Cha0s
Forum Veteran
Forum Veteran
Re: RouterOS v7.0 beta1 - when?
Mon Dec 11, 2017 4:00 pm
Could we expect hardware acceleration AES for RB3011UiAS-RM?
Not before v7. Even after v7 I am not so sure they will add HW AES support. The CPU does support it, but MikroTik don't seem to want to invest in RB3011.
They never released any other model as they did with the various models of RB2011...
ZeroByte
Tue Dec 12, 2017 8:04 pm
Could we expect a setup assistent for IPV6 Nat in Router OS?
IPv6 NAT - I bet we have to wait longer than the IGMP snooping people waited before it comes out. . .
If Mikrotik _does_ decide to add this in, I would request the following flavors (most-preferred first)
- NAT64 protocol translation (stateful)
- NAT64 protocol translation (stateless)
- NAT66-PT (stateless prefix translation)
-NAT66 (dstnat) - This is useful for things like transparent service redirection
- NAT66 (srcnat many-to-1) - this one I could be happy if they never implemented. I'd prefer for the IPv6 community to never deploy in a way that requires this because once it's there, the wound can never be completely healed.
When given a spoon,
you should not cling to your fork.
The soup will get cold.
Vooray
Sat Jan 06, 2018 7:57 pm
Up :)
It is 2018 already. May we have some status report or plans on v7 release? Or it is abandoned already?
mistry7
Sun Jan 07, 2018 9:03 pm
Looks like it is Canceled.....
Nothing in the last 4 years
So we are Stil on Kernel 3.xx.xx
telcouk
Mon Jan 08, 2018 4:03 pm
I think we can safely assume that v7 is some way off, with Mikrotik staying tight lipped on a release date.
Indicating that they themselves have no idea of when it is going to be released.
We are getting to the stage where we are outgrowing our Cloud Core routers, yet we’re only doing 10-100Mb of traffic typically throughout the day! What is killing us is BGP updates, causing jitter / latency spikes on our network… We have a total of 3 full BGP feeds on a total of 4 Mikrotik Cloud Core routers.
Unfortunately, we have lost patience with Mikrotik and we are in the process of exploring alternatives. We won’t be purchasing further Mikrotik products which require BGP.
I really do think they should spell out the limitations of BGP… As on paper everything looks amazing with the Cloud Core routers, however the reality is VERY different.
ste
Mon Jan 08, 2018 5:03 pm
Not noticed this BGP generated jitter/latency so far. Searched the forum and did not find something regarding this. Did you post/discussed this problem?
ZeroByte
Mon Jan 08, 2018 5:12 pm
I think he's referring to the fact that BGP runs in a single thread - ergo cannot take advantage of multi-core tile platform. It could be that during convergence, his network performance is spotty due to various reasons, but that's just speculation on my part. At the end of the day, though, there have been many "oh that will be fixed / added / addressed in ROSv7" issues - more than I can recall, really.
When given a spoon,
zyzelis
Mon Jan 08, 2018 7:34 pm
+1
to say more: we already moving out from mtik wireless, now after some accidents bgp routers are on the way.
patrick7
Mon Jan 08, 2018 7:54 pm
Maybe we should collaborate and make a list of alternative devices / software solutions?
As a start:
CloudCoreRouter
SuperMicro 5018D-FN8T
- 6x Gigabit Ethernet (RJ45)
- 2x 10 Gigabit Ethernet (SFP+)
- 16GB RAM
- Xeon-D 1518 Quad Core
RB75X
PCEngines APU2
- 3x Gigabit Ethernet
- 4GB RAM
- 1 GHz Quad Core X86
BGP/OSPF/MPLS done with FRR, multiple fulltables no issue.
mistry7
Wed Jan 10, 2018 5:36 am
We are lucky and dont buy Mikrotik CCR for BGP....
http://mum.mikrotik.com/presentations/RU14/megis.pdf
But for all other, this Dokument is 4 years old and still nothing...
The most CCR for BGP would sorted out before they will release v7
so the problems also resolve themselves, no more need for ROS v7
I am also looking for an alternative for Mikrotik Wireless, because of missing
- spectral scan
- Nv2 bad performance in 802.11ac
- missing innovation
- missing Sync
- Limitation in Channel width
After 14 years with MIKROTIK this is not easy. Our hole Netwotk is Mikrotik based,
But they don't here and don't care the needs in Wireless Market, so we have to look to another Brands!
Pity, but reality
Mistry7
honzam
Wed Jan 10, 2018 10:12 am
- spectral scan
- missing Sync
Pity, but reality
We have the same problem with wireless :(
We don´t use BGP on Mikrotik . The main problem is the old wireless kernel 3.0 in ROS V6
LAN, FTTx, Wireless. ISP operator
WireDick
Fri Jan 12, 2018 12:48 am
Can someone explain me why they just can't enable Hardware accelartion for AES in rb3011 for example as Routerboard update or license buy option???
We have 18 of them mostly for managing sophos / Cisco / Siemens stuff etc. .... via openvpn and during the last months with growing network complxity we run into bandwith issue ....
patrick7
Fri Jan 12, 2018 1:57 pm
Don't expect anything kernel related to be fixed in v6.
mistry7
Fri Jan 12, 2018 6:05 pm
And don´t expect fast Release of ROS7,
we are now at 4.14.xx how long we will see Kernel 4?
Linux Kernel 5.0 Will be Coming in the Summer of 2018
Mikrotik is 4-5years behind development!
Chupaka
Sat Jan 13, 2018 7:12 pm
RHEL 7.4 uses kernel 3.10.0-693. How many years are they behind development? :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
mistry7
Sat Jan 13, 2018 9:59 pm
right....
But RHEL 8.0 is on the way based on Fedora 27 aka Linux Kernel 4.14
s9date
Sat Jan 13, 2018 11:54 pm
Hello. I have 11 Mikrotik 912 + Sierra MC7304. I too would love to have this to start testing LTE on MC7304. Thank you.
RogerWilco
Tue Jan 16, 2018 3:35 am
I only have 1 of each, but I'd love to be able to use LTE too.
wilsonlmh
Wed Jan 17, 2018 8:34 am
No, I'm still waiting for VirtIO support in v7
mark73
Thu Feb 08, 2018 5:01 pm
ROSv7 will be released just after Duke Nukem Forever!
*SCNR*
mrz
Thu Feb 08, 2018 5:33 pm
DNF was released in 2011, so ...
juliokato
Thu Feb 08, 2018 6:51 pm
No comments....
kkk
:wq!
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
Chupaka
Fri Feb 09, 2018 7:59 am
So it's time for ROS v7!
jarda
Fri Feb 09, 2018 9:06 am
Apparently not yet. Don't you remember the well known sentence of Normis? "When it will be then it will be." :-)
patrick7
Sat Feb 10, 2018 12:34 am
After waiting 5 years, I think it won't ever be released.
pe1chl
Sat Feb 10, 2018 11:55 am
They have moved themselves into incredible difficulty by raising the expectations so much....
When v7 would just have been a move to a new kernel that would then allow the gradual introduction of new features that required that new kernel,
and in parallel to the usual changes like we now see in the 6.x series there would be some "experimental packages" that introduce radical changes
(like the mighty new routing code), everything would have proceeded smoothly.
And it has been done before. Autorouting has been an experimental package before, and several packages for Wireless.
After some feedback and development, these respective packages became part of the standard distribution.
But now, v7 is kind of a magic bullet that promises to fix many issues and limitations, and of course it can never be completely ready for release
(without bugs and loose ends). So no matter how long it is postponed, there will always be a lot of disappointment and support calls. And by now
it is much too late to go back to the more gradual migration as described above. At least under the designation RouterOS v7.
Paternot
Long time Member
Long time Member
Sat Feb 10, 2018 4:58 pm
And by now it is much too late to go back to the more gradual migration as described above. At least under the designation RouterOS v7.
Well, there is always RouterOS v8... :D
patrick7
Sat Feb 10, 2018 9:05 pm
Release of v8 will be in ~ 40 years if they proceed with the same speed.
pe1chl
Sun Feb 11, 2018 12:14 pm
I think it refers to the option of skipping v7 altogether and then proceed the way described above.
(i.e. make v8 a v6 with current kernel and then incrementally build from there just as done in v6.xx releases)
Paternot
Long time Member
Long time Member
Mon Feb 12, 2018 3:19 am
Yes, that's it. I just think V8 should come with a new kernel - and the rest should be improved sequentially. The worst part of a new kernel are the hardware drivers. The rest is, for the most part, high level enough to not be directly affected by it.
bearmeister
Thu Feb 15, 2018 5:58 am
And yet, they are still able to deliver a working stateful DHCPv6 server, irony much?
Meanwhile, Mikrotik who are supposed to be in the SP space can't deliver a decent BGP or a working DHCPv6 server.
ROS7 has been thrown around so much over the years as far as I'm concerned its just vaporware, I'll believe it exists when I see it.
Until then, I like others, will continue to explore alternative that meet basic industry requirements.
Sob
Thu Feb 15, 2018 6:21 pm
When v7 would just have been a move to a new kernel ...
It's pure speculation, but I think that "just switching kernel" might be the problematic part. If they modified too much in the old one (and it looks like a lot of what RouterOS does is not just in userspace), porting everything forward can be hard. Linux is evolving, and it's being worked on by many people, much more than MikroTik has (I guess). So they can either break from it, go own way, and lose all those nice improvements already done by someone else. Or they can try to keep up with changes, port their stuff, but that can be an awful lot of work.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
Paternot
Long time Member
Long time Member
Fri Feb 16, 2018 9:49 pm
I'm not sure about that. The drivers are kernel bound, of course. So are the NV protocols - with all that TDMA and whatnot. But (almost) everything else? Is just userspace. Even routing: you change it in linux with a userspace command. The kernel may change as much as they want - the interface is still the same.
Even things like L2TP shouldn't be a problem: You still talks to the kernel through a userspace interface. IPv6, PPP, OpenVpn, IPSec... everything is userspace controlled. Yes, yes. OpenVpn creats an interface (tun or tap). They are provided by the kernel, and are userspace controlled. If the Linux kernel was ported to a given architecture, chances are they're already available.
The drivers... well, the drivers are the hard part. If they aren't part of the kernel three, then Mikrotik must get them, compiled to the new kernel, from the hardware makers. And this is not always easy... Then they need to test, test, test, integrate, validate... a truly hellish task.
I agree with what was said: they promised too much, and now are trying to live up to their promises. This means a lot of development, in a lot of packages. And the drivers! Have I said how hard the drivers part will be? :)
Sob
Fri Feb 16, 2018 10:40 pm
I'm not sure either (and I hope I made it clear enough).
My basic argument is that used kernel was said to be limiting factor for adding some new features years ago. So it would make sense to upgrade it, and not wait for too long before doing so. Not only can the new version already have some wanted features built-in, but also hardware manufacturers are more likely to support current kernel in their (not yet built-in) drivers, if we're talking about newish hardware. If there was only relatively small amount of modifications made by MikroTik, then why hold off for so long?
I'd also say that there's a difference between controlled from userspace and being in userspace, but I can't really go far with that, because that would be too thin ice for me.
I doubt that MikroTik will share exact details, so speculations is the only thing we have. Other than just waiting, but it's a little boring already. ;)
Paternot
Long time Member
Long time Member
Sat Feb 17, 2018 12:22 am
I don't know. Just passing time, with idle speculation. :D
mhugo
Sat Feb 17, 2018 10:57 pm
We have been waiting too long for basic SP features like multithread BGP and something as simple as DHCP Option 82 Circuit ID. I think that if Mikrotik showed that anything was actually happening it would be easier to not look at other vendors.
jarda
Sun Feb 18, 2018 12:12 am
This is always possible and I encourage you to do that. There is free competition on the market and you should spend money on the products that fits your needs the best.
thobias
Mon Feb 19, 2018 12:29 pm
+1
We are also now in the process of throwing out everything Mikrotik running BGP as it cannot handle it.
patrick7
Mon Feb 19, 2018 5:48 pm
We too. Using SuperMicro Xeon-D appliances with debian and FRR. Works like a charm, BGP with X fulltables, VRF (v4/v6), Route Leaking, ...
netravnen
Tue Mar 06, 2018 2:09 pm
Looking away from RouterOS v6.x running IPv6 BGP [tables]?
Not being able to verify IPv6 routing table (when not main table!) is really a big deal. (But seeing the routes exists by the number the route counter shows. :sigh:)
And doing policy routing rules for anything else than main table in IPv6.
It feels a bit poorly planned/immature(still?) when compared to I can do the WHOLE vrf-mpls infrastructure with IPv4. But it is only partially implemented with IPv6 (vrf's?) in RouterOS v6.x. :/
Still looking for equalized feature set between IPv4 and IPv6 in RouterOS version 7 or 8(?) in 2020 or 2025(?)
@Mikrotik: Would be nice with a roadmap somewhere telling all us customers which year to expect the release of the first release candidate for the next major release of RouterOS. (Currently it feels sort of I'm/we are left out to dry just looking/scraping for news about the next major below the earths horizon and outer space past the planet of Uranus.)
Would REALLY appreciate a lot more openness compared to fx when GitLab.com encountered extended downtime for days due to an engineers non-intended blunder while doing maintenance that fateful day last year (2017).
have you enabled IPv6 on something today...?
Cheers,
Netravnen
Cha0s
Forum Veteran
Forum Veteran
Tue Mar 06, 2018 2:19 pm
Didn't you hear? Almost all v7 features have been backported to v6!
Doesn't matter that routing (bgp), ipv6, drivers and all necessary 'routing' stuff cannot get backported due to old kernel version in v6. At least we now have kids control and detect internet! Super essential features for routers running BGP in the public internet :lol: :lol:
netravnen
Tue Mar 06, 2018 2:39 pm
No. I have not (before now) stumbled across that information.
So looking forward to when RouterOS will support SR !
Cheers,
Netravnen
carlhjerpe
Wed Apr 04, 2018 1:42 pm
If we draw some conclusions:
  1. Almost everything from 7.x has been backported to 6.x
  2. MikroTik has been in trouble about GPL
  3. It's been in development for a long period of time
  4. Linux has dropped TILE support
Could it possibly be that they're moving to something that isn't GPL licensed?
Just saying, there are options that aren't Linux.
mtsphere
Thu Apr 05, 2018 3:11 am
I'm sure that this will never happen... Much like IS-IS..
Somehow i'm sad that many people are leaving MT platform (numerous reasons) since i'm following and using MT basically from the begging.
Number of our customers moved to Quagga / Bird just because BGP glitches.. They waited.. but - Big Foot (v7) never came around..
Cheers
ziegenberg
Thu Apr 05, 2018 11:24 am
As mentioned several times on this forum, this does not apply as MikroTik did not use the linux community TILE code in any way. They do not rely on the TILE support of Linux at all.
cheeze
Sun Apr 15, 2018 10:04 pm
Mikrotik, please please please please.
Leave the development of *NEW* features/things/whatnot out of ROS 6 now. Please, move the developers out of ROS 6 feature development and have them go to ROS 7 development. Bugfixes should still keep going on ROS 6 as they are going now (if possible).
There needs to be a harder development push towards ROS 7. If there's nothing else to develop for ROS 7 (which I have high doubts on as I know more and more features are being added to it all the time), then can we please get a glimpse of how things are going with it. I think we can all more or less surmize that Mikrotik is probably building an entirely new routing stack from scratch and that it is taking far more amounts of time than anyone ever expected. As much as it is feasible, can more people be thrown at developing ROS 7 instead of adding more features to ROS 6?
jarda
Mon Apr 16, 2018 3:43 pm
Déjà vu?
Don't we remember the transition years between the version 5 and 6?
dynek
Mon Apr 16, 2018 3:51 pm
Well if they say they backported most (all ?) v7 functionalities into v6, I don't really see a problem here.
mistry7
Mon Apr 16, 2018 4:28 pm
The problem is the old kernel ROS 6 based on, there much improvements only possible with newer kernel.
And we will see ROS 7 with 4.xx Kernel when Linus Towards launch Kernel 5.xx, happens probably this summer....
And the delay will getting bigger.
All new products with IPQ have driver throughput problems, Mikrotik works with a back ported driver, it would be easier to use the origin one,
but it is only available for newer kernels...
here the delay takes its toll
pe1chl
Mon Apr 16, 2018 9:12 pm
It becomes more clear that the kernel has been so heavily modified that it is not so easy to upgrade it anymore.
This is of course always a tough decision: do you limit the kernel changes and try to forward them to the kernel development group, which will cause a lot of wasted time due to discussion about how to implement some feature, or do you just "fork" the kernel based on some version uptodate at that time, causing the problem there is now.
On the other hand, when you do all the work on a forked kernel, you are not affected by decisions like the dropping of TILE support in the kernel.
honzam
Mon Apr 16, 2018 9:56 pm
Maybe Mikrotik wait for kernel 5.x :)
jarda
Mon Apr 16, 2018 11:06 pm
... Just to start waiting for the 6.x kernel...
mistry7
Mon Apr 16, 2018 11:18 pm
right, and then hang on old drivers, that is exactly what happend
The problem Beginns if you has to support up to date Hardware with this old software!
And now we are standing in the rain, Mikrotik has no timeline for Ros7, flawless ARM Wireless driver, Spectral Scan........
cheeze
Tue Apr 17, 2018 12:35 am
I am still not sure why Mikrotik didn't go with IP Infusion....
CTSsean
Thu Apr 26, 2018 5:37 pm
so 15 years from version to version. Nice... so we only have another 11 years.
nz_monkey
Fri Apr 27, 2018 12:12 am
That is not the problem.
The problem is getting a modern kernel that boots on all of the platforms while supporting hardware offloads.
Just my opinion...
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
cheeze
Mon Apr 30, 2018 12:19 am
Just my opinion...
To be honest, I think it's both. However I think what you bring up is likely more of the issue though.
I wonder if it's worth it for Mikrotik to just focus on like.....x86-64/ARM/TILE going forward. Not sure if the MIPS devices are still supported to be honest. I also have been hearing that TILE is no longer going to be a supported hardware platform. Which sucks.
jarda
Mon Apr 30, 2018 10:15 am
It was written several times here. Future versions of ros will be running on tilera further. Ros is not affected by this.
normis
Mon Apr 30, 2018 10:29 am
RouterOS uses very little of open source code. MikroTik is in direct relationship with the CPU manufacturers. We use the official drivers and code. We don't use open source code.
mistry7
Mon Apr 30, 2018 10:44 am
Then explain the difficulty's with migrating on to newer Kernel.....
normis
Mon Apr 30, 2018 11:56 am
This is the difficulty :D If we were using all open source code, it would be easy to upgrade. Now we must only rely on ourselves to upgrade all programs.
Vitis
Mon Apr 30, 2018 4:04 pm
Do you have any timeline? We are waiting more than 4 year for the VRF support :?
lillecarl
Mon Apr 30, 2018 4:09 pm
Is RouterOS 7 going to ship a Linux kernel?
levicki
Tue May 01, 2018 11:56 am
MikroTik (just like Ubiquiti and many others for that matter) are depending on the hardware (CPU/chipset) manufacturer for major upgrades. Those manufacturers are the ones who provide SDK and drivers (the latter usually in binary form only due to patents), and those drivers cannot be loaded on newer kernel without recompile. If the manufacturer does not supply updated binaries and SDK they cannot update anything.
patrick7
Fri May 18, 2018 3:13 pm
While I understand it needs some time to make good software, it's getting embarrassing with v7 (or its promised bugfixes). Since 2013 MikroTik promises to fix bugs with v7 (recursive ipv6 nexthops etc), and absolutely NOTHING happens. I'm sorry, but such a product is absolutely unsuitable for professional use.
Florian
Fri Jun 01, 2018 2:50 pm
To be fair, some of "wait for v7" problems were in fact corrected in v6.XX (like more options for DHCPv6 Server)
My theory is that they didn't plan to push v6 this far, and they realised that SOME of v7 features could be in fact in v6, so this "helped" delay V7.
Now, Mikrotik is not a small fish, but they're not Cisco or HPE/Aruba. If V7 is a major overhaul, I can't image the hour/man needed to do that.
- Sorry for my english -
pe1chl
Fri Jun 01, 2018 3:17 pm
That is why it is often impractical to develop software that way.
Announcing a new version that is to be "rewritten from scratch" or similar claims usually results in failure.
Gradually developing new features and maybe rewriting some subsystems one at a time has more chance of succeeding.
Probably a chance to survive this mess is to make a release that aligns the kernel with a reasonably current version and
then work from there on replacement of the subsystems that were announced to be rewritten. However it will be impossible
to release such a change as "v7.0" because there will be a big flood of "you announced it will be fixed in v7 and now we have
v7 and it is still not fixed!" complaints. No idea how to work around that. Go to v8 immediately, change the version naming
(like Microsoft did many times) so it is e.g. called "RouterOS 2018" or "RouterOS Vista"?
Paternot
Long time Member
Long time Member
Fri Jun 01, 2018 6:28 pm
I agree that would be the best way to handle this.
About the problem of "You said it would be done on V7!": Make the version 7 a big announcement. Keep telling about the improvements the new kernel would bring. And - here is the thing - create a roadmap. Something like this:
V7.0 -> Inicial release. Low level kernel/drivers work.
V7.1 -> Subsystem "X" revamped.
V7.2 -> Subsystem "Y" revamped. Feature "Z" included. Long pending limitation "W" addressed.
Better than trying to deliver whole mythical unicorn. V7.X to V7.Y would be like V4.41.X to 6.42.X, in terms of time and development.
How about?
juliokato
Sun Jun 03, 2018 6:06 pm
I just want to get an idea of how much this unicorn will give birth.
R1CH
Forum Veteran
Forum Veteran
Tue Jun 05, 2018 4:17 pm
Why is Mikrotik so against using open source software? We would have working 802.11ac Wave2, 5 GHz spectral scan, OpenVPN UDP support, more secure smbd, httpd, etc if Mikrotik would stop re-inventing everything in-house and use well-tested open source software. You could combine open source kernel with proprietary modules for hardware offloading etc in much the same way NVIDIA provides proprietary Linux graphics drivers for their chips.
pe1chl
Tue Jun 05, 2018 4:26 pm
One reason is probably that when you use opensource software and keep tracking all the updates, you end up with more and more bloated software that does not fit into a space-limited router anymore.
It works fine on the PC platform where space and other resource usage (CPU) has grown with the code, but on embedded hardware it is a bit more difficult.
Remember the current routers mostly have only 16MB of flash space!
(the previous generation usually had 128MB which was a bit more generous, but to store generic opensouce software for all functions you would need more like 512MB-1GB in my experience)
Paternot
Long time Member
Long time Member
Tue Jun 05, 2018 4:48 pm
I don't see all this bloat. Well, not at where we talking: low level, kernel, drivers and servers. Take a look at the RaspberryPi: Full OpenSource, ARM, Linux kernel. This is fdisk usage from one I have access to (default install, with graphic desktop and full updated).
df -h
Sist. Arq. Tam. Usado Disp. Uso% Montado em
/dev/root 15G 4,6G 9,4G 33% /
devtmpfs 370M 0 370M 0% /dev
tmpfs 375M 0 375M 0% /dev/shm
tmpfs 375M 9,9M 365M 3% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 375M 0 375M 0% /sys/fs/cgroup
/dev/mmcblk0p1 41M 22M 20M 53% /boot
tmpfs 75M 0 75M 0% /run/user/1002
tmpfs 75M 0 75M 0% /run/user/1001
I am using 4,6GiB of disk space. Not that bad.
True, it doesn't have OpenVPN and everything else installed - but it would not use more than 1 GiB. Even if it used 3 more GiB: It would be still using less than ROS.
So, no. To me is more about control. If they build it, they can guarantee the software through the expected life cycle of the product.
If it is a good idea, if this costs less resources than going full OpenSource, if the competitive advantage is worth the trouble (even if there is one or not) is another problem - and a strategical decision to Mikrotik.
Wyz4k
Tue Jun 05, 2018 5:37 pm
3GB is less than ROS? ROS is 20-40MB...
pe1chl
Tue Jun 05, 2018 6:05 pm
I think you somehow are confusing MB and GB here. Quite common these days!
juliokato
Tue Jun 05, 2018 6:17 pm
many people also confuse bit (b) and byte (B) for traffic analysis.
Chupaka
Tue Jun 05, 2018 6:36 pm
many people think that if 1 megabyte = 1024 kilobytes, then 1 megabit per second = 1024 kilobits per second :)
Paternot
Long time Member
Long time Member
Tue Jun 05, 2018 9:58 pm
LOL True enough. Things move so fast, we lost track of these things. Nowadays we carry in the pocket a mobile with 4GiB of RAM - and my first computer had 16KiB of RAM... Sometimes is enough to make lost track of things... :D
R1CH
Forum Veteran
Forum Veteran
Wed Jun 06, 2018 2:22 pm
I don't really buy this argument. Linksys, DLINK, etc all use open source software and have no issues selling $50 routers with enough disk space to support all these packages. With good compilation options and stripping of binaries it's possible to get very small versions of many popular packages. And as you say, Mikrotik used to have plenty of disk space with their products, only recently have they been skimping on the NAND size.
brotherdust
Fri Jun 08, 2018 12:24 am
I think @levicki is correct about being beholden to the manufacturer's release cadences. Most manufacturers of embedded networking kit are still hanging out on kernel 3.x. It's really annoying! If any manufacturer is reading this: STOP DOING OUT-OF-LINE KERNEL RELEASES. UPSTREAM YOUR CHANGES.
I digress...
In terms of features, at release, ROS 6 was in the unique position of supporting some fairly advanced scenarios; but these had to be developed in-house. Since that time, much effort (and a LOT of money) has been put in to the Linux network stack, especially in the v4.x series. As a result, vanilla Linux kernel can do almost everything ROS can do, and more besides. ROS can't leverage those developments unless they backport the features from v4 kernel to v3 kernel, because most manufacturer SDK's are, as mentioned previously, still stuck in kernel v3-land.
So, all this to answer the question, "When?" My gut tells me that it won't happen until it's more painful to maintain ROS v6 than it is to start over and leverage open-source efforts better. As ROS v6 continues to age, use-cases in [newer, more complex, software-driven] environments will shrink; to the point where it's only useful for very small providers, small business, and home users.
From where I'm standing, as a service provider, the competitive landscape is changing rapidly. To survive, I must be able to offer new services my customers are demanding as quickly as possible. Right now, my biggest limiting factor in delivering those services is RouterOS. I really, really love RouterOS, but it's not growing with me and, sadly, I don't think Mikrotik is all that interested in what we have to say.
Evidence:
- Numerous attempts to solicit ideas for future products from the forum community (see: viewtopic.php?f=2&t=121533&hilit=flagship+router), then basically ignoring it and going a different direction
- Continued focus on last-mile and switching-type devices and software supporting said devices
- Inability and/or unwillingness to maintain a coherent feature request list (see: https://community.ubnt.com/t5/UNMS-Feat ... reRequests as an example of how to do it better) that the community can vote/provide feedback on
Am I wrong? Possibly. I'm trying to be as objective as I can in this analysis; but I'll admit I'm at the point of "believe-it-when-you-see-it".
nz_monkey
Fri Jun 08, 2018 3:10 am
I agree with almost everything @brotherdust has said above, his comments match my own feelings on the current state of Mikrotik.
I have been a huge fan of Mikrotik's RouterOS, but I am using it less and less. The service provider market has kept evolving but RouterOS has not evolved with it.
Mikrotik had a lot of momentum with RouterOS and Service Provider features, e.g. they moved from Quagga to their own Routing engine and added MPLS features during the 3.x and 4.x phase, and then it all just stopped during the 5.x phase. That was over 7 years ago now!
Mikrotik's sales are growing and they are focusing on the areas where they see growth, but that does not mean long term success.
This reminds me somewhat of Toyota thinking they could keep growing by making variations of the Corolla and Camry, so they stopped producing cars like the Celica and Supra, but what they did not realise was that while sales volumes for the Celica and Supra were low, they were the "hero" cars that were attracting buyers to the brand... The result, Toyota, from #1 to #6...
The Service Provider features like BGP, OSPF, MPLS, BNG (PPP/DHCP) are the "Hero" features of RouterOS...
Chupaka
Fri Jun 08, 2018 1:07 pm
Well, sometimes those changes are simply not accepted into kernel :)
patrick7
Fri Jun 08, 2018 5:38 pm
2 years ago I had CCRs running in 3 locations. Now all CCRs have been replaced with debian+FRR boxes. Are much better (features, open source), and the price is +- the same.
The only mikrotik device I'm still using is a small CRS at home.
brotherdust
Fri Jun 08, 2018 10:15 pm
What it really boils down to is management decision to go where the money is. This is not unexpected or really all that surprising. Apple does the same thing. What's troubling is that they are effectively alienating some of their fiercest advocates, service providers, in the same way Apple is alienating their professional customers. From where I stand, it's a short-sighted and frustrating turn of events; especially since they aren't really communicating this change in strategy to their customers (maybe in shareholder meetings, but I'm not privy to those).
I think what angers me the most is they aren't willing to fess up and stop leading their service provider customers on with false hope of being able to deliver the features we need. I'm willing to be patient, to bend over backwards, but only if expectations are clearly communicated. If they can't deliver, they should explain why, and set new expectations. It's that simple. =/ Is that too much to ask?
brotherdust
Fri Jun 08, 2018 10:16 pm
That's a fair point. It's not a simple matter to get those changes accepted. But that begs the question: if they're being denied, why? Maybe write better code? =)
PtDragon
Sat Jun 09, 2018 6:23 pm
Dear MikroTik team!
Can we have some info on v7 progress?
Like "Release possible this year" or like "Release can be in next few years roughly" or "Don't even wait for it until 10-15 years".
You know in which state your code is, right?
And we still do not have any info at all so year after year we wait it blindly.
CCR1036-12G-4S +6x100Mbit ^_^
jarda
Sat Jun 09, 2018 6:29 pm
Why to wait for something that none knows anything about it?
jspool
Sat Jun 09, 2018 11:08 pm
I'm more excited that they are hiring Android & iOS programmers as well as mobile application WEB application programmers. Some native management apps would be very nice.
https://darbs.mikrotik.com/darbs/
When they are ready they will release the newer RouterOS. Their new building is more conducive to their growing needs and should allow them to evolve to the needs of the industries they serve.
jarda
Sun Jun 10, 2018 10:17 am
Unfortunately they are not seeking the persons they need the most: the security engineers.
z1022
Thu Jun 14, 2018 6:42 pm
We will release a beta, when it will exist. Currently v7 is in alpha stage, many functions are not completed and non functional. Beta needs at least all functions to be somewhat operational.
waiting for three year la
paoloaga
Wed Jun 20, 2018 6:34 pm
It seems that releasing a complete RouterOS v7 is a very complex task.
What if Mikrotik publishes new release branches? Something like:
Legacy-v5 - Stable-v6 - Current-v6 - Daily-v6 - Current-v7 - Daily-v7
V7 can be published starting with a minimal set of features. Who needs the complete set can install v6-current, who needs v7 features (like ipv6 recursive next hop) but doesn't need other things can optionally install v7.
Vooray
Wed Jun 20, 2018 11:43 pm
Hmm.. heared that U named company released linux 4 based firmware for their routers. Just to mention.
And, as i heared u can have frr on it.
No hands on that equipment, but i keep my eye on it.
And, as i track linux kernel changes, some descent work has been done in networking stack by guys from 6wind and cumulus.
So, mikrotik team, you have a chance. Or had?
huntermic
Wed Jul 04, 2018 4:01 pm
This makes me seriously thinking about goin back to this U named company, the lack of news on the great version 7 with support for 'old' thing like wave2 support and serious ipv6 support for instance. The Mikrotik hadware is capable but the software is limping on this hardware. Shame on Mikrotik for not even ging us an indication on how far development is. I'm done waiting.
pe1chl
Wed Jul 04, 2018 4:39 pm
The problem is that the U named company has so few options for routers, and so little router functionality in WiFi equipment.
huntermic
Wed Jul 04, 2018 5:30 pm
The real issue is lack of clarity. No communication or anything to keep us posted on the progress of the new kernel version. ( they call it version 7 but that's just a number ).
All they say is 'hey we have hardware that can do this, only the software can't but we will fix that in the next version, 7. But we might keep you waiting for many years'
ofer
Wed Jul 04, 2018 6:57 pm
from what I'm seeing from a business perspective there is no point pushing for the mythical v7 as long as the v6 still sells well
Mikrotik doesn't see v7 as a priority because v6 still sells.
when v6 will become a deterring factor we will see v7 being worked on seriously until that day comes don't expect to see any major investment in v7
you should all that this is the way things are v6 is available as is because there is no official word about v7 or future roadmap take that to consideration when buying Mikrotik products.
v7 the eternal alpha will be a unicorn until maintaining v6 will cost more than developing a new one
Sob
Wed Jul 04, 2018 7:58 pm
Except when v6 will become a deterring factor, it will be too late. It isn't easy to fix damaged reputation.
mistry7
Wed Jul 04, 2018 8:26 pm
the customers answer of missing features, don't buy it
mirhav
Thu Aug 23, 2018 1:51 pm
After these years, I do not expect any serious answers to come from the Mikrotik. .... Ubiquity is much more flexible in communication ... another region, another morality
alidamji
Sat Sep 29, 2018 7:12 pm
V7 beta seems to be already in development. You can see mrz's post:
viewtopic.php?t=130551
Seems to be v7beta running on Virtualbox.
buset1974
Sat Sep 29, 2018 7:49 pm
true endeed
joegoldman
Sun Sep 30, 2018 2:07 pm
I've been forced into ubiquiti for Wireless gear (PtMP Sector -> CPE networks), comfortably finding 27dbi, 29dbi dishes , 20+dbi sectors and a functioning proprietary high-speed AC protocol beat out Mikrotik systems - but FUCK ME if Ubiquity's management tools are absolute shit compared to Mikrotik / Winbox - talking purely over 500+ms links here my ubiquity web-portals are constantly timing out, where I can manage my RB1100's spread out over the same country fine (still use Mikrotik for routing and PPP termination).
wispmikrotik
Wed Jan 02, 2019 10:28 am
2019?
ofer
Wed Jan 02, 2019 10:57 am
2019?
Router OS v7 is never going to happen.
wispmikrotik
Wed Jan 02, 2019 8:29 pm
2019?
Well ... so let's get routeros v8.0.0 ...
:lol: :lol: :lol: :lol:
mrmut
Fri Jan 25, 2019 2:58 am
Maybe they will release v13 out of joke. :-)
Numbering doesn't matter, I am happy with them as it is.
Vitis
Fri Jan 25, 2019 11:12 am
Are you also happy with VRF implementation? :wink:
mrmut
Fri Jan 25, 2019 11:31 am
I had to google VRF to see what it is, so I guess the current implementation is just fine by me :-)
pe1chl
Fri Jan 25, 2019 11:41 am
Well today the numbering is usually enforced by marketeers and it could well be that a next release suddenly is called "2019" or whatever symbolic name.
But I agree that it is quite unlikely that we will ever see a version 7. There will undoubtedly be some creative move to work around that.
cgood
Sat Jan 26, 2019 12:28 pm
unsubscribe ...
  • MTCNA 99% '17
    MTCRE 89% '17
    MTCTCE 89% '18
enzain
Wed Jan 30, 2019 10:48 am
When?
We need multicore BGP (different peers connections on diffirent cores is minimum)
NAT64, DNS64, etc
Full OVPN support (compression, UDP)
etc.
enzain
Wed Jan 30, 2019 10:49 am
When?
Minimum - is multicore BGP
connorgoodwolf
Thu Feb 21, 2019 8:26 pm
Many are exceptionally disappointed at MikroTik's transparency on the release of RouterOS v7.0.
If MikroTik is unwilling to be transparent at the very least they could do is help RouterOS become Open Source so those who care about the platform can assist in development. Many of us have the skills needed and are willing to sign agreements with vendors to help push Mikrotik ahead.
Currently Mikrotik's lack of a roadmap, transparency, implementing standards like VXLAN which is documented by IETF in RFC 7348 is causing Mikrotik adoption to slow and companies are starting to choose competing products like ubiquity. Releasing new hardware isn't "helping" adoption, so please refrain from making statements like, "We're releasing new technology."
The ball is on your court MikroTik:
1) Choose to be transparent
2) Choose to work on Open Sourcing RouterOS
3) Continue the nose dive, destroy the company
Connor Goodwolf | IOWolf LLC | +1 412-423-8779
Technology Consultant | MikroTik Enthusiast | LinkedIn
normis
Fri Feb 22, 2019 2:12 pm
What do you mean? We have been very open about it.
V7 is not ready for public release, however, development continues. When it will be released? When it's stable enough. That's all.
Chupaka
Fri Feb 22, 2019 3:31 pm
"MikroTik. Destroying the company since 1999. For 20 years already." (c) :lol:
P.S. OMG! RouterOS is 20 years old this year?!? What's the exact date?
normis
Fri Feb 22, 2019 3:35 pm
Only RouterOS v2, but there was another one.
1995	Arnis and John start to provide Internet services to local businesses.
	Wireless network project in Moldova.
1996	SIA “Mikrotīkls” is incorporated. The name means “Small network” in the Latvian language.
1997	Starting work on a routing utility, which then is a MS-DOS program and is called “Tik” software system.
	PC routers based on 2.4GHz Aironet platforms IC2200.
1999	Installations in Kosovo and the first Linux based RouterOS v2.0
Chupaka
Fri Feb 22, 2019 4:52 pm
So, the first version of RouterOS was RouterOS 2.0, that's why I'm asking :)
boldsuck
Fri Feb 22, 2019 6:50 pm
Yes, then the Mikrotik hardware would finally openWRT friendly.
For our "Freifunk" projects in Germany, we mostly use / recommend AP's from Ubiquity or TP-Link. Every DAU can flash openWRT on it. Both companies are very community friendly. Sources per ftp downloadable. To send on CD as Mikrotik, is a nasty joke. ;-)
╰_╯ Ciao Marco!
connorgoodwolf
Sun Feb 24, 2019 11:08 am
Can you please define the definition of transparency? I'll save you some time, "the quality or state of being transparent".
All you have told us since 2015 goes along the lines of "v7 is currently in internal testing, and will be released as beta when it's stable enough"
I don't like being direct, but what Mikrotik is doing to people who've spent years around Mikrotik hardware, certifications and dedication is wrong. You're hurting not only Mikrotik by not being transparent or forthcoming, you're hurting us.
Items YOU need to address:
1) A graph or document indicating the current status of RouterOS v7.0, even if the features are in flux.
2) Missing standards which will not be targeted in RouterOS v7.0, i.e. VXLAN
3) Update the community with facts and projections on current development
This whole situation would be made easier if Mikrotik had a developer program to work on an open source side project. It would not be hard to set up a lab, virtualization platform or real testing hardware for those who want to be serious about contributing.
normis
Mon Feb 25, 2019 10:40 am
Those are subjects to change. I don't want to promise anything and later tell you that we decided to remove something, or similar.
vecernik87
Long time Member
Long time Member
Mon Feb 25, 2019 11:44 pm
Hey guys, stop harassing Mikrotik about V7 :D It is a good topic for jokes but bad choice for serious discussion.
I am not a blind fan, but in this case, @normis is right. Anyone, who ever did a continuous development, knows that specifying future dates of release is a suicide. If you don't make it on time, everyone will complain (and it will be legit because promise was not delivered). If you rush it and make mistake/bug, everyone will complain (and it will be legit because even a simple bug can cost business millions).
Can't you be just happy that there are free updates which not only fix security holes but also improve functionality? And you can get all of that with device prices starting at $50?
In addition, demanding things this way is a bit ridiculous: "what mikrotik is doing ... is wrong" , "you need to address". Cmon... are you a shareholder or what? :lol:
Yeah. They flexibly told me that their products will misbehave if power is lost unexpectedly and the only solution is factory reset and restore from backup. Unfortunately I am stuck with them on three hospitality sites...
Sob
Tue Feb 26, 2019 4:32 am
I think the idea is that after years in development, it should be slowly shaping up and they should be getting some rough idea what it will contain and when it might come out. This very thread is four years old, and third post already mentions the "codename" unicorn. And that popped up only after some time of waiting, when people started to think that it maybe takes a little bit too long. And again, that was four years ago. I wanted to add "when I was still young", but it hasn't been that long, my chances to see RouterOS v7 are still good. :D
connorgoodwolf
Tue Feb 26, 2019 4:59 am
This is apart of the development process, many of us are the people who build complete platforms and architectures from the ground up. Even if a timeline or development status stated there was work on a specific feature which was later removed during a release then people would be enthralled there's at least some level of transparency.
Nobody is saying "promise us this," if you're working on an idea/feature/standard which doesn't make the cut then we may be a bit disappointed but it's better than "we're working on it"
connorgoodwolf
Tue Feb 26, 2019 5:02 am
All network equipment should have UPS units with AVR, to not have conditioning and backup power supplies attached to radio and networking equipment is asking for trouble.
zandhaas
Tue Feb 26, 2019 2:55 pm
Totally agree :!: :!:
telcouk
Tue Feb 26, 2019 4:31 pm
Without sounding harsh, I think you would have been better off not telling us about v7 if that's the case.
We would not have invested in Mikrotik kit and would have a fully working IPv6 setup by now.
normis
Tue Feb 26, 2019 4:53 pm
We have not advertised v7 as a version. The first post in this forum thread is by a user.
MikroTik only mentions v7 if there is some feature, that can't be implemented because of kernel limitations. In that case, it's technically not possible to make something until we have new kernel.
Other than that, have we told you there will be a v7 soon?
Sob
Tue Feb 26, 2019 6:06 pm
You didn't, but since the first time someone from MikroTik said "sorry, feature X is not possible now, it needs new kernel", the clock started ticking in users' heads. It's mix of optimism and trust, they (want to) believe that you want to give them the best and the right time for that is now, or at least soon. :)
Jotne
Tue Feb 26, 2019 6:12 pm
No??
Who created the subforum with the name RouterOS v6 RC and v7 BETA?? A user :)
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
telcouk
Tue Feb 26, 2019 6:21 pm
Just google, site:mum.mikrotik.com "v7"
Also what Jotne said.
#facepalm
connorgoodwolf
Tue Feb 26, 2019 6:34 pm
You know what would help fix this? Having an open source version of Mikrotik. Some of your users are the engineers who develop operating systems, have worked on various OSes including integrating code from KAME in to the BSD projects.
If there's a new kernel required, or a code in an existing kernel which needs to be modified, then perhaps this is the time to be transparent with the community.
Perhaps this is the time to engage the community and inquire if there's any interest in having a community driven project for Mikrotik hardware.
joegoldman
Wed Feb 27, 2019 12:28 am
The development going into 6.x is development FOR 7.x as well. A lot of the roadmapped features have been put into 6.x because of the delays 7.x brings. 7.x isnt going to suddenly have a heap of new features, 7.x will likely be the latest 6.x but on new kernel, and will take a few iterations to start getting new features that were otherwise impossible on the 6.x kernel - for instance my main feature request as of right now would be VRF aware management services and better VRF implementation over-all - my understanding is that this is a kernel limitation in 6.x, but i wont be expecting this feature in 7.0beta1, i'll probably not expect it till 7.5 or later, just because the first few iterations of 7.x will be just making sure everything runs as expected on new kernel.
Development is time. There's not an unlimited amount of developers working on this, and they are obviously still pumping out 6.x (230 odd changes/fixes in current changelog, massive!) so you just have to be patient - if you want massive company resources and promises, go spend massive dollars on Cisco/Juniper/whoever.
huntermic
Wed Feb 27, 2019 11:24 am
Fake News!
Sorry, this is the first thing that i think of when i read this crap.
You do sound a lot like Trump in this regard, you just can/will not tell the truth.
normis
Wed Feb 27, 2019 11:33 am
Sorry to break the news to some of you, but the official stance has always been - use v6. We are working on v7, and it will be released when it will be ready.
huntermic
Wed Feb 27, 2019 11:49 am
Correct, that indeed is the thing you keep telling us.
The problem we have is that for many years now you refer to this V7 and there even is a subforum called V7Beta, this raises expectations that after many years turn into frustration
normis
Wed Feb 27, 2019 11:56 am
I can repeat again, we only refer to v7 if there is something that can't be implemented in v6 due to kernel limitations. It doesn't even mean v7 exists.
mistry7
Wed Feb 27, 2019 12:00 pm
Developing on old Platforms often costs more ManPower then needed, there are so much changes in 4.xx Linux Kernel, why invest the time to back port them?
And it happend what i promise last year, Linux kernel is now at 5.00 and we don't see anything about ROS 7.......
We even don't know on that Kernel ROS 7 would be based.....but it would be outdated from the first day it released on....
huntermic
Wed Feb 27, 2019 12:07 pm
In that case, please do not say V7 but instead say: Some version we might release in the (probably distant) future
nescafe2002
Long time Member
Long time Member
Wed Feb 27, 2019 12:10 pm
Really?
huntermic
Wed Feb 27, 2019 12:12 pm
Really?
Why not, holds the same informational value: nothing
connorgoodwolf
Wed Feb 27, 2019 4:45 pm
ZERO TRANSPARENCY
normis
Wed Feb 27, 2019 4:46 pm
When is the new Tesla Y model coming out? What features will it have?
Which company, even the transparent ones, give you information about unreleased products?
connorgoodwolf
Wed Feb 27, 2019 4:51 pm
Elon has stated publicly the release of information about the model will come out around March 15.
When will we see a roadmap for v7?
connorgoodwolf
Wed Feb 27, 2019 4:52 pm
The current kernel needs quite a few modifications in order to accommodate much needed improvements.
normis
Wed Feb 27, 2019 4:55 pm
Before he said that. You didn't know about March 15, right?
OK so, please wait for a similar statement.
telcouk
Wed Feb 27, 2019 4:58 pm
We've been patiently waiting 5+ years :/
connorgoodwolf
Wed Feb 27, 2019 5:07 pm
How about you get the big boys at Mikrotik to the table so we can have an adult discussion?
You're only showing us how worthless the MikroTik training is since there is "no v7", no road map, nothing to show, no transparency and no engagement for the community who would gladly work on an community distribution (sort of like how people can load SwOS).
anav
Wed Feb 27, 2019 5:46 pm
@vecernik87
Wait, isnt this poster the magic unicorn? Even the magic unicorn doesn't know when v7beta will come out and thus we are all being treated equally. By the way buset1974 is obviously a student of software engineering and knows of what he speaks, the rest of you yahoos are smart as whips but on big picture stuff not really. Anyway, the real question is what will happen first, v7Beta released or a fricken stable version of Apex Legends.........
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
ofer
Wed Feb 27, 2019 9:15 pm
Same here I'm willing to join forces towards a community driven project.
patrick7
Wed Feb 27, 2019 9:16 pm
At least you can repair a broken tesla. But we can't repair RouterOS. BGP has been broken for 5+ years now and nobody knows when it will be fixed.
Oh, sorry, we do! It will be fixed with RouterOS v7 (tm)
connorgoodwolf
Wed Feb 27, 2019 9:25 pm
I'd be interested as well. A community driven firmware could push MikroTik back in to the limelight, but as right now they're falling to the way side.
Sonnix
Wed Feb 27, 2019 9:47 pm
Since there is no v7 can we get a road map for udp support for openvpn which was requested 10 years ago? Or multi-thread BGP? Or for any other similar request? Because in threads like that we get an answer that it will be added in v7. So we start asking for v7. And now we get an answer that there is no v7. You see the problem here? Either give a road map for features or for v7 with the list of features to expect. Or if it's going to be another 10 years of waiting at least tell us that we should not expect any improvements any time soon so that we can move to another brand. Right now answers "it will be included in v7" or "we are working on it" hold no value at this point as as we hear them for 10 years and nothing changes.
Also some of the features can be solved if there was support for metarouter, containers or something similar for new devices.
dynek
Wed Feb 27, 2019 9:51 pm
Forget about OpenVPN, go straight to Wireguard :-)
connorgoodwolf
Wed Feb 27, 2019 9:58 pm
We should email the executives of the company starting with Mr. Tully.
John Tully - CEO
tully@mikrotik.com
If people can provide contact information for the other executives then the rest of the community would be exceptionally appreciative.
I've sent Mr. Tully the following,
Mr Tully,
I'm writing you due to a conversation on the forum which clearly indicates there's no transparency or any plan for RouterOS v7. Many Mikrotik support staff and developers have made statements "v7 will come out soon" many years ago.
Mikrotik's software is rotting, we all know this, there's BGP issues, lack of proper OpenVPN support, lack of supporting standards like VXLAN and so on.
The community would be appreciative if the build tools could be released for building the base kernel + tools used to create a custom empty firmware. I'd be interested in driving a community effort. Mikrotik makes great hardware, I've been mikrotik for almost a decade, but the community needs to be the driving factor for the software.
honzam
Wed Feb 27, 2019 11:50 pm
Good idea. Write us the result...
honzam
Thu Feb 28, 2019 12:07 am
Normis:
Your post from 08Jan 2015 - v7 is currently in internal testing, and will be released as beta when it's stable enough
Your post from 06 Feb 2015 - We will release a beta, when it will exist. Currently v7 is in alpha stage, many functions are not completed and non functional. Beta needs at least all functions to be somewhat operational.
This topic about V7 was created itself?
And now you say V7 is not a version? Are you kidding?
I understand you can not say anything, but do not make fun of us at all
whitbread
Thu Feb 28, 2019 12:45 am
Sry Mikrotik - your public relations behaviour is a total desaster when it comes to this topic.
This is a user forum. So I don‘t expect u guys to do the right thing nor do I expect that u even know the truth. We all know that here and there especially software projects might end in a desaster. In combination with the announcement years ago there is a dramatic chance, that ur development is lost in space, i.e. will never been finished.
This would be a desaster for the community but it will hit others even more if their business is based on your products.
Answering ‚it will be ready when its ready‘ is not an option anymore after years of ‚coming soon‘ answers. But this is again something I would expect to be dealt with by you board. So there must be anything more serious than ‚alpha status‘, ‚coming soon‘, ‚not ready yet‘. If you are lost in space and don‘t believe you gonna make it shortly - plz tell us. This will be the better option and will let u determine the right action to be taken.
mistry7
Thu Feb 28, 2019 2:50 am
All unfixed Problems with ROS, where we get the answer, „will be fixed in ROS7“ show us how Mikrotik cares about there costumers, we decided last year to not buy Mikrotik Wireless anymore because of ARM NV2 Issue, what looks like it fixed now. (first issues told to support on Xmas 2017. viewtopic.php?f=7&t=128916&p=633371&hil ... v2#p633371 -to now, so it is about 13 month for this fix) and in all this time nothing as information so I think it is not possible to do serious Business with Mikrotik.
Same with Spectral Scan, missing since 2014 in ac based Devices (now with over brand on our network we see how much pain it is to miss this feature)
Same with IPv6 PPP delegated Prefix (we wait for 6 years I believe)
Same with Open VPN UDP support (we wait for more then 10 years)
Wave 2 support until Mikrotik is selling Wave 2 Hardware for more then A year now,
The next Standart is right on the corner, and support for the actually one is not Given...
But this is a think we don’t care anymore, there are overs with software that has this features.
We will run out of IPv4 Adresses this year so we need a working IPv6 Solution, but I don’t
believe Mikrotik get this ready this years, so we need to look around for our Routing and PPPoE Srvers beside Mikrotik
Mistry7
normis
Re: RouterOS v7.0 beta1 - when?
Thu Feb 28, 2019 9:12 am
Normis:
Nothing has changed from that time. Please suggest what answer you wanted to hear.
mistry7
Thu Feb 28, 2019 10:22 am
We are not able to do Business decisions with a maybe or "in near future"
normis
Thu Feb 28, 2019 10:23 am
Assume 'never', until other announcement is made. Why are you trying to speculate a release date for something that will not be stable when released?
pe1chl
Thu Feb 28, 2019 11:02 am
The problem is that the delay has been so long and the expectations have gone op so high that it has become almost impossible to release something that will not cause a lot of criticism.
You should just have made a v7 with new kernel at some time (already enough work to forward-port all customizations that apparently have been done on the kernel), first as a "development" release then later as some form of beta, and then work from that new base to introduce new features that require the new kernel similar like how new features are introduced in the 6.x version.
Probably while keeping development on 6.x (by backporting new features that do not require the new kernel) for some time until the new platform is considered "stable".
But now you can't do that anymore because when you now release a v7 that is just a 6.44 with new kernel there will be a large uproar.
And there is no need to continue development of an "all new v7 with new routing engine and this and that and that" and release it as a single new version, because you will never be able to make that happen in a company without unlimited resources and while continuing support of a version 6. It will always remain a back-burner project that gets too little attention.
(which it now has been for about 7 years)
normis
Thu Feb 28, 2019 11:06 am
Very good response pe1chl, you are getting it.
Anyway, I am just trying to keep expectations mild. Most development is done on v6, as you can see from all the new features, fixes and huge changelogs.
genesispro
Thu Feb 28, 2019 11:48 am
out of curiosity...
which are the key features that the new kernel has that they cannot use at the moment in this kernel?
In other words what would make a big difference (feature or improvement) and CANNOT be implemented in the current kernel?
I am not questioning, I am wondering
Sonnix
Thu Feb 28, 2019 1:48 pm
If release date for v7 is 'never' than the answer we wanted to hear is the release date for every requested feature. Or if there is no release date and we should not expect it in near future then we wanted to hear an answer 'never' for that feature instead 'it well be in v7'. Just stop mentioning v7 in feature requests if there is no v7.
normis
Thu Feb 28, 2019 1:52 pm
It is not never. I suggested to stop worrying about it and use v6.
About the features, which features do you need? Remember that MikroTik does not implement features by demand. It might not be feasible or possible to make something. Everything has to be evaluated individually.
onnoossendrijver
Thu Feb 28, 2019 2:25 pm
The only feature that makes me sometimes buy from the other guys is ipsec with VTI support. So please implement this :)
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
Sonnix
Thu Feb 28, 2019 2:55 pm
The feature I'm personally interested in is udp support for openvpn which was requested in 2008. It's not even a new feature just an extension of existing one. It was never stated that it is not feasible or possible.
Instead we get answers like this:
viewtopic.php?f=1&t=26499&start=100#p617477
Should we consider such answers an 'never' now? Or will some reasonable timeline be given for this feature instead of promised v7?
paoloaga
Thu Feb 28, 2019 3:49 pm
For my company IPv6 recursive lookup, faster routing table updates (BGP/full view) and IPv6 route reflection are really important.
(edit: forgot one feature).
telcouk
Thu Feb 28, 2019 5:44 pm
For ourselves it would be:
IPv6: iBGP with OSPFv3 using loopback addresses (OSPFv3 uses link local addresses which is breaking things).
BGP: Faster routing table updates
patrick7
Thu Feb 28, 2019 8:19 pm
Also things like delete-bgp-communities, which is probably a 3 liner of code.
But due to some strange reasons MikroTik refuses to touch any routing daemon (exceptions are made for serious bugs).
honzam
Thu Feb 28, 2019 8:45 pm
As a WISP - I'm primarily interested in wireless so I'm interested about spectral scan on AC. And wave2 support?
Will we wait for it in version 6.x or wait for the V7 that will never come?
LAN, FTTx, Wireless. ISP operator
schadom
Thu Feb 28, 2019 9:42 pm
+1 for increased BGP performance and security:
- faster routing table updates !!!
- faster route matching (via /ip route print where x)
- RPKI ROV support (see https://rpki.realmv6.org)
Sob
Thu Feb 28, 2019 11:01 pm
... when you now release a v7 that is just a 6.44 with new kernel there will be a large uproar.
As many other people, I also expect that when v7 comes out, my router will be able to do anything I've ever dreamed of and more, and make me a coffee on top of that (without any additional hardware required, that's how great will v7 be).
But realistically, just kernel update without anything else would be reason to celebrate. Not that users need it that much (they don't need to care about what's inside, as long as it does everything they need), but lack of new kernel was given as a reason by MikroTik several times, why some feature can't be implemented, so it would remove one important obstacle.
doush
Long time Member
Long time Member
Thu Feb 28, 2019 11:33 pm
How come new high-performance tilera replacement products can come without the new kernel ?
I dont think many modern CPUs supports the ancient mikrotik kernel nowadays.
pe1chl
Thu Feb 28, 2019 11:52 pm
The point is that many new features have been postponed for many many years "until v7" even when they do not require a new kernel at all!
(e.g. a complete implementation of OpenVPN, which can run on much older kernels than is now in v6, or better IPv6 functionality)
v7 has become synonymous with "able to do anything I've ever dreamed of and more, and make me a coffee on top of that" mostly due to those repeated replies to feature requests.
And I think many users have not read that as "ok first we have v7 and that brings us a new platform to build new features in later 7.x versions".
No, they now fully expect that version 7.0 will include all those "will be done in v7" features, making it a huge development effort and almost impossible to get right.
telcouk
Fri Mar 01, 2019 1:07 pm
There is obviously a huge stumbling block as to why a kernel upgrade has not happened, either in a 6.x version or the unicorn v7.
Let’s not forget that Mikrotik is mostly made up of open source software, maybe one or more elements can’t be upgraded to a more recent kernel?
My guess is that it’s fast path / fast track… They both rely on the route cache, which isn’t available in more recent kernels.
Paternot
Long time Member
Long time Member
Fri Mar 01, 2019 4:13 pm
Mikrotik writes its own drivers, and maintains its own kernel patches to the Tile CPUs. It is open to discussion if this is a good decision, but I don't know enough (both of the internals of Mikrotik business and of driver development) to have an informed opinion.
anav
Fri Mar 01, 2019 4:57 pm
Ive written my letter to Tully CEO.
It says.
"Don't listen to all these yahoos on the forum that whine about v7. Keep providing stable secure releases with the fixes that can be managed with the resources you have. Regardless of the brand of networking equipment, there is always a huge crowd of unsatiated users demanding more. The challenge is to maintain focus and keep abreast of actual changes in standards.
If and when you wish to relocate Mikrotik to Canada, I will help as best I can. I have a tent on our property and we are painting Normis's name on it."
buset1974
Wed Mar 06, 2019 2:48 am
some cases promise fix on v7 are not fix yet on v6 thought.
BGP withdraw on PE-CE, OSPF NSSA, etc.
Please fix the issue without waiting for v7.
Problem above are not cosmetic features, you're product are world wide used now, not just as CPE but also PE or CORE and those issues already known years.
PtDragon
Wed Mar 06, 2019 10:00 am
normis, Some months ago i suggested that your company can post small monthly updates(just a little bit of info what progressed in last month for v7(roughly what you worked at last month), any of developers can do that in just some minutes).
Because right now all we know that is that you work on something and its not ready yet.
Correct me if i'm wrong but it looks like an easy thing to do.
P.S. I really wait much for new queue types for easier latency management.
jimmer
Wed Mar 06, 2019 10:24 am
I too second the faster and more secure BGP updates as well as better handling of multi core devices with respect to routing and filter rules.
Since 7.0 has become the Duke Nukem Forever of the RouterOS world maybe skip straight to RouterOS X (10) so the stigma of the Neverending release date can be put to bed :)
I do like where development is heading but I do feel that RouterOS is getting a little behind the competition, go back a few years and it was definitely leading, I will be sticking with RouterOS, I wont be returning to the Cisco camp (since i've replaced all of our Cisco kit now) but Mikrotik does need to prove it's willing to challenge the competitors, the 6.x tree is slipping - it's now 7 years old.
Kind Regards,
Jim.
joegoldman
Wed Mar 06, 2019 11:57 am
THE GOOD NEWS IS, that once RouterOS is brought up to date on 4.x kernel - it should be a fairly straight run to keep it updated. The Linux Kernels are not feature releases, meaning the diff between 4.20 and 5.0 is just patches, not a huge new architecture or anything. We just gotta make this one big jump and hopefully smooth sailing.
However another thing I'm really keen for - and I'm not sure if this was an old kernel limitation or not - is proper /31 support. I'd love to use /31's for PtP without muck-about rules and static routes.
Chupaka
Wed Mar 06, 2019 12:27 pm
But for now it's RouterOS 9 ("Nein" in German) :lol:
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
ofer
Wed Mar 06, 2019 2:42 pm
Don't worry you'll have RouterOS 7 soon enough.. (when pigs will fly)
buset1974
Wed Mar 06, 2019 6:04 pm
When RouterOS v7 beta1 is gonna to be released?
This is the first question from this thread in 2015.
now is 2019, next year is 2020
thx
jarda
Wed Mar 06, 2019 9:40 pm
Ages are not ending by 2020.
TimurA
Wed Mar 06, 2019 10:10 pm
someone may not live :D
jarda
Thu Mar 07, 2019 12:45 am
May not... But others will be borned.
Paternot
Long time Member
Long time Member
Thu Mar 07, 2019 12:46 am
The cycle of RoS?
borisk
Sat Mar 09, 2019 7:35 pm
Guys, what are you arguing about? Everyone of us knows the v7 release date. Really. Just a mathematics. We are at 6.44 now. Each release requires 3-4 months. So.... 700 - 644 = 56 release cycles. 56 * 4 / 12 = 18,(6) years. So, the year 2037 will be year of 7.00 release!
P.S. Don't thank
Sob
Sat Mar 09, 2019 9:05 pm
Fortunately for us, it's not regular number but version number, it has different rules (which means no rules at all, total anarchy :)).
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
anthonws
Sun Mar 10, 2019 12:19 am
Context: Long time (home) user, lurking in the forums, enjoying reading change logs and all the advancement that Mikrotik is doing.
Perspective on the topic: I can see that Mikrotik could definitely improve their marketing and messaging around the roadmap of their products and the future investments.
In the current era, customer engagement is for sure a very deep and important part of any company. Specially when it's aligned to innovation.
Customers often invest more in a vision, and a partnership, than actually a change log or a vain/shallow promise of something that is totally unclear and not transparent.
I'm sure everyone that is sticking around knows that Mikrotik is a commercial company, and therefore needs to be profitable, and that resources are not unlimited, but customer engagement (like stated above) is (in my perspective) vital.
So, in essence, albeit the fact that it's important to follow standards and not investing in areas that are not aligned to what the industry is doing, would it hurt to create focus groups, composed by your most trusted and recognized customers (WISP, trainers, architects, etc.) and get feedback flowing into the community? "It's ready when it will be ready" doesn't provide your customers the trust and openness that they expect.
Sharing something (that doesn't compromise your IP and competitive edge) with the community, even if saying in bold letters "Dates are subject to change", is a growing, and quite common, practice.
There are several successful projects out there that do it in a very intelligent way, without requiring a horde of resources, and the benefits are quite visible.
Remember that it's all about the journey. I'm sure that 99% of the people still sticking around and replying in this forum, they are here simply because they care. Because they once believed in Mikrotik's "Why".
Although it's vital not to lose your eye on the "Why", it's still of upmost importante to make sure you explain the "What" and "How" properly.
My 2 cents,
anthonws.
hugleo
Mon Mar 11, 2019 5:32 pm
/31 support
rupeshkafle
Wed Mar 13, 2019 1:31 pm
About features, due to adaptation of IPv6, IPv6 route marking should be implemented ASAP. Also recursive routing should be supported for easy implementation of BGP on IPv6.
ofer
Wed Mar 13, 2019 2:07 pm
P.S. Don't thank
my estimation is 1 - 2 years
plankanater
Mon Mar 25, 2019 3:14 am
would love BGP information sent via SNMP
crcro
Wed Mar 27, 2019 10:41 pm
please fix bgp issues now ... no more v7 please! working with mikrotik routers several years now and i try to use them as little as possible when bgp is needed!
no info about bgp in snmp
slow search in routing table
slow prefix/filter list updates
even on high end routers like CCR*!
what is the reason for high memory and high cpu count if you can use them properly?!
Takv
Thu Mar 28, 2019 1:48 am
RouterOS v7 MUST include stable x86-64 architecture for PC. New and old ethernet drivers compatibility, and/or the ability to install custom drivers from linux repositories.
Regards.
Chupaka
Thu Mar 28, 2019 2:50 pm
You forgot "make me a coffee" button.
Takv
Thu Mar 28, 2019 5:01 pm
You're right, but lot of people concerns (including me) about the x86-x64 PC support through the forums. So we need a real "official" industrial coffee machine for all.
Takv
Thu Mar 28, 2019 5:16 pm
In fact, Mikrotik started as a software development company, and now, starting from 4 to 5 years ago, they have some kind of company secrecy around the upcoming major RouterOS software update, or they are just focusing in hardware development, forgeting they origins. Not in vane they have begun speaking about v7 version five years ago, or is it? So, the less they have to do is to incorporate the most old complains in the major update. We are talking about x86-x64 PC Image, the ethernet driver extense support and all related to ipv6 and bgp, also including the present and stable NV2 AC and Wave 2 support, at least. You have to just look, there is so many complains in the forums never ever solved...
mfr476
Thu Mar 28, 2019 9:16 pm
No news about Ros 7?
patrick7
Don't worry. I'm sure it will be fixed with RouterOS v7
mada3k
Sun Mar 31, 2019 12:55 pm
I think there's a high risk that some architectures/platforms will be stuck on ROS v6 for flash-size and toolchain reasons. v7 will probably be ARM and x86_64 only, and will probably lack some features thats simply not portable (I guess MPLS- and tunnel stuff).
Manages some CCR's, RB750Gr3, RB922 and wAP's
nz_monkey
Mon Apr 01, 2019 12:38 am
This is my expectation as well.
rkj
Tue Apr 02, 2019 12:41 am
Something I believe is missing from the feature requests I've read is network telemetry (https://blogs.cisco.com/developer/its-t ... -telemetry) ; SNMP should stand for "Scalability Not My Problem" in how hard it's to make a thousands elements service provider network manageable. My guess is that it would also ease up the CPU load of boxes when WinBox is connected to them.
vecernik87
Long time Member
Long time Member
Tue Apr 02, 2019 4:00 am
re. network telemetry: Well, idea in theory is nice but I find monitoring through highly-abstract layer a bit suicidal. As long as it works, it will be great, but there are few points:
- it definitely won't ease up CPU load (because HTTPS is way more intensive on CPU and bandwidth than SNMP),
- if something goes wrong, it will be way harder to troubleshoot. Look at many network elements (including UBNT, DLINK, TPLINK, mikrotik's SwOS etc etc..) - the least reliable module of most devices is always the web interface/server. And now you want to run realtime monitoring via this module? cmon.
- even now, manufacturers are unable to properly implement universal OIDs in SNMP and too often they implement their own MIBs. I am desperately trying to monitor important devices in my companies through dude, but every manufacturer makes their own way of recording elements. No matter if we talk about printers (and remaining toner), no matter if we talk about UPS (and available capacity or output load). Do you really believe they will somehow magically work together and make this working? universally? nope, not gonna happen. In the best case we get many different proprietary implementations, one from each manufacturer, which won't be compatible. In the worst case, some manufacturers will come with different version for each of their brands and they won't work together.
edit: actually about the push/pull method... I am actually thinking that pull method might be more scalable than push method. Thing is, that with push method, all devices will keep pushing data to controller node. But what if the node becomes busy? or just overwhelmed because there are to many devices? With pull method, controller can easily schedule requests based on requirements - critical data can be polled every few seconds, less important data can be polled once a minute. More important devices can be scheduled more often, less important devices can be polled rarely. Or even if there is some critical task, controller can postpone polling of other things temporarily. See? this is the actual scalability based on controller's configuration.
MasterJames
Thu Apr 04, 2019 3:26 am
Wow this is the biggest blunder in the history of the internet.
Such a shame since RouterOS is great except for this problem with IPv6 in general.
This should be open sourced before they go under. Really it's pretty much to late.
I say open source RouterOS 7+ now or die. Release it for the community to make it work. At least they will be able to try and do something.
As long as they get what they need working, other parts can be addressed over time, and not by waiting over 10 years <SHOCKING>.
This is so bad I think you are really left with corruption as the only explanation, (trying hard not to be paranoid) that and incompetency that is not being addressed.
Incompetency can be resolved. Retardation of an entire corporation is mind boggling. No one is at the wheel.
Or get some financing to hire as many experts (all on here waiting for a decade) to add what seems like a simple enough thing.
Can I install https://dd-wrt.com/ DD-WRT on this RB4011 paper weight? Will a refund on my new RB4011 send the right message or should I hope my loses will help support a company that has passed the point of no return, and think maybe it will be usable in a few years,
If we get some kind of source we can replace or another company can maybe take charge. Can this be given to apache.org or something?
How can we as a community get Mikrotik to allow us to take the wheel and get shyt done!? Can we start a class action lawsuit? I'll sign it, I have losses due to negligence. We need to decentralize people. For the Grid with Arduinos or similar (I'm for WiFi GPUs in light-bulbs?).
A boycott? A petition? anything. Something to through a stone at maybe?
Okay so what's my alternative Cisco? Does their GUI need Java so lame or lamer are my two choices. Bummer. "It's mi way or the Huawei." [ No there out too. ]
I know this sounds like a rant but it feels like I'm drowning. So desperate to find real solutions. Best one I can think of would be to open source RouterOS.
Is this link below anything, a download archive of binaries or what? Is there a Git Repo for RouterOS. Who can explain why that is not possible? If not, I think I'm done, because 5 years ago was the time to act on this idea. It's really too late for even that. Just stop fixing ROSv6 it's dead without IPv6. Divert all resources to release even a borken alpha as soon as possible.
https://github.com/robimarko/routeros-GPL
I've burned uncountable hour$ smeared over a number of months tracking down this horrible truth about RouterOS' grievous incompetency. It makes me & us look bad and has jeopardised many other companies with similar pointless losses too. [ It's no longer worth my time to pursue this route. ]
Okay so it's too bad it does not even make coffee but it probably has enough juice for that.
If Mikrotik sold to Google, Google would conclude to do the right thing and shut it down in about 9 days (a current statistical fact about google these days see Google+ etc.).
Can I get on a mailing list for when ROS7 is available just so in another 10 years I can have a good laugh?
Okay now I go get a couple of boxes of paper towels for my tears I'm drowning in.
My final thought to share is that we could have a mass burial. This idea will create a release deadline so on Bury Your Mikrotik Day say April 1st 2020 (joke is on us), we all just say a final goodbye together to a tragic death of a good friend, cut down in it's prime by what is best defined a stupid senseless crime against humanity.
Sob
Thu Apr 04, 2019 4:09 am
Interesting find, that repository. A 12MB, 400k lines kernel patch, it looks like good explanation why it's not easy to just swap kernel for newer one.
anav
Thu Apr 04, 2019 5:00 am
No worries, mate, just ship all your latest MT products to me I will take them off your hands and will pay shipping LOL. In Nova Scotia, we help you part with those things that are stressing you out. Its the least we can do. Things are so chill here. :-)
Omniflux
Fri Apr 05, 2019 4:42 am
Jotne
Re: RouterOS v7.0 beta99 - released.
Fri Apr 05, 2019 8:11 am
From the video:
7.00beta99 so long past beta1 as the title asks for :)
MikroTik->Splunk
mkx
Fri Apr 05, 2019 8:28 am
From the video:
Perhaps MT is counting down ... so next beta from the one shown in video (probably not current any more as @Normis hinted) was beta98 ... and so forth. So v7 will be released to public when count-down reaches beta1 :wink:
BR,
Metod
normis
Fri Apr 05, 2019 9:06 am
Arent jokes funnier if not published 4 days late?
P.S: this CGI business is getting out of hand
macgaiver
Fri Apr 05, 2019 3:16 pm
From the video:
I have seen v6.99, when MT is working on the fix/debugging of some crash fixed on our routers
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
schadom
Fri Apr 05, 2019 6:55 pm
@normis can you confirm the authenticity of this video? if real, this would be very nice!
Chupaka
Fri Apr 05, 2019 7:33 pm
viewtopic.php?p=725088#p725088 — isn't that about authenticity? :)
schadom
Fri Apr 05, 2019 9:20 pm
dude, honestly i'm not here for the lulz. we work with business customers and we expect clear statements from MT so that we can plan our next hardware purchases.
connorgoodwolf
Fri Apr 05, 2019 9:56 pm
I can't imagine what Mikrotik stock would be like if they were public. The stock would be more volatile than TSLA based on public statements.
anthonws
Fri Apr 05, 2019 11:57 pm
I think the plan is very clear if you're dealing with Enterprise customers. The "It's ready when it's ready" statement says it all :)
Me, as a consumer, I honestly couldn't care less. Sure, I'm unhappy for not having a couple of cool features, but my investment until now has been very low and I don't mind replacing everything tomorrow for something else that fulfill my needs.
connorgoodwolf
Sat Apr 06, 2019 5:50 am
Unfortunately some of us are in such a scenario where we must decide to work on a custom firmware solution for Routerboard devices or spend the money replacing all Mikrotik hardware.
pe1chl
Sat Apr 06, 2019 12:44 pm
I fully agree. "It's ready when it's ready" is what a hobbyist writes. Or a beginner.
A professional developer has a plan and a schedule, and can explain overruns of the schedule.
maara
Mon Apr 22, 2019 4:04 pm
This "It's ready when it's ready" approach is something that shouldn't be part of your PR if you are an enterprise company. If so, then your management is seriously lacking.
Chupaka
Mon Apr 22, 2019 5:52 pm
Just like Google, btw.
" - When are you planning to release that feature for Google Cloud?
- When it's ready, no ETA (c)
- <working hard to implement the feature in a self-hosted way>
- <in 2 month they release it>
- F*ck! Are you kidding? We could wait for those 2 month instead of doing a ton of sh*tty work!"
maara
Tue Apr 23, 2019 6:54 pm
Agree, yet Google is not selling any enterprise HW products and no customers are planning any new infra deployments based on their hw etc...
mkx
Tue Apr 23, 2019 7:15 pm
HW products by Mikrotik are mostly fine. It's mostly software which makes us sometimes unhappy. ROS7 is, after all, software which will, hopefully, run on our existing HW. All in all, this is not that far from what we expect from google ... only that for google's services you most of times pay with personal data and for Mikrotik's services you pay with hard cash and electricity ... and receive back some heat (you can't say that about google's services).
BR,
Metod
tesme33
Tue Apr 23, 2019 7:33 pm
Independantly when R7 comes , in the toolchain of Melanox it is stated that they use kernal 3.10.104 which was released 21.10.2016.
Mmmh this is really long time back. A lot of improovements have been implemented since then and i doubt that MT has the capacity to get all these benefits backported.
So which kernel will we get ? And Is this good or bad ?
http://www.mellanox.com/repository/solutions/tile-scm/
How this looks like for the other processors i didnt check. But at least the tile will get the new OS with hope of a better parallel CPU usage.
Chupaka
Tue Apr 23, 2019 10:25 pm
I was talking about Google Cloud Services. You pay for it in cash also :)
mkx
Tue Apr 23, 2019 10:34 pm
Well that sounds better (but still no heat in exchange I guess). Unlike majority of inhabitants of Earth I value my own personal data and choose to pay with cash ... it's much easier to decide if something is worth the price or not ...
BR,
Metod
mfr476
Tue Apr 23, 2019 11:49 pm
Mikrotik have a Big problem with costumers and product.... Forun Gurú not improve the result
irukandji
Tue Apr 30, 2019 2:18 pm
Omg, just ordered rb4011 and I thought something is seriously wrong. :lol:
IPv6? I didnt notice any lack of IPv4 addresses yet, so I wouldnt bother too much... Just relax.
(anyway until I am forced by ISP to use IPv6 and I wont have any chance to switch to some other, I will keep it turned off to keep my sanity)
mfr476
Tue Apr 30, 2019 7:05 pm
Wireless ac improvement It is other Big problem...
PtDragon
Tue Apr 30, 2019 8:26 pm
Guys, we have a lot to progress to, current kernel is 5.X.
That is cool that we have 7.x in development.
But still, even if it becomes a tradition that MikroTik programmers dislike - please post a bit about your progress every month(just some things you remember in 5 minutes, no need for full details).
Surely one of programmers can sacrifice 5-10 minutes of time every month to keep people informed. 10 minutes is a full maximum to tell changes you are working at.
Really, we know too few for now, i know it can be embarassing if you show something on 5.x kernel tat does not even have enough features.
But still it will be a small window thru which we can see a small bit of your hard work.
Yeah, you have own code, you have own repositories, that's okay, just give small bits of info on what you are working so we can objectively see you do some work(because after some years with no information many people start to doubt you do anything on v7 branch).
Please, i really wish to hope for myself and for some of my clients that you will do 7.x branch with better(more even) load sharing between the cores.
mfr476
Tue Apr 30, 2019 10:18 pm
+1 Great idea¡¡¡¡¡ no timelines but we know the progress.
Steveocee
Wed May 01, 2019 9:17 am
Great idea but can’t see it happening.
Do Apple give updates on what their design and software team are working on?
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
pe1chl
Wed May 01, 2019 10:16 am
I asked about it at the Amsterdam MUM.
(actually I asked when we would get more IPv6 features, the reply was "in v7" as usual, then I wondered if we would ever get that)
The reply was "certainly before the end of the year".
Of course, it wasn't mentioned "which year" :-)
mfr476
Wed May 08, 2019 4:40 pm
A lot of days without New firmware... Is It a Ros 7 signal?
anthonws
Wed May 08, 2019 5:15 pm
No. It's just a signal of no signal. Typical around these corners...
buset1974
Thu May 09, 2019 4:07 pm
not yet
mfr476
Sat May 18, 2019 10:27 pm
When? In a long future?
Sob
Sat May 18, 2019 11:11 pm
It's getting closer every day! ;)
anthonws
Sun May 19, 2019 12:04 am
What an awesome slogan for Mikrotik!
"Trust in Mikrotik! What you're waiting for is getting closer every day!" TM
Microsoft tried patenting that for Windows Phone/Mobile, but Mikrotik got there first ;)
pe1chl
Sun May 19, 2019 11:17 am
Don't use that example, we all hope that it will not be vaporware like Windows Phone...
mkx
Sun May 19, 2019 12:04 pm
Windows Phone was not vaporware, it was real ... shit. And that's why it disappeared real soon ...
BR,
Metod
pe1chl
Sun May 19, 2019 1:15 pm
Well, it really showed that Microsoft thrives only on existing installed base.
In a "new market", it really stands no chance against the competition.
However, what I meant is that the platform has almost (and also completely) disappeared many times, with the proponents clinging onto a promised new version time after time.
And every time it failed to deliver. We would not want that same thing happen to RouterOS...
anthonws
Mon May 20, 2019 12:20 am
Indeed we don't want to see the same thing happen to RouterOS.
But I'm sure ROS 7 is going to be the savior, just like Windows 10 Mobile was :P heheheheh
mfr476
Mon May 20, 2019 8:34 am
The worst of this situation in mikrotik silence
I Hope that wisp have future in a fiber world
normis
Mon May 20, 2019 1:09 pm
I just want to let everyone know, that v7 is progressing pretty good this year, and most core functionality is usable. Some more difficult parts need to be done and we can release a public beta.
Keyko
Mon May 20, 2019 1:15 pm
mkx
Mon May 20, 2019 2:03 pm
@Keyko, hold on there on the tree trunk, don't fall down! ;-)
BR,
Metod
anthonws
Mon May 20, 2019 2:20 pm
Thanks for the feedback @normis! It sure adds a bit more of clarity, although there's no rough timelines.
But definitely an improvement over the "it's ready when it's ready". And for that I congratulate Mikrotik.
Cheers,
anthonws.
p.s. Now, before everyone get's super hyped and expects a release next month...Personally, and by experience in the software engineering industry, I don't expect any betas before EOCY 2019 or Q1 2020.
vecernik87
Long time Member
Long time Member
Mon May 20, 2019 2:28 pm
@normis: so in another words, the easier parts are done and now we are just couple of decades from release?
(nah, don't get offended. I really, really appreciate everything you do as long as you don't lie to us or keep silent about security)
@keyko: hold on mate! You don't have right to use this meme unless you are realy Aussie :lol:
(I would post a selfie with his cuddlish bear but mommy told me to not show myself over the internet)
jarda
Mon May 20, 2019 2:31 pm
This is the day we were looking for. If there are any memorable dates in the Mikrotikls history, don't forget to add this day to it.
Now the question is: When we will be able to install the first public version?
Paternot
Long time Member
Long time Member
Mon May 20, 2019 2:48 pm
When it's released. :D
pe1chl
Mon May 20, 2019 3:04 pm
I was at a MUM recently and they said we could expect "stable" RouterOS 7 release before the end of the year.
However, I should add that it was not mentioned WHICH year that was!
krisjanisj
Mon May 20, 2019 3:37 pm
Already answered here!
* Wager of "The Holy War" against users who don't paste their config/export/print into [code][/code] blocks
* Avid coffee consumer
* Provider of stupid solutions for simple problems
mfr476
Mon May 20, 2019 4:39 pm
Lite to Lite. Please Normis tell us when mikrotik improve ros7. In the Internet world speed and ping is all
pe1chl
Mon May 20, 2019 4:58 pm
The problem is that this only mentions beta versions.
I do require more IPv6 functionality (like policy routing, hopefully also NAT66) somewhat urgently for a production environment, not really the place to run early beta versions.
Best would be when that appeared in v6 but as I understood, no more work is being done on IPv6 in RouterOS v6.
anthonws
Mon May 20, 2019 5:00 pm
Thanks for sharing that! Like I estimated. EOCY or Q1 2020.
Edit: A stable release should be in the schedule for Q3/Q4 2020.
krisjanisj
Mon May 20, 2019 5:12 pm
That is not true. Work on v6 development still continues while v7 is being developed.
pe1chl
Mon May 20, 2019 5:23 pm
But not on IPv6 within v6, as far as I understood. IPv6 is (as a whole) apparently a lower priority than IPv4 within RouterOS.
There are long outstanding open requests to complete the functionality of IPv6 but they are either ignored, or answered with "this will be done in v7".
So it looks like we need to wait for v7 to get more complete IPv6 support.
(there are topics which describe what is wanted in this regard, but for me it comes down to being able to support more than one ISP link, each with their own /48 assignment, in a single router)
mfr476
Mon Jun 03, 2019 10:23 am
Any news about ROS v7 in hungary MUM?
Pénzi
Mon Jun 03, 2019 9:18 pm
Nothing
mistry7
Mon Jun 03, 2019 11:07 pm
We droped Mikrotik out of our Core, IPV6 is needed more Then Ever, we will obtain last avaible IPv4 address in the Next 3-4 Month, and Then we need to start CGN NAT
Jotne
Mon Jun 03, 2019 11:56 pm
Can you give some information on what kernel it will be using 4.x or 5.x?
MikroTik->Splunk
mistry7
Tue Jun 04, 2019 1:10 am
4.xx
pe1chl
Tue Jun 04, 2019 10:33 am
One could hope that after this experience MikroTik tries to limit the number of kernel patches and/or keeps an eye on kernel development and regularly updates the kernel patches so it becomes possible to change kernel revision in a minor v7 revision (e.g. 7.0.x to 7.1.x).
If not, it will not take long or everyone will be asking for RouterOS v8 because a newer kernel is required for the features they want.
(and this whole story repeats)
mfr476
Tue Jun 04, 2019 10:49 am
Today we have a New mum. I Hope any news about Ros v7 or any improvement in router
pe1chl
Tue Jun 04, 2019 2:11 pm
I recently visited a MUM and there was no mention in the opening announcement, but the people at the MikroTik desk said "it will certainly be released before the end of the year".
They did not mention WHICH year.
krisjanisj
Tue Jun 04, 2019 2:15 pm
As @Normis answered previously:
All I can say is that development of v7 has picked up in the last few months, more than ever. While I can't promise anything stable, it is pretty safe to say, that some kind of public test release (like beta for specific platforms) could be expected this year. The chances of that happening are now higher than ever before, when similar promises were made.
mfr476
Tue Jun 04, 2019 6:20 pm
This year @krisjanisj?
enzain
Sat Jun 15, 2019 9:10 pm
This video fake or not?
https://www.youtube.com/watch?v=NbfKplzda7I
And yes - we all waiting for v7 betas
mfr476
Sun Jun 16, 2019 8:34 am
It isnt a fake. It is real but we don't have beta...
mfr476
Wed Jun 19, 2019 4:52 pm
Please said us anything about rosv7 progress.
troybowman
Sat Jun 29, 2019 7:31 pm
Are you implying that RFC6296 NAT66 and IPv6 policy routing is coming soon, then? It would be great to see it on some kind of product development roadmap!
enzain
Sun Jun 30, 2019 12:00 pm
I more need netmap66 - in IPv6 is more actually
connorgoodwolf
Sun Jun 30, 2019 12:06 pm
It's fake, even one of the Mikrotik support personnel joked about the video. Someone was using a custom program to jest with us all.
mfr476
Mon Jul 01, 2019 2:21 pm
Another security problem because mikrotik use old kernel....
mrz
Mon Jul 01, 2019 2:52 pm
If you are talking about SACK panic, then all Linux version starting from 2.6.29 are affected.
Chupaka
Mon Jul 01, 2019 6:40 pm
from 2.6.29
old kernel....
Sonnix
Mon Jul 01, 2019 7:07 pm
It was fixed in 5.1.11 and even that kernel can be considered old now. The current version is 5.1.15 right now.
mrz
Tue Jul 02, 2019 1:01 pm
Right ... 5.1.11 released 17 Jun 2019 ...
Chupaka
Tue Jul 02, 2019 1:54 pm
It's even not this month! Way too old!!!!111oneone
cmurrayis
Mon Jul 08, 2019 8:28 am
When? please an update - we are in so much pain with the existing 1072's and really don't want to replace them all if we don't need to!
Or at least open up a version of CHR for ISO install with Intel drivers...
mfr476
Wed Jul 10, 2019 11:05 pm
That problem is as old as the promise of the v7 @chupaka hahahaha. what a great joke!
whiteghost12
Thu Jul 11, 2019 5:20 pm
when it's 1072 with ROS 7 becomes useless. why do we need beta for some devices in the end of this year.... may be. Now mainline kernel 5.2 . The kernel in nonexistent ROS 7 is outdated yet now.time to ask when it comes router os 8 with 5.x.x kernel?
anthonws
Fri Jul 12, 2019 8:11 pm
LOLOL! I'm not sure man kind will be around for a Router OS version 8 :P
leoktv
Trainer
Trainer
Sat Jul 13, 2019 7:45 am
It is not version 8 it is Buterfly version X
_________________
Leo De Geer, Mikrotik Certified Consultant/Trainer #TR0003, MTCNA, MTCRE, MTCWE, MTCTCE, MTCINE, MTCUME, MTCIPv6E MTCSE MTCASE & MikroTik Distributor
http://www.mikrotik.se
support[at]mikrotik.se
Office: +46 325 660 650
Chupaka
Wed Jul 17, 2019 11:52 am
RouterOS v7 is almost there, just need to add some components...
Jotne
Wed Jul 17, 2019 12:02 pm
LOL
:mrgreen:
MikroTik->Splunk
connorgoodwolf
Wed Jul 17, 2019 1:35 pm
Please remember to add Duke Nukem Forever
Connor Goodwolf | IOWolf LLC | +1 412-423-8779
Technology Consultant | MikroTik Enthusiast | LinkedIn
honzam
Wed Jul 17, 2019 2:22 pm
Can it run on rb411 or need a more powerful 4 core processor? :-)
mrz
Wed Jul 17, 2019 2:30 pm
Will not run, you need one core per pixel.
mkx
Wed Jul 17, 2019 5:18 pm
BR,
Metod
honzam
Wed Jul 17, 2019 5:58 pm
CCR1072 seems to be weak :-(
Paternot
Long time Member
Long time Member
Wed Jul 17, 2019 6:19 pm
But will it run Crysis?
mfr476
Wed Jul 17, 2019 6:48 pm
chupaka I hope the games, at least, work well hehehe
Sob
Wed Jul 17, 2019 8:51 pm
Well, they will be re-implemented by MikroTik from scratch, so few tiny details could be different from what you're used to. Like all machine guns being single-shot only, and there will be no health packs. But other than that, fully compatible with originals.
muetzekoeln
IPv6 ready?
Wed Jul 17, 2019 9:48 pm
Will ROS v7 sport a IPv6-Ready logo from the beginning?
https://www.ipv6ready.org
Chupaka
Re: IPv6 ready?
Thu Jul 18, 2019 6:14 pm
ROS v7 is IPv6-Ready. Then it will become IPv6-Steady, and finally IPv6-Go!
Users browsing this forum: No registered users and 93 guests
