technonotux
Forward all ports except Mikrotik reserved
Wed Jan 21, 2015 8:51 am
I am using RB450G with PPPOE-Client Internet connection with public ip, i have forwarded all ports using the
/ip firewall nat add chain=dstnat protocol=tcp dst-port=1-65535 action=dst-nat to-addresses=192.168.1.101 to-ports=1-65535
/ip firewall filter add action=accept chain=input disabled=no dst-port=8291 protocol=tcp
above script has successfully forward all ports i have lost connection to RB450G from Winbox (8291), http (80), ssh(22) as all ports are forwarded to local ip, i want to exclude RB450G (RouterOS Ports) i.e. 8291, 80, 22, 21 etc.. how can i do it.
jarda
Re: Forward all ports except Mikrotik reserved
Wed Jan 21, 2015 9:18 am
Make accept rules for these ports in input chain.
technonotux
Wed Jan 21, 2015 9:45 am
i already have following accept rule for the port 8291 but when i forward all ports the LAN ip, i loose Winbox(8291) connection what could be the reason ?
bajodel
Long time Member
Long time Member
Thu Jan 22, 2015 9:00 am
nat happens before filter, exclude 8291 from the range or put another rule before
technonotux
Thu Jan 22, 2015 9:05 am
as there are multiple ports to exclude like 8291, 80, 22, 21 etc.. which RouterOS uses, is there any other simple way to exclude in single / multiple rule
bajodel
Long time Member
Long time Member
Thu Jan 22, 2015 9:31 am
put before you nat range rule something like..
/ip firewall nat add chain=dstnat protocol=tcp dst-port=22,80,8291 action=accept
technonotux
Thu Jan 29, 2015 8:45 am
Thanks it solved my issue :D
Users browsing this forum: MSN [Bot] and 47 guests
