RobClem
routing question
Wed Sep 22, 2004 1:18 pm
I have been running my MikroTik with a Bridge setup - basically I have my LAN and WAN interfaces added to the Bridge and then bind my private and public addresses to the Bridge. This works fine - EXCEPT that any broadcast storms on my network bring it to a standstill.
I would prefer to have a NAT rule(which I know how to configure) for my private addresses to NAT to a single public address.
What I need to know is how to route public addresses from the LAN side of the router to the WAN side and back the other way as well. Is this possible and if so can anyone offer any advice?
Cheers
Rob
advantz
Wed Sep 22, 2004 3:19 pm
You can start here : http://www.mikrotik.com/docs/ros/2.8/ho ... to.content
use dst-nat and src-nat to link public to local ones
RobClem
Wed Sep 22, 2004 3:56 pm
I know how to do this bit but I want to let public IP's flow through the router without NATing them - I do this with a bridge at the moment but ideally don't want to use a bridge
mag
Wed Sep 22, 2004 4:25 pm
sorry, but i guess this is not possible that easy. (a router is actually defined by at least two different interfaces with two different subnets)
let's suppose a subnet of public ip-addresses is bound to the LAN- interface, then there are three options for the WAN side:
- unnumbered point-to-point link
- transfer-net (usually a small subnet e.g. /30 of public ip-addresses
- NAT (the WAN interface responds to all public ip-addresses)
the last case needs one-by-one NAT, usually done with a pair of ip-range-dependend src- and dst-nat rules.
there's also a good packet flow picture in the manuals ip firewall section.
i hope this helps a bit.
matthias
RobClem
Wed Sep 22, 2004 8:31 pm
what do y udo to route public IP's through a MikroTik - this must be a very common request?
RobClem
Wed Sep 22, 2004 8:34 pm
I understand point 3 - can you explain point 1 and 2 a little bit more?
Rob
mag
Wed Sep 22, 2004 8:48 pm
2: usually a small transfer-net i.e. an ip-subnet with 4 addresses (/39).
for example:
145.253.129.0/30 with .1 being the remote WAN interface on the upstream ISP and the default gateway too. .2 to be bound to the local WAN interface.
if the LAN-interface has an ip-address from a different subnet, routing occurs automatically.
1: only for point-to-point-links and often used on cisco routers, i haven't tried that on mikrotik ROS. the point-to-point-interface gets the ip-address of the LAN interface with unnumbered command.
exampe is here: http://www.mikrotik.com/docs/ros/2.8/ip/address.content
RobClem
Thu Sep 23, 2004 10:56 am
just to clarify -
my upstream ISP has a router with a /26 address range GW - xx.xx.xx.65
WAN side of my Router - xx.xx.xx.66 /30
LAN side of my router - xx.xx.xx.67 /26
Customers - xx.xx.xx.70-128 /26 with xx.xx.xx.65 as Gateway
Will the above work or have I got my subnets wrong?
thanks for the help
Rob
pbailly
Thu Sep 23, 2004 11:22 am
70-128 no can do + gateway should be in the range
that /30 uses addresses 64 to 67 included (network and broadcast) so the next usable ranges are :
a /30 (68-71)
a /29 (72-79)
a /28 (80-95)
a /27 (96-127)
1 IP per range for the mikrotik and use this ip as gateway
1 IP is the network add. and 1 IP is the broadcast add.
it seems just strange to me that your ISP put his router on your IPs, i imagine you mean the router they installed at your location has the x.x.x.65 IP.
in that case i suggest do decrease the range on the ISP router at your place (a /30), a /30 on the MT also, then use RIP2 on your LAN so the router can learn the routes from the MT and vice versa
a drawing of your setup could help a lot
Patrick
mag
Thu Sep 23, 2004 2:06 pm
same subnet on both interfaces -> no routing.
it would be possible (as explained in pbailly's posting) to use
x.y.z.66/30 for the WAN, and a default route to .65 on the MT.
and than for example
x.y.z.68/30 set aside for other WAN interface
x.y.z.73/29 for LAN (leaves 5 more ip for e.g. network equipment), def. gw is .73 for them
anything else depends from the network scenario.
GJS
Sat Sep 25, 2004 6:39 pm
How about proxy arp? This is what I use.
Basically, you set proxy arp on the WAN interface which will make your router respond with an arp reply to any address which is in it's routing table.
Then add a static route for the public IP with your LAN interface as the gateway. Then set the public address on the client (or assign by static DHCP lease) and you should be good to go.
I combine this with arp reply-only on the LAN interface so that each client can only use one IP address according to their MAC address.
'Hope that helps, Rob.
Guy
pbailly
Sat Sep 25, 2004 7:40 pm
proxy arp will work only if the matching that occurs in the MT machine hits the LAN route before the WAN route : packet matches the LAN route and is thus forwarded there, but imaging it matches the WAN route first ? it is then sent back where it came from
easily checked when you have only 2 choices (2 network cards) : turn the router arround and use the LAN card as WAN and WAN card as LAN and it'll work, but imagine a MT machine with 5 or 6 network adapter : things won't work then
MT 2.5 seemed to use a different kind of match (smallest matching network perhaps) because what you suggest did work with MT 2.5 but didn't after upgrade to 2.8
and then one day you'll decide to connect a second MT to your router, perhaps as a future replacement, using proxy-arp for this once will really srew your network as you'll have to have the routes from your first MT (at a high cost) and then some TCP packets will be taken by one router ... and some by the other one (both have the same routes, cost is just different) go figure !
but using a small network (/29) for the router and the MT and using RIP on the router and the 2 MT will allow you to use ARP-ENABLED instead and to add that extra MT in there and do a very painless switchover from one MT to the other, or allow the use of both MT simultaneously.
Patrick
GJS
Sun Sep 26, 2004 3:03 am
Hmm... not sure that I understand, Patrick. I'm running 2.8.13 without any problems, though I do only have two interfaces on the router. Why would the packet match the LAN route?
The route has the interface that the host machine is connected to as it's gateway:
# DST-ADDRESS G GATEWAY DISTANCE INTERFACE
1 S X.X.X.1/32 r 192.168.51.1 1 private
If it were connected to a different interface I would just use the IP address of this interface. On the host, the gateway is the same interface (192.168.51.1 in this case).
I beleive that it's possible to to route a public IP addess across any number of routers, provided you have proxy arp enabled on both the relevant interfaces. See the posts by mp3turbo in this thread for details:
http://forum.mikrotik.com/phpbb2/viewto ... highlight=
Guy
pbailly
Sun Sep 26, 2004 10:51 am
i was talking about routing a /26 of official IP add. were the LAN part actually has the official addresses and the WAN part is connected to a adsl router or leased line router
of course, masquerading private address space is no problem with proxy-arp
Patrick
Users browsing this forum: jmcguckin, Majestic-12 [Bot], temporal, wispmikrotik, Znevna and 122 guests
