azurtem
Trainer
Trainer
Netinstall
Mon Jan 19, 2015 6:58 pm
Hi
I have been struggling for the past two hours trying to get netinstall to talk to my CCR-1009
Following a power cut the router won't boot ("loading kernel from nand")
...same issue as : http://forum.mikrotik.com/viewtopic.php?f=3&t=87811
I have set up the CCR-1009 with boot to Ethernet
I activated the Boot server in Netinstall and entered an ip address within the same subnet
I keep getting "Please, check ethernet cable..."
I have tried a direct link, intermediate switch...nothing works
I have even attempted to use DHCP protocol - the router however doesn't attempt to reach the DHCP server
I tested the same setup with an RB433 and it works perfectly
Any ideas ?
thanks
yann
bajodel
Long time Member
Long time Member
Re: Netinstall
Mon Jan 19, 2015 8:02 pm
Hi
Following a power cut the router won't boot ("loading kernel from nand . ...
double check wich is the correct "boot port" on the CCR and use that ..
azurtem
Trainer
Trainer
Re: Netinstall
Mon Jan 19, 2015 8:19 pm
Thanks Bajodel
Silly me, I assumed it was port eth1
There is even the indication 'boot' above port n°8 !
thanks
yann
Users browsing this forum: eguun, eworm, hgoertz, pe1chl, Sob and 102 guests
