keema
Re: RouterOS v6.28 released
Tue Apr 21, 2015 11:31 am
We do not offer torrent download directly from our servers any more. You can download this torrent, download RouterOS files, associate them and then share with others.
One word...PRO! You can download, you can do this, you can do that...what can you do? Aperently not combined torrent package which should be easy to do for a user to share with others, but impossible for Mikrotik?
alexspils
Tue Apr 21, 2015 12:54 pm
We found a bug.We Have router with vrrp on it.It is master.When we do /ip neighbor discovery set 0-5 discover=yes or no vrrp becomes backup and after some time returns to master
urknall
Tue Apr 21, 2015 1:35 pm
@strods:
I think my problem directly after the update is related to the new romon feature maybe somehow:
See the two peaks in CPU Usage right after the update, nothing was changed in the config. Then i read about the new romon feature, activated it and deactivated it again and also high cpu usage was the result. That could be related to my problem somehow, though i did not initially made some changes to the config after the update, when theses problems appeared. Now the romon feature is activated again, to prevent high cpu usage...
Will investigate more and make a support ticket.
strods
Tue Apr 21, 2015 1:42 pm
alexspils - That is true, but this state should be changed back to master even within one second. Do you need to wait longer?
urknall - Fix for this RoMON CPU usage issue will be included for testing in 6.29 release candidate versions.
ittcoin
Tue Apr 21, 2015 3:36 pm
Problems with CAPsMAN with the hAP lite as APs, I've differents APs with the same configuration working together (mAP and RB751) and working ok with 6.28, hAP lite not working :-(
kristaps
Tue Apr 21, 2015 3:42 pm
ROS 6.28 seems to break the WiFi setup on my OmniTIK UPA-5HnD.
1 ap bridge with 2 virtual APs (a/n, 20/40MHz channel). Client is a Nanostation M5 (I am using wireless-fp).
Works flawless in 6.27.
After upgrade the client does not connect.
Downgrade to 6.27 fixes the problem.
Hi, could you please send supouts from both versions to support@mikrotik.com ?
skibi82
Tue Apr 21, 2015 5:05 pm
Critical bug in 6.28
After updating to version 6.28 is the problem of detection ipsec esp.
Before that could properly be described in Mangle encrypted traffic Packet Markt: IPSEC and then on filter rule i culd filter IP inside the ipsec tunnel
Since version 6.28 does not have the capability of this.
Because the above error stanol traffic on one of the VPN concentrator.
Please fix it as fast as possible
1 Rule on mangle
/ip firewall mangle
add action=mark-packet chain=input comment=IPSEC new-packet-mark=\
ipsec-encrypted passthrough=no protocol=ipsec-esp
2 Rule on forward
add action=passthrough chain=forward comment=IPSEC packet-mark=ipsec-encrypted
leroylim
Tue Apr 21, 2015 5:07 pm
I am currently on ROS 6.28 RC20. I am having an issue when upgrading to ROS 6.28 that my connectivity totally breaks.
Let me describe the issue I am having.
Currently I am using a CCR1036-8G-2S+ with a bonded link using 2 1 Gbps ports using LACP to my switch.
Over the bonded link, I have 3 VLANs, VLAN 1 - LAN, VLAN 5 - WAN1, VLAN 6 - WAN2.
In ROS 6.28 RC20, everything works fine, traffic for LAN over VLAN 1, traffic for 2 WANs with DHCP client over VLANs 5 and 6.
But when I upgrade to ROS 6.28, connectivity is totally lost, as in, I cannot ping anything over VLAN 1, when looking in Winbox -> Interfaces, I can see VLAN 1 transmitting, but never receiving anything in return. VLANs 5 and 6 DHCP client is also searching with no avail.
I have tried upgrading to ROS 6.28 twice, and rolling back to 6.28 RC 20 as connectivity was totally broken.
docmarius
Tue Apr 21, 2015 8:23 pm
Sorry for the alert.
It was a strange power failure coincidence on the client side, which resolved at the same time as my downgrade (found out today) and I never checked connectivity before the upgrade.
Upgraded again to 6.28 and it works without any issues.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
skl
Tue Apr 21, 2015 8:31 pm
After update RB941-2nd from 6.27 to 6.28 it is no more possible to connect by winbox3rc6 (was working fine until update). Winbox closes right immediatelly after writing "downloading plugins".
The same with winbox3rc9 (actually latest).
The main website of router does not contain any downloadable winbox application. ( error 404: file not found when going to http://router.ip/winbox/winbox.exe)
Winbox 2.2.18 of course does not work with smips by any chance since beginning (was never officially told by Mikrotik in advance in documentation or product page but it is how it is).
There is no winbox that could log into it.
This and other posts above are putting my expectations back. I thought recently that mikrotik changed at least a bit their approach to software development management but it is not obviously true. I am unhappy of that.
Check "open in new window", works like a charm ;)
RafGan
Wed Apr 22, 2015 12:51 am
RafGan - Normis is at MUM. Do not worry - he will be back soon :D[/quote]
Now I don't worry, I'm happy :D
Best Regards,
Raf G
TomosRider
Wed Apr 22, 2015 10:02 am
Leroylim, can you tell me, do you have direct access to your equipment or is it on remote site?
You can check if you have local access by logging into router to see if there is problem with interface mismatch.
For example, after upgrade, eth5 became eth1 and so on. In this case, you must manually adjust interface numbers.
JanezFord
Wed Apr 22, 2015 10:18 am
I upraded about 15 devices and only issues so far are lost graphing data on rb800 (but not on two rb850gx2 so I guess it's not powerpc related) and one hung rb912-2hnd which had to be netinstalled (the other identical rb912-2hnd with identical config upgraded ok). I run ipsec, ospf over ipip and gre, l2tp, capsmanv2, nat and so far it seems OK. No high cpu.
JF.
noyo
Wed Apr 22, 2015 10:24 am
Does in v6.28 "auto-before-reset.backup" is encrypted?
Because v6.27file is not encrypted and is not dangerous.
jarda
Wed Apr 22, 2015 11:06 am
Unfortunaelly not for me. Even after downgrade back to 6.27 I am not able to connect by winbox3rc9 or winbox3rc6. Strange. Even not after power cycle...
Karlsonas
Wed Apr 22, 2015 11:29 am
I had same problem, and solved by logging another system user, so problem is in winbox dll cache, we need to find them and clear to winbox work!
jarda
Wed Apr 22, 2015 2:21 pm
Well, I have just created a new "full" user and tried to log in, both with 3RC6 and 3RC9, both with "open in new window" on and off. No luck.
Juta
Wed Apr 22, 2015 2:39 pm
Problem with e-mail client still exists.
If you use TLS then the second EHLO, which is normally issued after STARTTLS, is malformed and rejected by postfix with error "Helo command rejected: invalid ip address"
tomaskir
Trainer
Trainer
Wed Apr 22, 2015 2:40 pm
Did you report this to support@mikrotik.com?
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
Juta
Wed Apr 22, 2015 2:50 pm
Just did it.
leroylim
Wed Apr 22, 2015 4:41 pm
Weird issue I had. The ports were still the same. One workaround that worked. I switched the protcol on my bridge-local from RSTP to STP. And then I changed my switch that I'm doing LACP from to STP too from RSTP.
jarda
Wed Apr 22, 2015 5:00 pm
Finally I have it. I needed to delete relevant directories in C:\Users\MyName\AppData\Roaming\Mikrotik\Winbox\ and relevant files in \sessions\ subdirectory. Shame on Mikrotik that the files are not overwritten or deleted or versioned on error automatically!
jarda
Wed Apr 22, 2015 5:08 pm
When disabling romon on 941-2nd, the cpu goes to 100% (shared between management and unclassified). When enabled back, the cpu goes to zero back. Disabling - 100%, enabling 0%, and so on...
Reboot helps.
raffav
Wed Apr 22, 2015 8:45 pm
Hello
the script to auto upgrade that is ins the wiki is not working any more
/system package update
check-for-updates
:delay 1s;
:if ( [get current-version] != [get latest-version]) do={ upgrade }
since i dont user for a while i dont know tell from witch version it stoped working i think on 6.27
when i run it on the terminal i get this and i know that the code worked in early version of ROS
any suggestion ?
[Vaselli@Raffa's MK] >
current-version: 6.28
latest-version: 6.28
status: System is already up to date
-- [Q quit|D dump|C-z pause]
status: resolving upgrade.mikrotik.com
alexspils
Wed Apr 22, 2015 10:31 pm
[quote="strods"]alexspils - That is true, but this state should be changed back to master even within one second. Do you need to wait longer?
winbox disconnect from router when vrrp changes state from backup to master.I never noticed before that when i change discovery interface settings something changes in vrrp
igb
Wed Apr 22, 2015 10:45 pm
Rapid reboot loop, out of memory, 6.28. Fine with 6.27.
System initially ran for about 30 minutes, but then entered reboot loop with a time constant of less than 30s. I managed to scp the 6.27 .npk package in during one brief window and then run "/system package downgrade" in the next to recover the router.
apr/22/2015 20:38:23 system,error,critical System rebooted because of kernel failure
apr/22/2015 20:38:23 system,error,critical Out of memory condition was detected
apr/22/2015 20:38:23 system,error,critical router was rebooted without proper shutdown
apr/22/2015 20:40:09 system,error,critical router was rebooted without proper shutdown by watchdog timer
apr/22/2015 20:41:19 system,error,critical System rebooted because of kernel failure
apr/22/2015 20:41:19 system,error,critical Out of memory condition was detected
apr/22/2015 20:41:19 system,error,critical router was rebooted without proper shutdown
RB2011 uAS. I don't think I'm doing anything exotic: prosumer PPPoE, IPv6, some queue prioritisation, nothing very complex.
payday
Wed Apr 22, 2015 10:59 pm
Hello
check-for-updates
:delay 1s;
any suggestion ?
Use command: check-for-updates once. It works this way from 6.28 but not on older versions.
rextended
Thu Apr 23, 2015 3:28 am
I just finish upgrade all my "core" routers for BGP.
Finally I can upgrade my 4 pppoe servers from 6.7 to 6.28 directly.
Two bug introduced on 6.8 are finally fixed (pppoe & EoIP mtu/mrru problems with fragmented packets).
I do not have any problem.
but for security I do:
/romon port remove [find]
Ciao Rextended non hai avuto nessun problema con ospf come qualcuno scriveva su?
Hi Rextended have you had any problem with ospf as written by someone?
Hi, I not use MPLS and OSPF or any other routing protocol,
except BGP, VRRP and "pure Routing" for failover and routing.
Because, for my network topology, other protocols over what I'm using, do not have any sense.
I'm Italian, not English. Sorry for my imperfect grammar.
gerencia@e-digitales.com
Issue upgrading to ver 6.28
Thu Apr 23, 2015 3:32 am
Hi all,
I'm no t really sure whether this is a version issue but i have upgraded 4 units so far to this ver. and 3 out of four never came back from the upgrade, all are remote units so now i have to go and check them up.
Has any one had this tiny problem upgrading to this new release?
thanks
rextended
Thu Apr 23, 2015 4:13 am
RomanHujer - Please use version higher than 6.25 on your routers with SSTP configuration. Also make sure that PFS is either enabled or disabled on both endpoints of connection;
It is not possible to upgrade all my devices at one time. SSTP Client from Small and Home Office are located throughout the world (Hong Kong, Dubai, USA, Canada, Czech Republic ..). :(
If you want take the risk of the update, must exist some benefit.
If all is working, why you want update?
rextended
Thu Apr 23, 2015 4:19 am
@strods:
Bigfoot
Thu Apr 23, 2015 7:02 am
LCD Page List not working, can not add interfaces to the LCD Page List and the Max Speed can not be set.
Abdock
Thu Apr 23, 2015 8:35 am
After the upgrade most of my links went out, although it said 1 neighbor on each side, but the traffic would not flow. I do not see anything concerning OSPF on the change log from .27 to .28 but this one broke the ospf, i had to downgrade and for some routers to come back online had to restart manually.
strods
Thu Apr 23, 2015 8:37 am
alexspils - It will be fixed in 6.29
jarda - RoMON CPU load issue will also be fixed in 6.29 version
igb - Please send e-mail to support@mikrotik.com with description of problem and include supout files. We will check what is going on there
payday - Now check for update is dynamic. If you run "/system package update upgrade", then router will be upgraded if new version is available. If it is not then it will not do anything. Before running this command you need to run "/system package update check-for-update". Basically this script:
/system package update check-for-update once
/system package update upgrade once
gerencia@e-digitales.com - Please write to support. Name versions from which you did the upgrade and provide supout file so we can check if we can reproduce it locally
Bigfoot - Timeout and Max Speed can be configured under "LCD Interface" menu. Not under "LCD page" menu
Abdock - Please write to support. Provide supout file so we can check if we can reproduce it locally.
RomanHujer
Thu Apr 23, 2015 9:50 am
Freeze forever no 6.25 is not a good idea. (reasons for update: support for new hardware, security updates, new features ....)
pehavel
Thu Apr 23, 2015 10:56 am
*) lte - ZTE MF823 may loose configuration;
What does that mean exactly?
Thank you
strods
Thu Apr 23, 2015 11:29 am
pehavel - It means that issue "ZTE MF823 may loose configuration" is fixed in this version
gabeselig
Thu Apr 23, 2015 4:09 pm
I have found the following issues:
Speed/Duplex negotiation issue between Netmetal5 and RB1100 will not link at 1 Gb. If the same netmetal5 is connected to a CCR1036, it will negotiate at 1 Gb. I have found two instances already.
If the same RB1100 model (the ones listed above experiencing link speed issues) is connected to a RB922UAGS-5HPacD (instead), it will link at 1 Gb when that RB912UAG is running version 6.25 (RB version 3.17). If that RB922UAGS is upgraded to version 6.28 (RB version 3.22), the link will still negotiate at 1GB. The speed issue appears to only exist between the Netmetal5 and the RB1100
Unfortunately, I have just finished testing on a third set of netmetal5 and RB1100 and it linked up at 1 Gb and acted fine. It may be an issue with PoE and voltage supplied or something else entirely.
When doing a system export, the /system health will not export and will time out on a PowerPC (RB1100). This is also duplicated twice on two separate RB1100s. This is not an issue on a 1100AHx2 and is not an issue on a 1100AH.
When in the winbox GUI, only on the RB1100 models, the system health section will not open up properly and will only provide three buttons, OK, Cancel, Apply.
On the CRS125 model, when a mikrotik branded SFP (have not tested other brands) is inserted (even after rebooting / reseating SFP, reseating fiber), the SFP does not report any DOM measurements. This is only tested on mikrotik's Single Model 1 Gb SFP (S-31DLC20D)
rextended
Thu Apr 23, 2015 4:12 pm
On what hardware?
I have checked one CCR1036-12G-4S and one 2011UiAS, no problem on both.
rextended
Thu Apr 23, 2015 4:29 pm
Mikrotik without igmp snooping and DHCP snooping is cheap toys !
We really need to switch IGMP and DHCP snooping.
Please stop to post this everywhere.
If you need DHCP snooping, use only MikroTik switch devices and simply do it with scripting.
TomosRider
Thu Apr 23, 2015 4:43 pm
Testing this release on couple of 750's...so far, so good...:)
Re: Issue upgrading to ver 6.28
Thu Apr 23, 2015 5:07 pm
Hi all,
thanks
Already went to the site and performed a manual reboot (Power out) and voila....up again.
tolkn
Thu Apr 23, 2015 5:38 pm
+1 memory leak in my 2011. Downgrade to 6.27 fix cyclic reboot.
DjM
Thu Apr 23, 2015 5:58 pm
Hello MikroTik support team,
[Ticket#2015032266000169]
I'm still not able to add a comment for /ip dhcp-server alert via CLI, please see ticket for details.
leandrobianchin
Thu Apr 23, 2015 11:43 pm
I have 1 ccr (1036-8G-2S+) and 4 crs (226-24G-2S+) with ring topology via fiber optic 10Gb and bridge with rstp protocol.
Everything was working fine until I upgrade to version 6.28, which occurs following the fall of sfp ether and interfaces that are part of the bridge (rstp). Other ports are still normal.
Has anyone had this problem?
Thank you.
sx10
Fri Apr 24, 2015 1:20 am
Is there a problem with the release candidate changelog on the download page? I see we are up to 6.29 RC10 but the changelog hasn't been updated in weeks (still 6.28 rc20).
leandrobianchin
Fri Apr 24, 2015 3:31 am
At first I saw nothing regarding this problem.
How was working perfectly before I went back again to the 6:27 version, which solved the problem.
Grateful for the help sx10.
armandfumal
Fri Apr 24, 2015 5:26 am
Hi all,
Upgrade to 6.28, CCR1036
after 20 mins my BGP config disappear, no more instance, no more config possible.
autosuppout created.
reverse to 6.27 resolve the problem.
ticket created at support.
anybody has the case ?
regards
Armand
Armand Fumal
________________________________________________________________
MikroTik & Ubiquity
strods
Fri Apr 24, 2015 8:22 am
Changelog for 6.29rc version is now uploaded to our download site. Sorry about a delay.
Abdock
Fri Apr 24, 2015 9:09 am
Hello Strods, Can we have the changelog for this rc release.
Thanks.
PatrickKan
Fri Apr 24, 2015 9:56 am
I have the same problem as leandrobianchin except my CRS-226 just has a 10GBE uplink to the CCR1036 via SFP+. The uplink also serves as the master of the entire CRS. The CCR has been running ok on 6.28 and 6.29rc10 but SFP+ on CRS has been a frequent problem after 6.27. So far I've found the relatively stable combination being with CCR running 6.27 or 6.28 or 6.29rc10 and CRS running 6.27. But even this combination still causes one SFP+ incidence on CRS every 5-6 days.
strods
Fri Apr 24, 2015 10:16 am
Abdock - Changelog is available at our download site:
http://www.mikrotik.com/download/share/ ... evnote.txt
gaid78
Fri Apr 24, 2015 11:41 am
rextended
Fri Apr 24, 2015 2:56 pm
Hi all,
regards
Armand
What model?
I have only some CCR1036-12G-4S and no one have this problem.
KBV
Fri Apr 24, 2015 5:54 pm
Router RB850Gx2 hangs on reboot if serial port is removed from the /system console
[admin@RB850Gx2] > /system console print
Flags: X - disabled, U - used, F - free
 #   PORT                                  TERM
RouterBOOT booter 3.22
RouterBoard 850Gx2
CPU frequency: 533 MHz
  Memory size: 512 MiB
    NAND size: 512 MiB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Then the network is not running, the port LEDs do not light
Cycling the power helps
tomaskir
Trainer
Trainer
Fri Apr 24, 2015 6:19 pm
 #   PORT                                  TERM
RouterBoard 850Gx2
    NAND size: 512 MiB
Please report it to support@mikrotik.com
KBV
Fri Apr 24, 2015 6:27 pm
I'm sorry :(
Router RB850Gx2 randomly hangs on reboot. I could not find regularities.
Relationship with the / system console has not been confirmed.
Well, I'll write our support.
armandfumal
Fri Apr 24, 2015 8:21 pm
Hi all,
regards
Armand
What model?
CCR1036-12G-4S, autosuppout has been created by the problem and has sent to support, waiting reply from them...
Armand Fumal
MikroTik & Ubiquity
dcavni
Fri Apr 24, 2015 11:51 pm
Every update of RouterOS kills my Ip Adress list, so i have to manualy reconfigure it. Is this a bug or a feature?
IntrusDave
Sat Apr 25, 2015 12:22 am
Is your Address List dynamic or have a timeout?
I have have an Address List of 3900 IP's (my blacklist), I have never lost it during an update.
David Joyce
Network & Security Engineer
Intrus Technologies, LLC.
Rancho Cucamonga, CA, USA
ufm
Sat Apr 25, 2015 12:48 am
Judging by the fact that 6.29rc11 crashes with kernel panic where works 6.27 - we are waiting for an interesting version. :)
lectrapon
Sat Apr 25, 2015 2:35 am
I need your help about my METAL 2SHPn with preinstalled system 5.26 (and firmware 3.22).
I upgrade to 6.27 and I noticed that my wireless was not stable (connect and disconnect).
After upgrade to 6.28, I noticed that the LOG menu can’t list something about DEBUG DHCP, HOTSPOT, WEB-PROXY when I add it in System > Logging menu.
And it seem like wireless card is not enabled even if I can detect it with Computer or Smartphone.
When I try to connect…I see only « connection » in my host client and nothing is listed in LOG window.
I have downgrade to 6.27 and 5.26 but nothing have changed. :(
rubber
Sat Apr 25, 2015 5:03 am
I need some help please.
I have Mikrotik RB850Gx2 running RouterOS 6.28. There are about 30 or so ppttp-clients connecting to it.
Every now and then, the RB850Gx2 logs the following error: Encryption got out of sync - disabling :(
npero
Sat Apr 25, 2015 11:34 am
Any one have problem on 411U reading health menu ?
I upgrade 411U to 6.28 health stop working.
I need voltage it is only way to check battery. :(
[admin@Jna AP] /system health> print
action timed out - try again, if error continues contact MikroTik support and send
a supout file (13)
Also can't make supout.rif.
Back to 6.27, for now stop future network upgrade to 6.28.
Clauu
Sat Apr 25, 2015 1:31 pm
@npero on my gx2 i had the same problem but after another reboot it get back to normal.. try a reboot
I have the same issue with the gx2..
Having fun with RB850Gx2, RB2011UiAS-2HnD, RB260GSP, RB751U-2HnD, CRS112, RB3011UiAS, hAP ac, cAP ac and hAP ac². More others on the way :-)
dcavni
Sat Apr 25, 2015 10:23 pm
One entry is dynamic (PPPoE connection) and two are static (Mikrotik's LAN and another adress range so that i can acess modem on Ether1Gateway.
Bigfoot
Sun Apr 26, 2015 9:18 am
apr/24/2015 06:03:25 system,error,critical System rebooted because of kernel failure
apr/24/2015 06:03:25 system,error,critical Out of memory condition was detected
apr/24/2015 06:03:25 system,error,critical router was rebooted without proper shutdown
rubber
Sun Apr 26, 2015 10:31 am
Restart is invalid, and no way to solve :(
thedix
Sun Apr 26, 2015 12:51 pm
I upgraded my RB750G from 6.27 to 6.28 and see increasing sector writes when router is idle.
Downgrading to 6.27 solve the problem.
Steps to repeat this issue:
1. Reboot.
2. Enable/disable any rule at Firewall/Filter Rules or Firewall/NAT.
3. See increasing sector writes at System/Resources.
There are users with similar problem:
http://forum.mikrotik.com/viewtopic.php?t=96157
urknall
Sun Apr 26, 2015 1:15 pm
i can confirm the sector write problem. after some monitoring i found out, that the problem probably might be that i have dynamically created address lists in firewall, which is causing this issue for me. i have alot of other services running like dhcp dns ntp but i haven't had time to check them all, but it think its firewall releated somehow...
thepoll
Sun Apr 26, 2015 4:31 pm
Updated RB2011UiAS-2HnD-IN from 6.22 to 6.28 and after update it was unreachable and when I looked at the router:
the LCD was all white,
Leds of the Gig-ports where flashing normal,
Leds of Fa-ports all off.
Poweroff-on results in immediate white lcd and (Normal looking) flashing Gig-portleds, no connection possible.
Poweroff with reset-button pressed results in:
(normal looking) lcd with "reboot configuration" message, and after short time all leds on, all leds off, followed by:
White lcd,
blinking Gig-leds,
Fa-leds off,
Tried netinstall - router seems to react normally - it appears in Netinstall with MAC, and during netboot the Gig-leds and the Fa-leds blinks like normally.
Installation proceeds normally, "waiting for reboot" and after reboot -> in Netinstall "Status OK" -> On router: White led, Gig leds blink, Fa-leds off. Router unreachable. Tried it with OS 5.26 netinstall -> Same result.
Tried it with no equipment attached back2back to pc -> status OK but router not working.
Also on the console-port CTS and DSR on but no RXD or TXD.
(forgot to mention: SFP-int does not seems to work when connected)
According to the (apparently) working netinstall-cycle the router isn't complete dead but after several times trying the above procedures, tried connection on RoMon in Winbox,Winbox connection on MAC... my brain is drained (for now).
Allthough 18 years of networking experience (mainly Cisco), I've not much experience with Mikrotik.
Does anyone has suggestions for solving this problem?
Thanks in Advance!!
Kind regards, Thepoll
BartoszP
Sun Apr 26, 2015 6:05 pm
Simple load sharing VRRP setup for 2 x RB1100AHx2 @ 6.28 taken from: http://wiki.mikrotik.com/wiki/Manual:VRRP-examples
/interface vrrp
add arp=proxy-arp interface=BRGLAN192 name=VRRP-13-GW-254 priority=254 vrid=13
add arp=proxy-arp interface=BRGLAN192 name=VRRP-17-GW-1 priority=1 vrid=17
add address=192.168.1.13/24 interface=VRRP-13-GW-254 network=192.168.1.0
add address=192.168.1.17/24 interface=VRRP-17-GW-1 network=192.168.1.0
On the second RB priorities are just swapped so VRRP-13-GW-254 is Master GW for DHCP users.
VRRP-17-GW-1 is not used but active. RBs are connected to the same switch.
Each RB is connected to different ISP.
The problem:
VRRP changes Master without reason from RB1 to RB2 for a while and goes back.
For VRRP-13 master I have up/down scripts logging change but there is no log activity.
There are only 3 devices running now in the LAN, ISPs are reliable.
There is no reason for such behaviour.
Real admins use real keyboards.
alireza6917
Mon Apr 27, 2015 8:12 am
Hi
I am wondering why don't you add important stuff like 'TR101' to routeros?
We have a big ADSL network and we use routerboard as BRAS.
We need user port information to be passed to RADIUS but routeros does not support this.
Because of this we are forced to buy cisco routers.
Could you please consider adding this feature to routeros?
Best Regards
karina
Mon Apr 27, 2015 4:38 pm
sounds like these must be dynamic lists that are deleted whenever the router is rebooted. I have never see this with static lists
IPANetEngineer
Trainer
Trainer
Mon Apr 27, 2015 5:10 pm
It shouldn't matter, but i'm curious which SFPs you are using?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
mirolm
Mon Apr 27, 2015 8:44 pm
I runned to another case of increasing sector writes at System/Resources. Steps to reproduce:
- open winbox.
- check sector writes first to check it is not changing.
- go to ip --> firewall --> connections.
- stay there browse the list.
- sector writes start to increase by 1 - 2 every second untill you reboot router.
I observe this on my RB951G-2HnD. RouterOS 6.28.
ditonet
Forum Veteran
Forum Veteran
Mon Apr 27, 2015 9:03 pm
- open winbox.
Same on RB433AH...
Regards,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
tron
Mon Apr 27, 2015 9:29 pm
1) Close Firewall window and then close Winbox.
2) Run Winbox.
3) What about sector writes? I don't see any increasing now...
mirolm
Mon Apr 27, 2015 9:33 pm
2) Run Winbox.
Hmm you are right. They stop to increase after you restart winbox.
rextended
Mon Apr 27, 2015 11:48 pm
After some year of RouterOS i notice one strange thing:
why I never have one sinle problem during update (*)???
I think because I use this method for update/upgrade the bios and the OS:
When I buy the RouterBOARD and arrive to office:
1) update the board with latest BIOS,
2) use latest netinstall to install the RouterOS I consider stable: actually 6.20 for non "ac" CPE(**) and 6.27 for non-CPE devices or new "ac" CPE
without keeping previous configuration and use only routeros-xxxx.npk instead of single files.
it also remove any distributor branding: the wisp service is mine, not of my distributors....
if needed I add not included packages like user-manager, ntp or Multicast at the same time of netinstall
3) disable (NOT REMOVE) unused packages, like hotspot on standard CPE
4) reset config without keep user, without any backup and without default configuration
5) now I configure the device as needed.
For update, or I do it online with system/package/upgrade or i put routeros-xxxx.npk inside the file folder or i download it by system/auto-upgrade and I reboot.
1) make one export compact, backup and database backup
2) upgrade
3) make another export compact
4) compare the two export and if something different, investigate why and make some decision about what is changed.
5) Fix the settings changed or set the new defaults, like this:
on new export:
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/ip upnp
set allow-disable-external-interface=yes
alig to default routeros value:
/ip ipsec policy
set [find where dst-address=0.0.0.0/0 src-address=0.0.0.0/0] dst-address=::/0 src-address=::/0
/ip upnp
set allow-disable-external-interface=no
(*) = not counting this two, are bug not related to updating but inside the update:
[pppoe server + eoip = MTU kernel panic] and [pppoe encryption + EoIP = kernel panic] from 6.8 to 6.27, solved on 6.28
(**) = because I want all the CPE at the same software release for better manage any problem or for fast configure all devices when something change.
bclewl1ns
Tue Apr 28, 2015 3:21 am
Can we get some Wireless improvements to NV2 in this release.
Brett
What is understood need not be discussed.
angboontiong
Tue Apr 28, 2015 3:36 am
Any new thing for the wireless ???
strods
Tue Apr 28, 2015 8:34 am
Issue with sector writes rising will be fixed in version 6.29. If you want to test it, then fix for it will be included in RouterOS starting from 6.29rc13 version when it comes out.
bclewl1ns
Tue Apr 28, 2015 11:01 am
Hate to sound like a broken record. But we really need some fixed for TCP traffic over NV2. Any Idea when that is going to happen.
Brett
ste
Tue Apr 28, 2015 11:19 am
To less people urge Mikrotik to do work for this. I tried for a long time now. My only solution is to replace MT where I see this problem.
bclewl1ns
Tue Apr 28, 2015 11:37 am
I am afraid i am going to have to start doing the same thing. It is to hard to have Links that should do 200 or 300 Meg getting 10 Meg TCP. I have lost customers over this.
Brett
Lakis
Forum Veteran
Forum Veteran
Tue Apr 28, 2015 12:54 pm
:) yep fanny isnt it!?
I have links using nstreme can go up to 100mbit, when switched to nv2 it can barely go 20 to 30mbits
And when AC txpower will be fixed?
rextended
Tue Apr 28, 2015 1:18 pm
BUG:
"export" do not export keepalive enabled if keepalive=10,10
ste
Tue Apr 28, 2015 2:53 pm
This is even more funny going over multiple hops or/and using .ac. You've great (udp)bandwidth but the customer blames you what the sh... you're selling him.
strods
Tue Apr 28, 2015 3:24 pm
rextended - Thank you. We already are familiar with this issue. It is reported to developers. You should be able to see it if you run verbose export.
CyberTod
Long time Member
Long time Member
Tue Apr 28, 2015 4:02 pm
In changelog for 6.29rc I see this change :
vrrp - do not reset interface when no interesting config changes;
Can this be expanded for all interface types and other items ? Especially when adding/changing comments.
bclewl1ns
Wed Apr 29, 2015 12:54 am
We are seeing decreased in every part of our network because of this problem. Nstream does not handle Multipoint well. 802.11 has high latency and NV2 had TCP throughput problems. I really wish (REALLY WISH) Mikrotik would spend some time on Fixing this issue and others related to CORE service rather then releasing all these NEW Features.
New Features + Existing Buggs= MORE BUGGS.
Sorry Need to vent I have a 100% Mikrotik Network and Now competitors with Ubiquity are running faster them I am. Does not do my heart well.
Brett
armandfumal
Wed Apr 29, 2015 9:01 am
Hi all,
regards
Armand
What model?
Ok BUG confirmed, Support told this will be fix in the next release...
Armand Fumal
MikroTik & Ubiquity
macgaiver
Wed Apr 29, 2015 9:36 am
Have you investigated how NV2 works?? and also how TCP works??
Try to do the test in the middle of night when your TCP connection is only traffic on the link.
Then try to do the same test in the morning when half link is busy with clients traffic.
You will see that your test will give better results in the morning when there are some other traffic on the link.
It is just the way NV2 works..., if all you need is single TCP connection - DO NOT USE NV2...
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
imTIgger
Wed Apr 29, 2015 10:07 am
6.28 seems broken to me (RB951G-2HnD)
Random reboot every few minutes.
strods
Wed Apr 29, 2015 10:11 am
imTIgger - Please reboot your device, generate supout file and then wait until your RAM memory fills up. Then generate another supout file. Send both of these files to support@mikrotik.com. Make sure that your device is not completely frozen when you try to generate second file.
bclewl1ns
Wed Apr 29, 2015 10:26 am
Thanks of the reply. Yes I have investigated how NV2 works. Don't let the Newbie fool ya. I have been working with Mikrotik for along time. The simple problem is TCP over NV2 in a PTMP environment is increasingly painful. Latency it to high and TCP throughput is severely decreased. And let me be clear. I only use NV2 in PTMP systems. I also did at test with with support from customer on one of my cleanest sectors. 5 RB911 AC CPE's connected to a RB921 netMetal AP. Speed via NSTREAM on all customers was in excess of 50 Meg TCP up and down (All customers testing at the same time). When i switch to NV2 Speed decreased to just above 10 Meg down and 6 to 7 up. I would not call that a single TCP connection. So are you sure you really know what you don't know!!
Brett
imTIgger
Wed Apr 29, 2015 10:29 am
strods - Okay, I have created a support ticket on the website.
Actually, it reboots almost every minute.
uptime: 1m8s
version: 6.28
build-time: Apr/15/2015 15:18:31
free-memory: 12.7MiB
total-memory: 128.0MiB
I downgraded to 6.27 and everything works again, with ~100MiB free memory most the time.
macgaiver
Wed Apr 29, 2015 11:21 am
The simple problem is TCP over NV2 in a PTMP environment is increasingly painful...
PTMP environment... that was the significant information that was missing....
Please, make sure that you point that out.. cause PtP it works as it should.
Also there is no need to refer to this problem in every unrelated forum topic, it doesn't work - you need to write to support@mikrotik.com
In any case PTMP NV2 is not the most common config, especially with 802.11ac around. So on global scale significance of the fix vs. time to fix it simply doesn't cost the effort. So you might need to work around it.
ibm
Wed Apr 29, 2015 11:47 am
Probably is not the most common but there are thousand and thousand AP that are working with NV2 in PtMP and this is the only protocol that can compete with airmax.
ste
Wed Apr 29, 2015 11:59 am
No. If your traffic passes multiple ptp connections your tcp-speed decreases with every nv2 ptp hop. So the problem ist with ptp, too.
They know the problem but it has no priority due to not enough users urge them to work on that. Writing to a forum is "urge them". Your statement is: Everything is fine just ignore this.
There is no solution to work around. You can try to use nstreme but nstreme is very sensitive to interference so you get faster tcp-speeds but with disconnects.
macgaiver
Wed Apr 29, 2015 12:14 pm
Over saturated links - no problem. I have 5 ptp hops
If link is almost empty, then i observe the same decrease, but it is only logical.
Sorry, but Hijacking topics is simply impolite! Create a topic and spam in it as much times as you like!
Lakis
Forum Veteran
Forum Veteran
Wed Apr 29, 2015 2:52 pm
macgaiver: 'cause PtP it works as it should' - using nv2 hm... 99% I am not sure about that, well you should try nstreme and see how it should work - except disconnect problem (yep ste:nstreme is very sensitive to interference) but noting is done past 2 years.
And again Mikrotik please give me a simple answer when AC txpower will be fixed?
ste
Wed Apr 29, 2015 3:09 pm
Just stop spamming :lol:
bclewl1ns
Thu Apr 30, 2015 5:52 am
Well it looks like i touched a nerve. Look I believe that Mikrotik is a fantastic system. But I am noticing an ongoing problem with NV2 and TCP connections. And as everyone here knows TCP works in multiple streams However. When your delivering a 25 Meg Connection to a user and they get on a speediest server and continually complain about speed. It becomes and issue. Especially when UBNT does great at those tests. I have also submited trouble tickets on tcp and nv2 speed problems and you get no response the only place you have to URGE a response is in the forums. There are also MANY posts on this in the forums. To draw some attention we post in the New Release forums. It is not an attempt to complain to complain or to spam for spamming sake it is an attempt to let the company who I have spend Thousands of Dollars on know that it is a REAL PROBLEM. We invest in this infrastructure we rely on it. We make our livings off of it. Please explain to me why in a forum on RouterOS release and beta testing it is considered spamming a topic to discuss a PROBLEM with ROUTEROS.
Brett
Lakis
Forum Veteran
Forum Veteran
Thu Apr 30, 2015 11:50 am
ste quote "Just stop spamming :lol:" it was just a joke
look bclewl1ns NV2 does not work like that, not like on Mikrotik web "Performance test results", in real world u can not expect in PTMP situation AP to deliver 150mbit to station. And in some parts u are right nv2 needs lot of improvements
especially for the P2P situation
turnip
Thu Apr 30, 2015 4:02 pm
I can confirm this - updated 3 routers to 6.28 and enabled RoMON. Tested it then switched it off. CPU usage sits at 100% for single processor (CRS125) and 50% for dual core (x86) router. Switched it back on and disabled all RoMON ports, and it's back to normal.
ROS 6.28, RB2011UAS-2HnD
try this
1) Tools -> RoMON, check ENABLE, click OK
2) Tools -> RoMON, uncheck ENABLE, click OK
CPU usage will be 100%, you must enable it again.
mnemo
Sat May 02, 2015 8:46 pm
I have a RB850Gx2 and when I update from v6.26 to v6.28 with the upgrade package I had a problem becouse the multicast package disappeared.
The solution is to load the muticast package from "All packages" package.
Please, solve it in the next update.
rpingar
Long time Member
Long time Member
Sat May 02, 2015 10:10 pm
I have the same exact experience,
tcp single stream is a very big issue in umltiple nv2 hop and in a ptmp.
nstream is very sensitive and with disconntions, only latest release and ac hardware seems little bit better.
Hope MT can get better.
But lately (2 years) they seems more focused on other part of the business.
regards
Ros
bclewl1ns
Sun May 03, 2015 7:49 am
Not sure were you got the 150M in my posts. And I am aware that NV2 Does not work like that and I can never expect 150 Meg on a PTMP link I am looking back and can't find were in this thread i have stated that. However, their are items that need to be addressed.
1. Latency - Even using auto on the NV2 Setting latency is way to high.
2. Jitter - It is increasely getting worse on NV2 Links
3. TCP Throughput Should be more stable and better then 10% of UDP
I am aware of NV2's benefits and its shortcomings. My only POINT is that instead of doing all these new features LETS Stabilize a issue that is effecting current users.
Brett
ibm
Sun May 03, 2015 11:50 am
+1
spacemind
Mon May 04, 2015 2:00 am
Upload rate in queues is shown in bits instead of kb alson on this version.
The queues are set in radius.
Chupaka
Mon May 04, 2015 3:11 pm
1228800 bps is 1228,8 kbps, and WinBox does not round limits in output. for example, 1228000 should be shown as 1228k
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
ddejager
Mon May 04, 2015 4:32 pm
This item does not seem to be listed in the changelog for 6.29. Is it, in fact, fixed? If it will take a long time for 6.29 to be released (due to the addition and testing of fast-track) can this fix be provided independently sooner?
[Update: it is showing up in the changelog now, perhaps I just missed it earlier]
bosuagwu
Mon May 04, 2015 4:48 pm
is quite cool. Nice work.
usmanahmed
Tue May 05, 2015 12:50 pm
Dear Mikrotik Support,
I have CR1036-12G-4S on version 6.28 and we are facing issue in guest page (hotspot) page that its not opening. we have to restart the router to resolve the issue. please look into it and if any logs is required from my side, please let me know, i will provide the logs on this forum
Usman Ahmed
PastuhMedvedey
Tue May 05, 2015 2:26 pm
jan/02/1970 00:41:33 system,error,critical System rebooted because of kernel failure
jan/02/1970 00:41:33 system,error,critical Out of memory condition was detected
jan/02/1970 00:41:33 system,error,critical router was rebooted without proper shutdown
jan/02/1970 00:41:37 interface,info sfp-sfpplus1 link up (speed 10G, full duplex)
jan/02/1970 00:41:38 interface,info sfp-sfpplus2 link up (speed 10G, full duplex)
During the test (traffic generator), the router reboots spontaneously. The test involved two 10G interface.
Router - CCR-1036 8g-2s+ . Supout file sent to support.
RB751U-2HnD, RB2011LS, RB1100AH, RB433, RB411GL, RBSXT, CCR1016
rextended
Tue May 05, 2015 9:55 pm
Now are 15 days after I have installed the 6.28 on my border BGP routers, my gateways, firewalls and user-managers.
No one single problem, except I must reboot one time each devices for update the software from 6.27 to 6.28 :)
MikroTik: Is possible to update the software without reboot the machines? :lol:
Chupaka
Wed May 06, 2015 12:54 am
on 17th day one of my CCRs became loosing packets on _some_ neighbour routers until reboot... I hope it was just a Moon in wrong phase :)
wfebbo
Wed May 06, 2015 2:09 am
After update Router OS 6.28 RB1100AHx2 not send e-mail backup!
Error: timeout occured
paoloaga
Wed May 06, 2015 3:14 am
I am experiencing troubles with the MTU on PPPoE session through a VLAN on a RB2011. The automatic mangle rule that changes MSS to 1440 seems not to work correctly. If I manually add a mangle rule that sets MSS to 1400 everything works again. The router was working correctly with v6.22. I also tried 6.29rc14 and the behaviour is the same as v6.28.
I hope to find the time tomorrow to open a ticket, generate the supout and try to find the exact steps to reproduce this bug.
sinaexer
Wed May 06, 2015 8:28 am
Hi
Unfortunately, the new version (6.28) web proxy does not work
Please check :(
kivimart
Wed May 06, 2015 9:23 am
Hi
Please check :(
i have 2 diffrrent RB that runs web-proxy on 6.28, no problem
bclewl1ns
Wed May 06, 2015 10:10 am
+1
So Interesting info to share. We replaced some of our backhaul links with Mimosa. Previously we had PTP RB921 Net Metals with NV2 because well it is the only one stable. We were getting 275 Meg up and Down. (Not to shabby) on the NetMeals. The Mimosa is doing 720 up and Down. Also Latency is only 2 MS verses 8 to 15 on the NV2 Link. All that is great However the most interesting item to note is The bandwidth on all of our NV2 PTMP sectors Went back to normal. Customers called us to inform us that the bandwidth was better then it was before. Testing we were getting 90 Meg UDP and 85 TCP on 911ac CPE's connected to a 921 Netmetal Ac sector. I was amazed out how much the CPE performance was increased when we moved out the NV2 PTP's in the system.
We also tested this with a older RB911 N link to a secondary site with ROS 5.26 using NSTREAM - Same Result as with the mimosa. Increase in overall performance and CPE speed.
In our network we are going to move all NV2 PTP's our and replace them with other systems. Mikrotik Please make it a point in the future to fix NV2 in PTP environments
Brett
nmaton
Wed May 06, 2015 1:23 pm
For me this is one of the buggiest releases yet.
My router hangs and stops forwarding packets.
I can still connect via serial but when you issue the system reboot command .. it hangs and spews out the following (but does not reboot)
] > system reboot
Reboot, yes? [y/N]:
y
system will reboot shortly
Rebooting...
Stopping services...
(0,3) WARNING: waiting for reply message: timed out
(0,3) Now cycle 562417970394666, timeout 40000000000 cycles
(0,3) Caller 0xfffffffc00042c58 with ICS 0
(0,3) Message type 0x10f, dest 0x40
(0,3) chan 1: 271
(0,3) chan 2: 271
(0,3) chan 4: 271
(0,3) chan 5: 271
(0,3) chan 17: 271
(0,3) chan 18: 271
(0,3) chan 19: 271
(0,3) chan 20: 271
(0,3) chan 21: 271
(0,3) chan 33: 271
(0,3) chan 34: 271
(0,3) chan 35: 271
(0,3) chan 36: 271
(0,3) chan 37: 271
(0,3) chan 49: 271
This on my 2 CCR1036 routers which are configured solely for PPTP termanation purposses.
Nicolas Maton
nicolasmaton@gmail.com
CCNA/ CCDA
MTCNA / MTCTCE
Available for Mikrotik Consulting
sergejs
Wed May 06, 2015 2:47 pm
nmaton,
please contact MikroTik support (support@mikrotik.com) with attached support output files from one of your routers.
We will try to find out what is the reason for your issues. We are sorry for any inconvenience.
rextended
Wed May 06, 2015 3:59 pm
Hi
Please check :(
1) Clear Cache
2) Change the webproxy folder
3) clear again cache
retry...
formatc
Wed May 06, 2015 4:50 pm
L2TP/ipsec firewall config:
/ip firewall mangle
chain=input action=mark-packet new-packet-mark=ipsec passthrough=yes
protocol=udp dst-port=500,4500 log=no log-prefix=""
3 chain=input action=accept protocol=udp dst-port=1701 packet-mark=ipsec
log=yes log-prefix=""
4 chain=input action=reject reject-with=icmp-network-unreachable
protocol=udp dst-port=1701 packet-mark=no-mark log=no log-prefix=""
L2TP/IPsec packet does not match rule 3, but match rule 4.
It seems there is no marker after the decryption IPSEC packet.
downgrade to 6.27 solve this problem.
KillerOPS
Wed May 06, 2015 11:35 pm
bclewl1ns, i think you should also consider the increased self-interference in your setup.
I've experienced this myself. You keep adding links and customers on the towers, and you can't expect the overall performance not to degrade. Also, your competitors don't stand still. They also keep adding links and customers.
4 years ago 5Ghz was clean. Now, I think in some places 2.4Ghz is cleaner than 5.
Also, it's a pretty known fact that nstreme on n p2p links is much better compared to NV2. Nv2 has that TDMA thingie which is very useful in P2MP, but almost useless in p2p.
bclewl1ns
Thu May 07, 2015 12:13 am
I am well aware of the increased self-interference . We plan sites very carefully to avoid this as much as possible. I also agree Nstream is allot better for PTP however it has proven to be almost useless when it comes to the new AC radios. nstream disconnects frequently and throughput is about half that of NV2. Understand this is not a criticism but a info share that is showing that there needs to be some work on the PTP side of NV2 or better fixing nstream to work with ac radios. More info on self-interference, The Mimosa radios we have replaced our backhaul with are 5 Ghz radio 4X4 so it uses 160 Mhz of spectrum. If anything we polluted our environment more by adding them in. However Speeds increased significantly. They are also TDMA based radios. But they have GPS Sync.
Brett
paolopoz
Thu May 07, 2015 12:27 pm
Does anybody experienced problems with wireless disconnections after upgrading to 6.28?
I have a PtP link and after upgrading one of the two sides I keep getting disconnections with error:
lost connection received deauth class 2 frame received (6)
After downgrading to 6.27 the problem disappeared.
The board is RB711-5Hn-MMCX
The wireless card is AR5008 Wireless Network Adapter (rev: 1)
PastuhMedvedey
Thu May 07, 2015 3:14 pm
RouterOS v6.28
Slow download speeds BGP prefixes, and uneven loading the CPU.
Wrong time BGP session timer.
paolopoz
Thu May 07, 2015 3:38 pm
This is a known limitation: BGP routing table loading is single threaded thus using only one CPU.
PastuhMedvedey
Thu May 07, 2015 4:18 pm
skibi82
Sun May 10, 2015 11:39 am
When the gentlemen of mikrotik deign to reply:
Ticket#2015042166000534 Data: 2015-04-21 16:08
Post
2015-04-21 15:57
tunnel
1 Rule on mangle
/ip firewall mangle
2 Rule on forward
/ip firewall mangle
rextended
Sun May 10, 2015 5:34 pm
Post
2015-04-21 15:57
tunnel
1 Rule on mangle
/ip firewall mangle
2 Rule on forward
You mark the packet on input chain and apply the filter on forward chain.
Obviously you can not see any input marked packet on forward chain.
Use on both rules the input chain or on both rules the forwad chain.
skibi82
Mon May 11, 2015 4:55 pm
1. According to the scheme packet floow, described ipsec traffic on input should be visible on a forward with mark.
Everything works fine until 6.27
After the update above 6.28 there is now the possibility to describe traffic that it's ipsec with the ipsec
A change in the documentation does not make this any indication of change Packet floow
Please you to firstly understand what is written:
http://wiki.mikrotik.com/wiki/Manual:Pa ... decryption
rextended - And by the way, you can run as dekryptor ESP if you want to input you lead srcip
Post
2015-04-21 15:57
tunnel
1 Rule on mangle
/ip firewall mangle
2 Rule on forward
mrz
Mon May 11, 2015 6:02 pm
@skibi82: ipsec is in transport mode or tunnel mode?
skibi82
Mon May 11, 2015 8:37 pm
In Mail from 2015-04-21 15:57:23.04.2015 - Ticket#2015042166000534 was picture incluted:
YES is in tunnel mode
Sykotic
Tue May 12, 2015 12:34 pm
Hi Mikrotik support.
6.28 broke BGP signaled VLPS.
I don't have any logs as I don't have the spare equipment to do it outside of my production environment yet, however it's easy enough to reproduce. Looks like there is at least one other that can confirm the problem.
http://forum.mikrotik.com/viewtopic.php?f=14&t=96705
pingus
Tue May 12, 2015 9:46 pm
I have the same problem with rb600a:
And I am not able to downgrade, after the reboot I have still 6.28 installed...
pingus
Tue May 12, 2015 10:08 pm
Ok, got it. The npk file was in a subfolder ... :-)
rgunderson
Wed May 13, 2015 6:16 am
6.28 disabled the SFP on my CCR1009-8G-1S. Downgrading back to 6.27 let it work again.
dmi3
Wed May 13, 2015 2:30 pm
Hi!
strods told me to write my problem with 6.29RC here, and i must update it from 6.28 cuz "sector writes bug" so:
1. i have a question. Where can i find additional packets like ntp, ups, capsman2 for RC platform?
2. now i use wireless-fp to use capsman, and i got 2 routers in configuration, and i got 2 bridges in master router
i got datapath1 configurated to add all master-wifi's in first bridge_work
and cap on master router did it, but no packets pass through router to, even when cap is in bridge_work, inet working but no local connect
on my second datapath2 configuration the slave-wifi's added to bridge_free
i make simple rules to allow bridge_free clients access to 2 of bridge_work adresses and its worked, like it should
when i use capsman2 on 6.28 i didnt have such trouble, all my master-wifi's client with datapath1 can connect each others and every bridge_work (lan) clients
 caps-man datapath print
 0 name="datapath1" client-to-client-forwarding=yes bridge=bridge_work
 1 name="datapath2" client-to-client-forwarding=yes bridge=bridge_free
 interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
 #    INTERFACE              BRIDGE              PRIORITY  PATH-COST    HORIZON
 0    ether8                 bridge_work             0x80         10       none
 1    ;;; master1
      ether1                 bridge_work             0x80         10       none
 2    ;;; master2
        ether7                 bridge_work             0x80         10       none
 3 I  wlan_work              bridge_work             0x80         10       none
 4 I  ether6                 bridge_work             0x80         10       none
 5    ether9                 bridge_work             0x80         10       none
 6    ether10                bridge_work             0x80         10       none
 7 I  wlan_guest             bridge_free             0x80         10       none
 8 ID cap7                   bridge_work             0x80         10       none
 9  D cap8                   bridge_free             0x80         10       none
10 ID cap9                   bridge_work             0x80         10       none
11  D cap10                  bridge_free             0x80         10       none
[/size]
karlisi
Wed May 13, 2015 3:22 pm
CAPsMAN v1 works fine if you have separate device for CAPsMAN and separate wireless devices, but if you are using for CAPsMAN router with wireless, it won't allow packets between wireless interface and other interfaces on this router. This bug apparently is corrected in v2. There is no exact mention about it in changelog, only this: ' improved CAP<->CAPsMAN data connection protocol'
Karlis
dmi3
Wed May 13, 2015 5:00 pm
Thx fo reply!
I would gladly use capsmanv2, on my running 29rc18, but i didnt know where can i pick a npk file for RC :)
and one more time in 6.28 with v2 all works great
i got vicious circle
6.27 cant fasttrack
6.28 have "sector writes"
6.29rc doesnt have capsmanv2
what should i do? back to 6.27?
grusu
Wed May 13, 2015 5:21 pm
Thx fo reply!
6.27 cant fasttrack
Link for capsmanv2:
http://www.mikrotik.com/download/share/ ... mipsbe.npk
Change "mispbe" with you router architecture.
dmi3
Wed May 13, 2015 5:53 pm
Link for capsmanv2:
THX alot!
there are you get this? any archive or beta page with list of stuffs, or you simply write it with own logic? :)
pukkita
Trainer
Trainer
Wed May 13, 2015 6:14 pm
Have yet to test, does this apply also if set in N mode?
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
grusu
Wed May 13, 2015 9:13 pm
Link for capsmanv2:
THX alot!
The information I got from another forum post.
honzam
Thu May 14, 2015 4:08 pm
Which boards have this problem? Only mipsbe?
It is real problem or only "cosmetics" ?
LAN, FTTx, Wireless. ISP operator
strods
Thu May 14, 2015 4:19 pm
It was problem for all devices. Simply all the time something was written in memory. It did not cause any problems. Only additional process was running while Firewall menu was opened.
bclewl1ns
Fri May 15, 2015 3:25 am
I have set to only N mode however if the radio is and AC radio the problem persists.
Brett
dmi3
Fri May 15, 2015 10:00 am
Hi guys! Updating to 6.29rc20 an have some questions:
1. i found capsmanv2 on direct link http://www.mikrotik.com/download/share/ ... mipsbe.npk , but where can i find NTP packet for RC releases? Maybe someone have user-friendly web page where we can download all rc packets we need? it would be nice
2. whether fasttrask added to the list of IPV6-FIREWALL?
3. i added and configured 6to4 interface through 192.88.99.1 but cant get good score on tests because MT blocks ICMPv6 to local bridge, i added some rules based on https://gist.github.com/tiernano/4344701
computer pinged good from MT and MT from Internet
4. MT cant ping ipv6 adresses with "invalid value" error, all clients can (look terminal @ screenshot above)
5. When i try SYSTEM-AUTO APGRADE while updating from RC18 to RC20 i got "there is now newer alpha/beta/rc version" but i know they exist :)
thx for help and any information!
bajodel
Long time Member
Long time Member
Fri May 15, 2015 12:33 pm
Problems on bridges interfaces, input traffic is not counted !!
Tested on platforms: CRS125-24G-1S and RB2011
RouterOS affected versions: 6.29rc14 6.29rc18 and 6.29rc20 (last one screenshot attached ..scroll down to view all)
Sob
Fri May 15, 2015 10:00 pm
3. i added and configured 6to4 interface through 192.88.99.1 but cant get good score on tests because MT blocks ICMPv6 to local bridge, ...
If you have 6to4 with 2002::/16 address derived from IPv4, unspecified remote address for 6to4 interface and 192.88.99.1 as default gateway, you're running into "my" 6to4 bug (broken since 6.20, in current state since 6.24). The problem is that default gateway specified as ::192.88.99.1%6to4 does not work at all. So you can only access 2002::/16 and that's it. And if someone tries to connect to you from production (non-2002::/16) range, packets get to your router, but replies don't get out.
Current workaround recommended by MikroTik support is to use two 6to4 interfaces:
/interface 6to4
add local-address=<your IPv4 address> mtu=1480 name=6to4
add local-address=<your IPv4 address> mtu=1480 name=6to4gw remote-address=192.88.99.1
/ipv6 address
add address=2002:<your IPv4 address>::1/16 advertise=no interface=6to4
/ipv6 route
add distance=1 gateway=6to4gw
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
dmi3
Re: RouterOS v6.28 released
Mon May 18, 2015 9:04 am
I did as suggested, and now http://www.ipv6-test.com/ tells me there is no ipv6 :)
some other services tell there is.. in fact clients got addresses, can go ipv6, can ping, download etc
but ping still didn't reach clients after MT
suppose its wright?:Image
Sob
Mon May 18, 2015 3:15 pm
Ok, that does not sound like improvement. I'd suggest to create new topic and post more details, config export, etc..
jondavy
Mon May 18, 2015 3:32 pm
the package all_packages-ppc-6.28.zip this damaged after installation and check
and also another bug:
he reappears the WebBox interface (which does not work) in RB1100AH
TomosRider
Tue May 19, 2015 11:31 am
One thing that happened yesterday, but i saw earlier posts about this....after power loss, Mtik lost all static DHCP leases....running ROS 6.27, will do update to .28.....any ideas why is this happening? No bad blocks....
TomosRider
Tue May 19, 2015 5:22 pm
After upgrade, same thing...also, cant create backup anymore. When i try to create backup file, i get message:critical error creating backup file:could not read all configuration files.
RB is 1200, running smoothly for months. Mtik staff, have any idea how to solve this problem?
rextended
Thu May 21, 2015 8:36 pm
Today are one month after I install 6.28 on all my production devices.
No one single problem on 5GHz ac or n, BGP, VRRP, EoIP, PPtP, PPPoE, user-manager, DHCP server, DNS server & big lists of static entry, firewall & big address-list, Routing, etc., etc., etc.
(I do not use VLAN, IPv6, MPLS or OSFP)
Thanks MikroTik, finally one stable MRRU+EoIP version of the RouterOS
jarda
Thu May 21, 2015 10:44 pm
... and the excessive flash writings?
rextended
Re:
Fri May 22, 2015 11:19 am
I do not have this problem, on production I do not have any mipsbe devices.
The only mipsbe devices are AP or PTP and no one of these have any firewall rule.
Cha0s
Forum Veteran
Forum Veteran
Fri May 22, 2015 2:21 pm
So just because -you- are not affected by the bug, does not mean that 6.28 was all colors and rainbows.
jarda
Fri May 22, 2015 2:42 pm
This is it. I decided to skip 6.28. Hope the 6.29 will be at least without major bugs. I know that there will not be corrections I am waiting for, so maybe I will wait till 6.30 before I start my own update tests. Keeping 6.27 in production so far.
rextended
Sat May 23, 2015 10:00 am
And this provocative phrase that means?
And where I have writed "6.28 is all colors and rainbows"?
If you do not like positive recensions, simply do not read, or comment, those.
If you have time and patience to ignore english errors, read that:
http://forum.mikrotik.com/viewtopic.php ... 00#p479732
I think that explain some bugs...
james
Sat May 23, 2015 11:23 am
Since upgrading my home box seems very unstable, lots of spontaneous reboots and enough bad connections that I have power cycled it a few times.
[admin@catbus_home] /system> /system routerboard print
routerboard: yes
model: 751G-2HnD
serial-number: 2F8701252CD1
current-firmware: 3.17
upgrade-firmware: 3.22
[admin@catbus_home] /system> /system resource print
uptime: 58m57s
version: 6.28
free-memory: 26.1MiB
total-memory: 64.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 250MHz
cpu-load: 4%
free-hdd-space: 21.4MiB
total-hdd-space: 64.0MiB
write-sect-since-reboot: 3132
write-sect-total: 12762707
bad-blocks: 0%
architecture-name: mipsbe
board-name: RB751G-2HnD
platform: MikroTik
From the log
may/18 23:14:53 system,error,critical System rebooted because of kernel failure
may/18 23:14:54 system,error,critical Out of memory condition was detected
may/18 23:14:54 system,error,critical router was rebooted without proper shutdown
Cha0s
Forum Veteran
Forum Veteran
Sat May 23, 2015 2:59 pm
It means that Mikrotik 6.28 (or any other 6.x version) is FAR from stable.
I may have been a bit offensive to you but that was not my intention. I just used your comment to point out that Mikrotik is far from stable in a sarcastic way (hence the colors and rainbows).
rextended
Sat May 23, 2015 3:09 pm
:D
rextended
Sat May 23, 2015 3:43 pm
routerboard: yes
model: 751G-2HnD
uptime: 58m57s
version: 6.28
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-load: 4%
bad-blocks: 0%
platform: MikroTik
From the log
1) Update the bios (/sys rou up)
reboot
2) Download winbox from the gateway ip of routerboard
3) Export the config (/export file=config)
4) Save the config from routerboard to your pc
5) Reset the config of your routerboard (/system reset-configuration keep-users=no no-defaults=yes)
reboot
6) Do this command: /romon port remove [find]
7) open config.rsc with notepad and paste block by block on new terminal inside winbox untill you done.
AlexVB
Mon May 25, 2015 8:11 am
After upgrade from 6.7 to 6.28 we now get spontaneous hangs every few days on CCR1036-12G-4S.
rextended
Mon May 25, 2015 8:32 pm
What method you use for install 6.7 (or the previous and what method use to go to 6.7)?
What method you use to upgrade to 6.28?
BIOS version of the router?
What package you have installed and what date and time have the packages?
AlexVB
Tue May 26, 2015 9:05 am
Upgrade from prevoius, preinstalled version
Upgrade package
routerboard: yes
model: CCR1036-12G-4S
serial-number: ...
current-firmware: 3.10
See attached image.
AlexVB
Tue May 26, 2015 9:06 am
I not mentioned that integrated watchdog does not detects the hangs, but If it is set to ping address then it detects hang but does not reboots router.
SCare
Tue May 26, 2015 1:06 pm
Problems with CAPsMAN with the hAP lite as APs, I've differents APs with the same configuration working together (mAP and RB751) and working ok with 6.28, hAP lite not working
strods
Thu May 28, 2015 11:22 am
bajodel - Unfortunately on bridge interface you can only see traffic where bridge itself is in/out interface. Bridged traffic will not be visible on this interface.
elurex
Thu Jun 25, 2015 5:52 am
can wireless bridge and virtual ap working on sxt SA5 ac?
hrehm
Mon Jul 06, 2015 7:19 pm
nmaton,
I do have EXACTLY the same issue with v6.28.
CCR1036 running a Hotspot, Etherrnet "crashes" after a few days, while ROS is still accessible on seial.
trying to disable Ether1 (the only connected port) brings:
[admin@Wifi-Master] /interface> disable ether1
(5,0) WARNING: waiting for reply message: timed out
(5,0) Now cycle 220085031284627, timeout 40000000000 cycles
(5,0) Caller 0xfffffffc00042c58 with ICS 0
(5,0) Message type 0x10f, dest 0x3
(5,0) chan 4: 271
(5,0) chan 5: 271
(5,0) chan 19: 271
(5,0) chan 20: 271
(5,0) chan 21: 271
(5,0) chan 35: 271
(5,0) chan 36: 271
(5,0) chan 37: 271
(5,0) chan 51: 271
(5,0) chan 52: 271
(5,0) chan 53: 271
(5,0) chan 67: 271
(5,0) chan 68: 271
(5,0) chan 69: 271
(5,0) chan 83: 271
(5,0) chan 84: 271
(5,0) chan 85: 271
(3,1) WARNING: waiting for reply message: timed out
(3,1) Now cycle 220371650555530, timeout 40000000000 cycles
(3,1) Caller 0xfffffffc00037860 with ICS 0
(3,1) Message type 0x405, dest 0x3
(4,4) WARNING: waiting for reply message: timed out
(4,4) Now cycle 220440770250348, timeout 40000000000 cycles
(4,4) Caller 0xfffffffc00037860 with ICS 0
(4,4) Message type 0x405, dest 0x3
CherryNOD
Thu Jul 30, 2015 8:38 am
Tools -> RoMON, then check ENABLE, finally click OK
Users browsing this forum: No registered users and 11 guests
