MUM Europe 2020
Zwodka
Interface connection with speed limit
Fri Feb 06, 2015 10:50 am
Hi All!
A would like to connect 2 or more ethernet interface with speed limit.
For example:
- ether1 -> ether2 : 10Mbps
- ether1 -> ether3 : 20Mbps
- ether2 -> ether1 : 30Mbps
- ether2 -> ether3 : 40Mbps
- ether3 -> ether1 : 50Mbps
- ether3 -> ether2 : 50Mbps
How can I do it?
I've tried:
- all ethernet ports in 1 Switch plus Simple Queue
and
- all ethernet ports in 1 Bridge plus Simple Queue
Simple Queue:
- Target: ether1 / ether2 / ether3
- Dst: ether1 / ether2 / ether3
without any success :-(
hossain2004a
Re: Interface connection with speed limit
Fri Feb 06, 2015 8:25 pm
All I know about golden law of queuing ( :D ) you should put the fastest queue in higher priority .
Zwodka
Sat Feb 07, 2015 7:43 pm
Fastest, lowest, higher, lower ... doesn't matter.
I've tried it with only one Queue ... no success :-((
yancho
Sat Feb 07, 2015 9:55 pm
When bridging set
/interface bridge settings set use-ip-firewall=yes
Zwodka
Sun Feb 08, 2015 12:10 pm
When bridging set
Code: Select all
MegaThanx! It works fine! :-)
What if I have more than 1 Bridge? Does it affect all Bridge?
yancho
Tue Feb 10, 2015 12:42 pm
Yes that is global setting
Netranger21
Tue Feb 10, 2015 4:08 pm
nice
Users browsing this forum: No registered users and 42 guests
