cwu46
Mikrotik Radius Client Attribute/Authentication Questions
Fri Jun 30, 2006 1:36 am
Hi all,
To authenticate w/ our Radius servers, I need to have the Mikrotik send during the RADIUS access-request for each user the following
1. SSID requested by the user
In doing some research, I've discovered methods of doing it either through Congdon (e.g. -- attached to the end of the called-station-id) or via a VSA
Does Mikrotik support this (through Congdon or a specific VSA for SSID)?
If not -- how are others implementing 802.1x RADIUS-based authentication w/ Mikrotik (or is anyone doing it?)
-Charles
cwu46
Fri Jun 30, 2006 2:17 am
Just to expand:
http://www.ieee802.org/1/files/public/d ... 21x-20.txt
Congdon RADIUS (802.1x) implementation of Called-Station-ID Attribute
3.20. Called-Station-Id
For IEEE 802.1X Authenticators, this attribute is used to store the bridge or Access Point MAC address in ASCII format, with octet values separated by a "-". Example: "00-10-A4-23-19-C0". In IEEE 802.11, where the SSID is known, it SHOULD be appended to the Access Point MAC address, separated from the MAC address with a ":". Example "00-10-A4-23-19-C0:AP1".
cwu46
Fri Jun 30, 2006 2:27 am
So I delved deeper into the documentation, and found the Mikrotik reference dictionary:
http://www.mikrotik.com/Documentation/m ... dictionary
It looks like there's no particular VSA for SSID =(
That said, is there any way to pass the user's associated SSID to the radius server (is Calling-Station-ID implemented correctly per Congdon)?
thanks
-Charles
datanet
Thu Nov 30, 2006 2:34 am
I need the same: is there any way to pass the user's associated SSID to the radius server?
I have a tower with 2 wifi interfaces and I must set access to particular SSID for wireless client in the radius server.
Please advice.
Piotr
normis
Thu Nov 30, 2006 9:18 am
Each SSID has its own interface in RouterOS. Radius gets interface name in NAS-Port-Id attribute.
It is possible to rename all wireless interfaces to their SSID value and then NAS-Port-Id will contain SSID of the client.
datanet
Fri Dec 01, 2006 5:02 pm
Now I can check SSID with NAS-Port-Id attribute.
00:13:CE:9A:F6:82 NAS-Port-Id == wlan1
But if I turn it on - DHCP server don't give me an IP address - I got Access-Reject.
Check SSID works fine, client can be associated with radio station, but dhcp lease stop working.
Then I remove this line from radius check table, DHCP start working, but of course I lost possibility of check SSID.
Any ideas?
jfan
Thu Jan 11, 2007 12:10 am
I have been told that v3.x will pass SSID to RADIUS. Can anyone confirm this? I am trying to prove it myself currently...
For Virtual AP, Each SSID should be able to pass to RADIUS per Congdon, right?
Jin
Users browsing this forum: No registered users and 4 guests
