boardman
What am I be doing wrong ? RB532 as AP and 2 RB112 as wds st
Tue Jul 04, 2006 5:17 am
Hi guys, (and girls) :lol:
Can anybody please point me in the right direction? This is weird...
(My english is not very good, but I'll try to explain myself)
This is all going on a benchtest:
One RB532 w/CM9, 2.9.26 as an ap-bridge, lets call it AP.
Two RB112 w/CM9, 2.9.26 as station-wds, lets call them A and B.
Everything works perfect until A or B deads, that is; AP, A and B are connected to a lazy computer each one; from the computer connected to AP I can ping to AP, A and B RB's, and to the computers connected to A and B accordingly.
If I shutdown or remove the power to one of the stations let's say to A, here's where the problem starts, after A turns off, from the computer connected to AP, I can NOT ping AP, can not ping to A (obvious) and CAN ping to B and the computer connected to it.
If I turn back on A, after it boots and get registered back on the ap-bridge everything returns to normal, now let's turn off B, after B is off, from the computer connected to the AP, I can ping AP, and A and not B as it should.
I found out for this scenario A was the first station-wds that was registered to AP, If I reboot A and B and force B to register first then B is the one that causes the problems, so I notice the first registered wds-bridge in AP "rules" the situation.
Now if A registered first as the first scenario I mentioned and I turn off B first, then turn off A in that order, I still can communicate to AP.
I am very positive about something is missconfigured on the wds-bridge settings, but I can not find what... All help will be really appreciated.
Best Regards
Jorge Boardman
P.S. I am posting the export file of AP and A (A and B are about the same)
Here's AP:
/ interface ethernet
set ether1 name="ether1" mtu=1500 mac-address=00:0C:42:04:FC:7C arp=enabled disable-running-check=yes auto-negotiation=yes \
full-duplex=yes cable-settings=default mdix-enable=yes speed=100Mbps comment="" disabled=no
set ether2 name="ether2" mtu=1500 mac-address=00:0C:42:04:FC:7D arp=enabled disable-running-check=yes auto-negotiation=yes \
full-duplex=yes cable-settings=default speed=100Mbps comment="" disabled=yes
set ether3 name="ether3" mtu=1500 mac-address=00:0C:42:04:FC:7E arp=enabled disable-running-check=yes auto-negotiation=yes \
/ interface wireless
set wlan1 name="wlan1" mtu=1500 mac-address=00:0B:6B:35:FD:98 arp=enabled disable-running-check=no radio-name="Aguila" \
mode=ap-bridge ssid="Aguila-Gume-Reservas" area="" frequency-mode=manual-txpower country=zimbabwe antenna-gain=0 \
frequency=5825 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps \
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps \
max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default \
periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a \
wds-mode=dynamic wds-default-bridge=wds-bridge wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no \
update-stats-interval=disabled default-authentication=no default-forwarding=no default-ap-tx-limit=0 \
default-client-tx-limit=0 proprietary-extensions=pre-2.9.25 hide-ssid=yes security-profile=default \
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no comment="" \
disabled=no
/ interface wireless nstreme
set wlan1 enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
/ interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:18,9Mbps:17,12Mbps:16,18Mbps:15,24Mbps:15,36Mbps:14\
,48Mbps:14,54Mbps:13
/ interface wireless security-profiles
set default name="default" mode=none authentication-types="" unicast-ciphers="" group-ciphers="" wpa-pre-shared-key="" \
wpa2-pre-shared-key="" eap-methods=passthrough tls-mode=no-certificates tls-certificate=none static-algo-0=none \
static-key-0="" static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none \
static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key="" \
radius-mac-authentication=no group-key-update=5m
/ interface wireless wds
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=no audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no \
frames-per-second=25 audio-min=-100 audio-max=-20
/ interface wireless access-list
add mac-address=00:0B:6B:32:BA:9E interface=wlan1 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 \
private-algo=none private-key="" comment="Radio Gume" disabled=no
add mac-address=00:0B:6B:34:88:66 interface=wlan1 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 \
private-algo=none private-key="" comment="Radio Reservas" disabled=no
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no memory-limit=10 file-name="" file-limit=10 \
streaming-enabled=no streaming-server=0.0.0.0 streaming-max-rate=0
/ interface bridge
add name="wds-bridge" mtu=1500 arp=enabled stp=no priority=32768 ageing-time=5m forward-delay=15s \
garbage-collection-interval=5s hello-time=2s max-message-age=20s comment="" disabled=no
/ interface bridge port
add interface=ether1 bridge=wds-bridge priority=128 path-cost=10 comment="" disabled=no
/ interface l2tp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption
/ interface pptp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=mschap1,mschap2 keepalive-timeout=30 \
/ ip accounting
set enabled=no account-local-traffic=no threshold=256
/ ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
/ ip service
set telnet port=23 address=0.0.0.0/0 disabled=no
set ftp port=21 address=0.0.0.0/0 disabled=no
set www port=80 address=0.0.0.0/0 disabled=no
set ssh port=22 address=0.0.0.0/0 disabled=no
set www-ssl port=443 address=0.0.0.0/0 certificate=none disabled=yes
/ ip upnp
set enabled=no allow-disable-external-interface=yes show-dummy-rule=yes
/ ip arp
/ ip socks
set enabled=no port=1080 connection-idle-timeout=2m max-connections=200
/ ip dns
set primary-dns=10.10.0.1 secondary-dns=192.168.127.1 allow-remote-requests=no cache-size=2048KiB cache-max-ttl=1w
/ ip traffic-flow
set enabled=no interfaces=all cache-entries=4k active-flow-timeout=30m inactive-flow-timeout=15s
/ ip address
add address=10.10.0.247/24 network=10.10.0.0 broadcast=10.10.0.255 interface=ether1 comment="" disabled=no
/ ip proxy
set enabled=no src-address=0.0.0.0 port=8080 parent-proxy=0.0.0.0:0 cache-administrator="webmaster" \
max-disk-cache-size=none max-ram-cache-size=unlimited cache-only-on-disk=no maximal-client-connections=1000 \
maximal-server-connections=1000 max-object-size=4096KiB max-fresh-time=3d
/ ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set wds-bridge discover=yes
set wlan1 discover=yes
/ ip route
add dst-address=0.0.0.0/0 gateway=10.10.0.1 scope=255 target-scope=10 comment="" disabled=no
/ ip firewall connection tracking
set enabled=yes tcp-syn-sent-timeout=5s tcp-syn-received-timeout=5s tcp-established-timeout=1d tcp-fin-wait-timeout=10s \
tcp-close-wait-timeout=10s tcp-last-ack-timeout=10s tcp-time-wait-timeout=10s tcp-close-timeout=10s udp-timeout=10s \
udp-stream-timeout=3m icmp-timeout=10s generic-timeout=10m tcp-syncookie=no
/ ip firewall service-port
set ftp ports=21 disabled=no
set tftp ports=69 disabled=no
set irc ports=6667 disabled=no
set h323 disabled=yes
set quake3 disabled=no
set gre disabled=yes
set pptp disabled=yes
/ ip hotspot service-port
/ ip hotspot profile
set default name="default" hotspot-address=0.0.0.0 dns-name="" html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0 \
smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no use-radius=no
/ ip hotspot user profile
set default name="default" idle-timeout=none keepalive-timeout=2m status-autorefresh=1m shared-users=1 \
transparent-proxy=yes open-status-page=always advertise=no
/ ip dhcp-server config
set store-leases-disk=5m
/ ip ipsec proposal
add name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=30m lifebytes=0 pfs-group=modp1024 disabled=no
/ system logging
add topics=info prefix="" action=memory disabled=no
add topics=error prefix="" action=memory disabled=no
add topics=warning prefix="" action=memory disabled=no
add topics=critical prefix="" action=echo disabled=no
add topics=wireless prefix="" action=memory disabled=no
add topics=state prefix="" action=memory disabled=no
add topics=route prefix="" action=memory disabled=no
/ system logging action
set memory name="memory" target=memory memory-lines=100 memory-stop-on-full=no
set disk name="disk" target=disk disk-lines=100 disk-stop-on-full=no
set echo name="echo" target=echo remember=yes
set remote name="remote" target=remote remote=0.0.0.0:514
/ system upgrade mirror
set enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 check-interval=1d user=""
/ system clock dst
set dst-delta=+00:00 dst-start="jan/01/1970 00:00:00" dst-end="jan/01/1970 00:00:00"
/ system watchdog
set reboot-on-failure=yes watch-address=none watchdog-timer=yes no-ping-delay=5m automatic-supout=yes auto-send-supout=no
/ system console
add port=serial0 term="" disabled=no
/ system identity
set name="AP Master Gume Reservas"
/ system note
set show-at-login=yes note=""
/ system routerboard settings
set baud-rate=115200 boot-delay=1s boot-device=nand-if-fail-then-ethernet enter-setup-on=any-key cpu-mode=power-save \
memory-test=no cpu-frequency=264MHz boot-protocol=bootp enable-jumper-reset=yes
/ system ntp server
set enabled=no broadcast=no multicast=no manycast=yes
/ system ntp client
set enabled=no mode=unicast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/ port
set serial0 name="serial0" baud-rate=auto data-bits=8 parity=none stop-bits=1 flow-control=hardware
/ ppp profile
set default name="default" use-compression=default use-vj-compression=default use-encryption=default only-one=default \
change-tcp-mss=yes comment=""
set default-encryption name="default-encryption" use-compression=default use-vj-compression=default use-encryption=yes \
only-one=default change-tcp-mss=yes comment=""
/ ppp aaa
set use-radius=no accounting=yes interim-update=0s
/ queue type
set default name="default" kind=pfifo pfifo-limit=50
set ethernet-default name="ethernet-default" kind=pfifo pfifo-limit=50
set wireless-default name="wireless-default" kind=sfq sfq-perturb=5 sfq-allot=1514
set synchronous-default name="synchronous-default" kind=red red-limit=60 red-min-threshold=10 red-max-threshold=50 \
red-burst=20 red-avg-packet=1000
set hotspot-default name="hotspot-default" kind=sfq sfq-perturb=5 sfq-allot=1514
add name="default-small" kind=pfifo pfifo-limit=10
/ user
add name="admin" group=full address=0.0.0.0/0 comment="system default user" disabled=no
/ user group
add name="read" policy=local,telnet,ssh,reboot,read,test,winbox,password,web,!ftp,!write,!policy
add name="write" policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,!ftp,!policy
add name="full" policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web
/ user aaa
set use-radius=no accounting=yes interim-update=0s default-group=read
/ radius incoming
set accept=no port=1700
/ snmp
set enabled=no contact="" location=""
/ snmp community
set public name="public" address=0.0.0.0/0 read-access=yes
/ tool bandwidth-server
set enabled=yes authenticate=no allocate-udp-ports-from=2000 max-sessions=10
/ tool mac-server ping
set enabled=yes
/ tool e-mail
set server=0.0.0.0 from="<>"
/ tool sniffer
set interface=all only-headers=no memory-limit=10 file-name="" file-limit=10 streaming-enabled=no streaming-server=0.0.0.0 \
filter-stream=yes filter-protocol=ip-only filter-address1=0.0.0.0/0:0-65535 filter-address2=0.0.0.0/0:0-65535
/ tool graphing
set store-every=5min
/ tool graphing resource
add allow-address=0.0.0.0/0 store-on-disk=yes disabled=no
/ tool graphing interface
add interface=all allow-address=0.0.0.0/0 store-on-disk=yes disabled=no
/ routing ospf
set router-id=0.0.0.0 distribute-default=never redistribute-connected=no redistribute-static=no redistribute-rip=no \
redistribute-bgp=no metric-default=1 metric-connected=20 metric-static=20 metric-rip=20 metric-bgp=20
/ routing ospf area
set backbone area-id=0.0.0.0 type=default translator-role=translate-candidate authentication=none prefix-list-import="" \
prefix-list-export="" disabled=no
/ routing bgp
set enabled=no as=1 router-id=0.0.0.0 redistribute-static=no redistribute-connected=no redistribute-rip=no \
redistribute-ospf=no
/ routing rip
set redistribute-static=no redistribute-connected=no redistribute-ospf=no redistribute-bgp=no metric-static=1 \
metric-connected=1 metric-ospf=1 metric-bgp=1 update-timer=30s timeout-timer=3m garbage-timer=2m
NOW A:
set ether1 name="ether1" mtu=1500 mac-address=00:0C:42:08:0D:B3 arp=enabled disable-running-check=yes auto-negotiation=yes \
full-duplex=yes cable-settings=default speed=100Mbps comment="" disabled=no
set wlan1 name="wlan1" mtu=1500 mac-address=00:0B:6B:32:BA:9E arp=enabled disable-running-check=no radio-name="Gume" \
mode=station-wds ssid="Aguila-Gume-Reservas" area="" frequency-mode=manual-txpower country=zimbabwe antenna-gain=0 \
frequency=5180 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps \
wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no \
update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 \
default-client-tx-limit=0 proprietary-extensions=pre-2.9.25 hide-ssid=no security-profile=default \
disabled=no
/ interface bridge
garbage-collection-interval=4s hello-time=2s max-message-age=20s comment="" disabled=no
add interface=wlan1 bridge=wds-bridge priority=128 path-cost=10 comment="" disabled=no
/ ip accounting
/ ip service
/ ip upnp
/ ip arp
/ ip socks
/ ip dns
/ ip traffic-flow
/ ip address
add address=10.10.0.249/24 network=10.10.0.0 broadcast=10.10.0.255 interface=ether1 comment="" disabled=no
/ ip proxy
set enabled=no port=8080 parent-proxy=0.0.0.0:0 maximal-client-connecions=1000 maximal-server-connectons=1000
/ ip proxy access
add dst-port=23-25 action=deny comment="block telnet & spam e-mail relaying" disabled=no
/ ip route
/ ip ipsec proposal
memory-test=no cpu-frequency=175MHz boot-protocol=bootp enable-jumper-reset=yes
/ system logging
add topics=debug prefix="" action=memory disabled=no
/ system clock dst
/ system watchdog
/ system console
/ system identity
set name="Gume"
/ system note
/ system ntp server
/ system ntp client
/ port
set serial0 name="serial0" baud-rate=115200 data-bits=8 parity=none stop-bits=1 flow-control=none
/ queue type
/ user
/ user group
/ user aaa
/ radius incoming
/ snmp
/ snmp community
set enabled=yes authenticate=yes allocate-udp-ports-from=2000 max-sessions=10
set enabled=yes
/ tool e-mail
/ tool sniffer
/ tool graphing
/ routing ospf
/ routing ospf area
/ routing bgp
/ routing rip
boardman
Tue Jul 04, 2006 6:34 pm
Any on these guys?
jarosoup
Long time Member
Long time Member
Tue Jul 04, 2006 6:40 pm
Your station A doesn't have wds-mode or wds-default-bridge set.
sten
Forum Veteran
Forum Veteran
Tue Jul 04, 2006 7:34 pm
jarosoup: station-wds need no wds-mode or wds-default-bridge.
boardman:
i think you could disable-running-check on your ethernet interfaces ( done in terminal console / telnet )
whenever ether port is down then IP disappears from bridge...
Move along. Nothing to see here.
boardman
Tue Jul 04, 2006 9:02 pm
Hi Sten,
Ethernet interfaces already have disable-running-check=yes , or did I missunderstood what you mean?
Any other idea?
Best
Jorge Boardman
jarosoup
Long time Member
Long time Member
Tue Jul 04, 2006 10:28 pm
sten, thanks for the correction....learn something new everyday :)
The only other thing I see is that on your AP, you don't have your WLAN set as a port on your bridge...not sure if this is causing your problem though or is even required, but we typically have our wlan in the bridge.
boardman
Tue Jul 04, 2006 10:45 pm
Hi, I fixed this, it was as jarosoup says, the wlan1 on AP was not added as a port on the bridge, but I have already tried that one before , but this time I reboot de AP so the bridge settings get applied.
Now everything is working as it should, thks guys...
Jorge Boardman
boardman
Wed Jul 05, 2006 12:06 am
Hi, I fixed this, the wlan1 on AP was not added as a port on the bridge, I have already tried that one before... no success, this time I reboot de AP so the bridge settings get applied.
Now everything is working as it should be, thks guys...
Jorge Boardman
Users browsing this forum: No registered users and 26 guests
