ssh disabled=yes port=22
set www-ssl certificate=none disabled=yes port=443
set api disabled=yes port=8728
set winbox disabled=no port=8291
/system watchdog
set automatic-supout=no
szastan
Re: 6.24 released
Wed Jan 14, 2015 1:54 pm
wow, this reminds me: [Ticket#2014121866000223]
This ticket is about the exact same issue regarding Omnitik wireless setting, and it's from 18 dec 2014. I gave you all supouts on 19 dec, and asked for an update on 8 jan. This gives us almost a month without any solution now.
uldis
Re: 6.24 released
Wed Jan 14, 2015 2:49 pm
Jeanluck,
I was unable to reproduce this problem. Took a fresh installed Omnitik with no configuration with Netinstalled RouterOS v5.26 and applied your scipr tnad then performed upgrade to v6.24 with bundle and NTP package. Everything was ok, no wireless config lost.
Jeanluck
Re: 6.24 released
Wed Jan 14, 2015 3:06 pm
ok, I'm sure that this will happen next time again.
What do you need from me for detect this bug?
jaroslavhala
Re: 6.24 released
MikroTik RouterOS 6.24
Mikrotik Cloud Core Router CCR1016-12G
jan/14/2015 11:38:11 system,error,critical System rebooted because of kernel failure
jan/14/2015 11:38:11 system,error,critical router was rebooted without proper shutdown, prob
This is not for the first time I can see this message. Do you want me to create a support ticket for it? Am I the only one experiencing the sudden reboot?
Edit: RB951G-2HnD - same issue now. "router was rebooted without proper shutdown" after 22 hours.
strods
Re: 6.24 released
Wed Jan 14, 2015 5:02 pm
Yes! Please send us supout file from your device. File should be generated after device has rebooted.
Kernel failure is almost the same as - device has rebooted. It only says that something has gone wrong. We need supout file which includes this error and then we can try to find a solution.
alfonzz
Re: 6.24 released
Thu Jan 15, 2015 10:54 am
i comfirmed that!
But no mather from ros 5.26, it happens from newer versions too.
It happens to me sometimes, sometimes not...
In the issue, omnitik found new wlan with new mac adresses:
eth1starts at: 00:0C:42:DC:B1:AC and wifi ends 00:0C:42:DC:B1:B1 but before upgrade wifi has 00:0C:42:DC:B1:AD
this cause that MK found new interface with no config :-(
To v. 6.19 upgrade for omnitik did not have this issues
Sorry for my English!
IPANetEngineer
Trainer
Trainer
Re: 6.24 released
Thu Jan 15, 2015 5:49 pm
Just to add a little perspective on code updates/stability to add to the discussion...
1) To run a stable network, it is NEVER advisable to jump on the latest RouterOS code just to try it. I would say better than 90% of the instability we see in customer's MikroTik (and really other vendors as well) based networks relates to poor design, no change control and code that isn't consistent and updated much too frequently.
note: This is not unique to MikroTik either, we have just as many problems with Cisco networks that are updated too frequently. Often times the list of resolved caveats in IOS and NXOS far exceeds the number of bugs we see in MIkroTik gear. The Cisco Nexus 5K/7K line in particular has been plagued with buggy code and catastrophic outages that shouldn't happen with multi-million dollar network equipment,
2) Running the same code in the major functional areas of your network - for example, all Core routers should be on the same code, all edge routers should be on the same code whenever possible. This lowers the risk of an unexpected interaction between features /protocols across routers.
3) Change control - planning/reviewing changes that aren't routine or part of a known stable template and executing them in a maintenance window solves most of the network instability problems we see. Trying to add things like OSPF, BGP or MPLS during the peak usage hours of your network is just begging for an unplanned outage. Even when we are forced to make major changes in an emergency, we still review the changes between engineers to ensure something critical hasn't been overlooked.
4) Undersizing routers - if your router is constantly at peak CPU, then you need a bigger one! The most stable networks we have rarely see sustained high CPU utilization because the routers are sized appropriately. Some bugs will manifest themselves only under a high load on the device, it's better to throw in more horsepower than to win the best bugfinder of the year award for MikroTik.
These concepts are often found in larger carrier and data center networks but we routinely stress them to customers who don't have tens of thousands of switches and routers because they are tried and true in all network environments. Even if you only have 20 subscribers, you will see a benefit in embracing large network best practices.
** At the time of writing this, we just did a code update to a hybrid MikroTik/Cisco Data Center network with 476 days of uptime! The secret was managed change control, reviewing and planning code changes. That't it...nothing fancy, just conservative management and growth of the network.
Last edited by IPANetEngineer on Fri Jan 16, 2015 5:24 pm, edited 1 time in total.
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
payday
Re: 6.24 released
Fri Jan 16, 2015 11:51 am
MetaROUTER disappeared from WebFig.
normis
Re: 6.24 released
Fri Jan 16, 2015 12:45 pm
will be fixed in 6.25
alexkulik
Re: 6.24 released
On SXT G-5HPacD not apply config file after reset configuration («System» -> «Reset Configuration» -> «Run After Reset» --> «"config file name".rsc»). And still does not display information in the tab «Current Tx Power».
rextended
Re: 6.24 released
Sat Jan 17, 2015 9:16 pm
On 1100AHx2, using EoIP (with default settings) slowly reduce memory free till system hang and reboot.
More traffic is coming trough EoIP, more memory is consumed over time.
Stopping EoIP cause memory slowly be freed.
Please check and fix that.
Thanks.
I'm Italian, not English. Sorry for my imperfect grammar.
rextended
Re: 6.24 released
Sat Jan 17, 2015 9:18 pm
add name="wds bridge"
add bridge="wds bridge" interface=ether1
set max-udp-packet-size=4096 servers=8.8.8.8,8.8.4.4
Good day.
When I try to reset the configuration SXT G-5HPacD followed by the file to the configuration settings will be reset without filling configuration («Reset Configuration» -> «Run After Reset» - does not work). Tried on firmware v.6.22 and v.6.24 - is not working. For example, at the same time, on the SXT Lite2 this function works fine.
Also on SXT G-5HPacD still does not display information in the tab «Current Tx Power».
Example configuration file attached below:
sample_cfg.rsc
add bridge="wds bridge" interface=wlan1
add address=172.16.1.2/24 interface=ether1 network=172.16.1.0
add distance=1 gateway=172.16.1.3
set max-udp-packet-size=512 servers=8.8.8.8,8.8.4.4
/system watchdog
set automatic-supout=no no-ping-delay=10m watch-address=172.16.1.1
Sorry for my English. Translated through an interpreter.
alexkulik
Re: 6.24 released
Sun Jan 18, 2015 12:39 am
Sorry, i made mistake. :wink: It was hastily written only for example, and as a result nothing in a hurry.
I found the problem. It proved that if configurtion file contains settings for the wireless interface - configuration not start correctly after reset, device receives configuration only partially (SXT G-5HPacD). Stops at any mention of the wireless interface. But if i removed all the wireless settings - It starts automatically with no errors.
Here is an example of settings including configuration of wireless interface - it does not start automatically, only manually:
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=\
    protected_access supplicant-identity="" wpa2-pre-shared-key=\
    xxxxxxxxx
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode \
    antenna-gain=16 band=5ghz-onlyac channel-width=20/40/80mhz-Ceee disabled=\
    no distance=1 frequency=5580 frequency-mode=superchannel guard-interval=\
    long hw-protection-mode=rts-cts l2mtu=1600 mode=station-wds \
    multicast-helper=disabled nv2-preshared-key=xxxxxxxxx \
    nv2-security=enabled radio-name=Alex-Side-ac scan-list=5580 \
    security-profile=protected_access ssid=xxx tx-power=24 \
    tx-power-mode=all-rates-fixed wds-default-bridge="wds bridge" wds-mode=\
    dynamic wireless-protocol=nv2
set wlan1 disable-csma=yes enable-nstreme=yes framer-policy=dynamic-size
add name="kuliks pool" ranges=172.16.1.130-172.16.1.200
add address-pool="kuliks pool" disabled=no interface="wds bridge" name=\
    Kulik-net
/queue type
set 2 kind=pfifo
set 9 pfifo-limit=100
add address=172.16.1.0/24 dns-server=\
    8.8.8.8,8.8.4.4 gateway=172.16.1.3 \
    ntp-server=66.219.116.140,128.138.141.172
set max-udp-packet-size=4096 servers=195.162.65.251,195.162.65.252
/ip service
/system clock
set time-zone-name=Europe/Kiev
/system identity
set name=SXT-ac_A-D-DHCPsvr
/system leds
set 0 interface=wlan1
/system ntp client
set enabled=yes primary-ntp=66.219.116.140 secondary-ntp=128.138.141.172
/system watchdog
set automatic-supout=no watch-address=172.16.1.251
Here is an example of the same configuration, but without the configuration of the wireless interface - it normally starts automatically.
    Kulik-net
/queue type
set 2 kind=pfifo
/ip service
/system clock
/system identity
/system ntp client
/system watchdog
sonny
Re: 6.24 released
Sun Jan 18, 2015 8:31 pm
Uldis,
when will we see AP sync support for NV2?
Now it is realy time to have this feature.
Karl Sonnleitner
Senior Wireless-Expert
Restlesspowerbox - managed powersupply for Routerboards
elod
Re: 6.24 released
Fri Jan 23, 2015 8:13 pm
Ok, 6.24 basically s*c*** big time.
I still have not installed my out of band link to the 433 whose ether2 interface (used as wan) stopped working twice in about 5 days) but now...
I can also confirm 3x rb2011's that lost ssh connectivity for some reason some time after the upgrade to 6.24. They are upgraded to 6.25 now, but I still have one that basically does not respond to any connection to the management interface (winbox, telnet or ssh). It does forward traffic though.
Users browsing this forum: storp and 43 guests
