Sun Jan 04, 2015 11:22 pm
Hi! I have same problem.
In one bridge I reached near 700 Mbps between 2 laptops with gigabit NIC by BTest with UDP.
But when I move one laptop to other VLAN (VLAN routed by this CRS) I found that speed is only near 15-20 Mbps, it's very low speed.
But if I disable 1Gbit modes (half- and full-duplex) on interfaces and link only 100 Mbps full-duplex -- I can reach all link's throughput. I then try to enable flow-control on 1 Gbps mode, but it not helps.
