rzirzi
CCR1009-8G-1S-1S+PC
Tue Jan 27, 2015 10:28 pm
Any more news about CCR1009-8G-1S-1S+PC model ?
honzam
Re: CCR1009-8G-1S-1S+PC
Tue Jan 27, 2015 10:34 pm
Deleted because not related
LAN, FTTx, Wireless. ISP operator
rzirzi
Tue Jan 27, 2015 10:41 pm
honzam - can You read?
So - just READ CAREFULLY .....+PC - can You see difference ?? YES - that is NEW model !
honzam
Tue Jan 27, 2015 10:43 pm
Next time please more decency :)
More info there:
phuang3
Thu Jan 29, 2015 2:44 am
OMG! CCR1009+PC is the one! I can't wait to see it.
rzirzi
Thu Jan 29, 2015 8:15 pm
What is the power consumption?
When it will be available?
Shiro
Thu Jan 29, 2015 8:25 pm
Awesome for home users.
@rzirzi: My current CCR1009-8G-1S-1S without SFP/Ethernet ideling around 18W and 23W with 2 SFP's + 5 Ethernet Connections. Most time my CCR running with one fan, i thinks that the PC model without fans is around 1-2W less.
jarda
Fri Jan 30, 2015 9:28 pm
Passively cooled device with speed controlled fan? Is this some new definition of passive cooling?
jarda
Fri Jan 30, 2015 9:30 pm
Anyway the renders look very good.
honzam
Fri Jan 30, 2015 10:49 pm
I think - it is bug in brochure :)
Jeroen1000
Sun Feb 01, 2015 10:44 pm
Darn, I almost wish I had not bought a 850Gx2. Anyway it will do for now. Only downside I can see is the low amount of NAND-storage compared to the 850Gx2 and the 450G
jarda
Mon Feb 02, 2015 7:14 pm
It has card reader, so no need for big flash.
ezyclie
Tue Feb 03, 2015 5:57 am
wow, waiting eagerly to buy this cute Router for my home network in Jakarta, Indonesia.
Hope Mikrotik got plan to add WiFi to this router in the future
honzam
Tue Feb 03, 2015 10:53 am
drb
Wed Feb 04, 2015 6:44 am
Now that this is officially up on the Mikrotik site, I'm wondering if someone from Mikrotik could comment if this passively cooled model would be a better option than the other CCR1009 models for solar powered sites? How much difference should we expect to see in power consumption compared to the fan based models? Is the operating temperature range greater, lower, or the same as the other CCR1009 models?
ezyclie
Wed Feb 04, 2015 9:21 am
I was wondering with the temperature too under heavy load.
Btw when can we expect the router availability in Jakarta, Indonesia?
chechito
Sat Feb 07, 2015 4:05 am
according to specs it has a 1ghz cpu that is 200mhz less than "normal" ccr1009 surely its to lower the power consumption.
will be nice to have power consumption info
ezyclie
Sat Feb 07, 2015 6:15 am
Didn't notice the CPU speed. If you are looking at "Performance test results" table they are having same performance BUT I am not sure if Mikrotik copy paste the table lol :lol:
earljack
Sat Feb 07, 2015 9:48 am
CPU reduction shouldn't matter to me. The CCR1009-8G-1S-1S I have is an absolute beast from hell. It's CPU changes between 0 and 2% during peak network times. It's like it's laughing at everything I throw at it. I love it! It replaced an RB1200 that had its CPU average around 25-35% during peak times with the same config. I'm foaming at the mouth for a CCR1009-8G-1S-1S+PC. However, I'm worried it might be a bit deeper with those heatsink fins sticking out the back. Might not fit in my outdoor enclosures. It seems like Mikrotik just keeps making their routers deeper and deeper. Kinda wish they would try and stick with the same form factor...
ezyclie
Tue Feb 10, 2015 3:25 pm
Hmmm can not find this product even in the Europe
normis
Tue Feb 10, 2015 3:32 pm
It was just released to distributors. Still flying to them. Wait a few days
ezyclie
Tue Feb 10, 2015 5:40 pm
Hi normis, thanks for your information, waiting eagerly to buy this router even from oversea distributor
mmv
Trainer
Trainer
Thu Feb 19, 2015 8:27 pm
Would somebosy clear, can it work with two SPF modules (like S-31DLC20D)?
In other words, in this router SFP+ sloth is compatible with SFP modules, to build ring?
Mikhail Moskalev
vortex
Sat Feb 21, 2015 2:38 pm
I am considering upgrading to a 250mbps download link at home, so I was thinking about getting this because it is fanless.
But I am disappointed by its ability to perform with whatever VPN method I might be forced to use compared to the RB1100AHx2.
But the RB1100 is out of the question because of the fans and it also seems like expensive old tech (not old architecture).
docmarius
Sat Feb 21, 2015 6:22 pm
Can you be a little more specific on what you mean by that? Both of them support ALL VPN methods RouterOS has to offer...
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
vortex
Sat Feb 21, 2015 7:07 pm
I am thinking about GRE/IPSEC for example, because GCM is not hardware-based at the moment, and there is not roadmap for it.
rfauske
Thu Feb 26, 2015 9:56 am
Now with the new units it looks like they are ready to be used with a -48v DC environment as-well ? It had been great if the new units could have some real screw terminals for power and not just the dc adapter input.
They had been great for us at least if they had that.
ivan07
Sat Mar 14, 2015 7:06 pm
Where did you get this information about GCM?
vortex
Mon Mar 16, 2015 12:36 am
Search for GCM, Mikrotik said it.
roc-noc.com
Forum Veteran
Forum Veteran
Wed Apr 29, 2015 2:30 am
Yes, it is not clear in the documentation so I just verified this for a customer. Both of the CCR1009 1S+ models link up with a standard SM SFP (S-31DLC20D) in the SFP+ ports and a SM fiber connection. I also checked an SFP+ port to an SFP port and that works as well in the CCR1009 with 1S+.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
chechito
Wed Aug 12, 2015 4:54 pm
performance test now are updated and shows a little less performance on passive model
chechito
Wed Aug 12, 2015 5:02 pm
inside photo
Users browsing this forum: Baidu [Spider] and 29 guests
