hajid
equal bandwidth shaping how to
Thu Jul 06, 2006 5:10 am
i have pipe to internet 512 kbps. then i want share to 4 site, ratio 1:4, when bandwidth full i want each site got equal banwidth at 128kbps CIR. i have read manual and suggest to used pcq method, please sharing.
sergejs
Thu Jul 06, 2006 7:12 am
Yes, probably PCQ queues will be the best option for you.
If you want to divide equally traffic between 4 sites.
hajid
Thu Jul 06, 2006 10:04 am
i have made queue type like this :
name="pcq-download-512" kind=pcq pcq-rate=512000 pcq-limit=50
pcq-classifier=dst-address pcq-total-limit=512000
but i still not understand about pcq-rate,pcq-limit,pcq-total-limit used for, is there some can explain more about it.
sergejs
Thu Jul 06, 2006 10:09 am
hajid,
explanation is here
You will find configuration example in the bottom of the given documentation (you wii have to change max-limit value).
