880frank
Virtual or pseudo ethernet interfaces possible?
Thu Jan 29, 2015 5:15 pm
from my cable provider i could get 5 fixed ip addresses via DHCP - but i have to gave them the interface mac address upfront. The cisco cable modem is connected to ethernet port 1.
Is there a way to create additonal Interfaces including DHCP clients with independent mac addresses but linked to the same physical Interface?
If there is a trick - please advidse
thank you,
frank
NathanA
Forum Veteran
Forum Veteran
Re: Virtual or pseudo ethernet interfaces possible?
Fri Jan 30, 2015 2:58 pm
No good way to do this that I know.
There is a virtual-ethernet interface (vif), but its purpose is to allow communication between host router and virtualized router (either KVM on x86, or MetaROUTER on MIPSBE and single-core Freescale PowerPC), so not all boxes that run RouterOS will show you the option.
In theory, on a RouterOS device that does have support for '/interface virtual-ethernet', you could create a bunch, just not use them with a virtual router, and bridge all of them together, or for router models that don't support this interface type, you could create a bunch of some other ethernet-like interface that is essentially virtual (e.g., EoIP) and bridge THOSE together. But all direct member interfaces of a bridge will assume the bridge's MAC address and not their own when transmitting frames, so you would still be stuck with a single MAC address. To transmit individual, unique MAC addresses, the bridge has to be forwarding frames, not originating/outputting frames, which still means multiple devices.
If you *are* using a router that has support for virtualization (KVM or MetaROUTER), the easiest way is to fire up one virtual router per IP address and dump them all in a bridge with your WAN port on the host. But that does seem a bit excessive to be running 4 or 5 virtual routers just to do this.
One final possibility that you might investigate is to do as suggested earlier and create a bunch of virtual ethernet-like interfaces and bridge them with the WAN port, and then use '/interface bridge nat' to construct L2 NAT rules to change the MAC address used on frame transmission. This might get complex rather quickly, though, and may even be impossible, since bridge NAT is basically stateless (no tracking of any kind) and the specific matchers that you might need to translate the MAC address on egress and ingress may not even exist.
-- Nathan
Sob
Sat Jan 31, 2015 4:55 pm
It seems that it's possible to misuse VRRP for that:
ros code
/interface vrrp
add interface=ether1 name=vrrp1 vrid=1
add interface=ether1 name=vrrp2 vrid=2
add interface=ether1 name=vrrp3 vrid=3
# VRRP interface needs some static address to come up:
add address=127.0.0.2/32 interface=vrrp1 network=127.0.0.2
add address=127.0.0.3/32 interface=vrrp2 network=127.0.0.3
add address=127.0.0.4/32 interface=vrrp3 network=127.0.0.4
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
    interface=ether1
add add-default-route=no dhcp-options=hostname,clientid disabled=no interface=\
    vrrp1 use-peer-dns=no use-peer-ntp=no
    vrrp2 use-peer-dns=no use-peer-ntp=no
    vrrp3 use-peer-dns=no use-peer-ntp=no
It's definitely not a proper solution and I'm not sure about all possible side effects. But at the first sight, it works:
ros code
 #   ADDRESS            NETWORK         INTERFACE
 0   127.0.0.2/32       127.0.0.2       vrrp1
 1   127.0.0.3/32       127.0.0.3       vrrp2
 2   127.0.0.4/32       127.0.0.4       vrrp3
 3 D 192.168.80.50/24   192.168.80.0    ether1
 4 D 192.168.80.48/24   192.168.80.0    vrrp2
 5 D 192.168.80.47/24   192.168.80.0    vrrp3
 6 D 192.168.80.49/24   192.168.80.0    vrrp1
NathanA
Forum Veteran
Forum Veteran
Sun Feb 01, 2015 2:06 am
It seems that it's possible to misuse VRRP for that: [snip]
Clever!!!
-- Nathan
FunctionalIT
Fri Oct 21, 2016 10:56 am
For all whom want to create a similar infrastructure. I have done this succesfully with VRRP, but this is kind of an abuse and has some flaws. You can do it with MetaRouter (if available), but that is a bit heavy for the system and the IP's will virtually be on different routers.
The easiest (and best) way to do this is to put a switch in front (between modem and router) and offer a physical interface to every IP...
jarda
Fri Oct 21, 2016 12:11 pm
Yep. To put switch in front of the router, that's bingo! At least meanwhile until mikrotik come with some real and usable solution. Maybe abusing eoip tunnels to some other device and back could do the job also.
Jotne
Sat Sep 01, 2018 7:07 pm
I did try vrrp config on an hAP lite.
Vrrp interface are all red (all config added)
Did try the same on hEX 750Gr3 interface did came up.
But all did get the same IP from my ISP.
Sob
Sun Sep 02, 2018 2:59 pm
It depends on what ISP does. The idea here was that ISP is willing to provide multiple addresses to devices directly connected to WAN. Is it your case? Multiple devices = multiple MAC addresses, VRRP can provide those. But it won't just work everywhere, when you're not supposed to get more than one address.
Jotne
Thu Sep 20, 2018 7:54 am
I did just try to connect ether1 to an Router with DHCP. So this router should give away IP to any who ask.
Stil red DHCP interfaces.
Tested on rb951g-2hnd and CRS-125-24G
JohnTRIVOLTA
Mon Oct 21, 2019 8:56 am
ros code
/interface vrrp
/ip dhcp-client
    interface=ether1
ros code
Hi SOB, i tried this configuration, but the traffic not passing from LANs . I tried mark the connections and used VRF too, but without succes!
Is there any other way similar to pseudo ethernet to use in this case? Do you know if Mikrotik staff plan to support it in ROS v7?
Sob
Mon Oct 21, 2019 5:12 pm
I think it still works, at least my very quick test suggests so. But it's just the basic part, to get more MAC addresses and then more IP adddresses from them. The rest depends on what else you do with it, and there are many way in RouterOS how to create configs that don't work.
And since you brought it up, one small update for the original idea. I'd rather use IPv6 mode for VRRP interface. One advantage is that it doesn't need any extra addresses, because there are always link-local ones. And VRRP doesn't mix IPv4 and IPv6 on protocol level, so if you add the other protocol address on VRRP interface, it's strictly local-to-router thing and can't mess something up.
About proper way, I'm just regular user with no special relation with MikroTik, so I don't know any more than you do. I know I was looking it up and Linux definitely has some kind of virtual ethernet interfaces. I think even the kernel used in RouterOS v6 has some basic support. But I guess that demand for this feature is probably not very high, so who knows when or if we'll see it in RouterOS.
JohnTRIVOLTA
Mon Oct 21, 2019 8:01 pm
Thank you SOB for your comprehensive answer!
diniboy
Mon Feb 28, 2022 1:01 pm
Great hint. I could also go as far as to obtain a secondary IP address. However I am getting timeouts if I try to ping for instance:
[admin@redacted] > /ping src-address=xx.xx.xx.xx interface=vrrp1 1.1
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0 1.0.0.1                                                      timeout
    sent=1 received=0 packet-loss=100%
I don't want to add a default route, but I would like to route certain IPs over this secondary xx.xx.xx.xx IP. However as of now it seemingly times out in all cases. What else is needed to bring this up properly?
archerious
Sun Mar 13, 2022 8:15 pm
ros code
/interface vrrp
/ip dhcp-client
    interface=ether1
ros code
This worked flawlessly.
Had to restart my ISP gateway in order to get it to give out IPv4, but on ROS 7 this is working perfectly. Also had to add the VRRP to the WAN interface list so my firewall didn't block.
For IPv6 I added them into ND and like magic they got IPv6.
Only question I have is do I need to add default routes for the VRRP DHCPv6 clients? It seems to be working without, I assume using the default route from my Ether1's DHCPv6 client?
Sob
Sun Mar 13, 2022 9:01 pm
No, you don't need default routes for other DHCPv6 clients. In fact, no DHCPv6 client should add route, it should come from RA, but if it works, you can keep it as you have it now (plus getting gateway from RA is currently broken in v7 anyway).
archerious
Sun Mar 13, 2022 11:43 pm
Awesome, thank you again. Seriously you were the only person that had a solution on MikroTik.
Really appreciate your time, if you have a crypto wallet I'd happily donate to you a cup of coffee.
Sob
Mon Mar 14, 2022 8:43 pm
It's fine, just enjoy. And hope for some future proper support. :)
bpwl
Tue Oct 10, 2023 12:28 am
But now MACVLAN may be helpfull. https://help.mikrotik.com/docs/display/ROS/MACVLAN
MACVLAN is very new ... ROS 7.12rc1 ... 2023-Oct-05
dbjerke
Tue Jan 09, 2024 12:59 am
It was VERY helpful! Thank you for posting that!
Users browsing this forum: No registered users and 110 guests
