honzam
Mikrotik DynaDish 5
Wed Apr 29, 2015 4:24 pm
Discusion and info about new product DynaDish 5
Suggested price - $179
http://routerboard.com/RBDynaDishG-5HacD
LAN, FTTx, Wireless. ISP operator
HaQs
Re: Mikrotik DynaDish 5
Wed Apr 29, 2015 7:40 pm
It looks ok.
+1 for version with SFP and DC JACK
ronniee
Fri May 01, 2015 8:27 am
We are waiting for it, when will be available?
Good move, the 802.3af/at POE, but the power supply is only for home users.
For a serious stabile link, I would use a 48V 1,6A power supply, no?
n21roadie
Sat May 02, 2015 12:04 am
Interesting but expensive, should be higher gain as 23dBi is too low for suggested price, higher gain is what I am looking for as there is very dish antennas on the market with around 27dBi gain, loads at 30dBi and higher.
N21roadie,
Network 100% MT for Now?
rado3105
Mon May 04, 2015 5:49 pm
There is only client version? no AP?
pukkita
Trainer
Trainer
Mon May 04, 2015 6:03 pm
License = L3, it can be used as CPE (client) or PTP (one end as CPE, the other in bridge mode, same as AP mode with just 1 client)
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
Diabolix
Mon Jun 01, 2015 9:46 pm
Where is the DynaDish?
Has it been delayed? My supplier said the date has been pushed back to due manufacturing issues... ;(
Mikrotik can you confirm?
Diabolix
Tue Jun 09, 2015 10:17 am
Nothing?
1 month? 2 months?
Łukasz
Thu Jun 11, 2015 1:01 pm
From routerboard.com
PoE in Passive PoE or 802.3at (only unshielded cable)
Unshielded cable with outdoor device?
Mikrotik, why?
normis
Thu Jun 11, 2015 1:03 pm
Mikrotik, why?
It was either this, or remove it from specifications altogether. This way, at least maybe somebody benefits from such option.
Petzl
Thu Jun 11, 2015 9:23 pm
Something wrong with the design ?
some people like to know why it is not possible with shielding.
If we don't use shielding al our links would-be running @ 10 mbit half duplex
pukkita
Trainer
Trainer
Fri Jun 12, 2015 12:15 am
Do you mean unshielded cable required only for 802.3at POE?
There's no such restriction when using passive POE?
normis
Fri Jun 12, 2015 10:12 am
Yes, of course.
It works fine with Shielded cable if you don't need 802.3af
Petzl
Fri Jun 12, 2015 2:15 pm
can you tell what is wrong in the design ?
it must be something between power lines and ground
can we use 48V passive POE ?
normis
Fri Jun 12, 2015 2:16 pm
Like I already said, you can use passive PoE with any cable, and 802.3af with unshielded cable. Provided Voltage range is correct for any PoE
rado3105
Mon Jun 15, 2015 12:45 am
what is the weight?
is it 23 od 25dBi?
what has better antenna for ptp links? qrt5ac or dynadish ac?
HaQs
Mon Jun 15, 2015 8:32 pm
normis, when you expect a cheap QRT5 AC with license level 3 :)?
Why this product is so expensive? in comparison with other
normis
Tue Jun 16, 2015 9:54 am
QRT is a very high quality 802.11ac device with a good antenna and a professional mount. It is not low end home product.
Łukasz
Tue Jun 16, 2015 1:08 pm
What happen when we connect shielded cable using 802.3af poe?
QRT is almost three times more expensive than SXT Lite5. If QRT is "very high quality" please made something like QRT Lite5 for distant clients.
normis
Tue Jun 16, 2015 1:10 pm
SXT and QRT should not be compared, the SXT is also much smaller and has much smaller antenna gain. What are you saying exactly?
There is a product for every distance/price category. Choose according to your needs.
normis
Tue Jun 16, 2015 1:11 pm
DynaDish will not power on.
Łukasz
Tue Jun 16, 2015 1:34 pm
No, there is not. Normis look at ubiquiti products. They have "product for every distance/price category". We need something like nanobeam NanoBeam M5-300 and M5-400 in the same prices. You don't have products with 22dBi and 25dBi gain in these price.
This is not just my opinion. Many times forum users please you about products like these.
normis
Tue Jun 16, 2015 1:47 pm
SXT Lite5, 16dBi , 59$
SXT 5, 16dBi higher output, 89$
SXT HG5 17dBi, 95$
SEXTANT G 5HPnD, 18dBi, 119$
and more products will be announced this year, new categories coming!
Łukasz
Tue Jun 16, 2015 3:37 pm
Thank you for answer, Normis. You give me hope :)
honzam
Mon Jun 29, 2015 11:22 am
When we can expect first pieces?
Inside photo from fcc
InoX
Mon Jun 29, 2015 1:46 pm
Very nice reset button :lol:
soulflyhigh
Tue Jun 30, 2015 1:18 pm
Would be better with L4 license.
Using it as a CPE for "home users" is just overkill.
The same goes for QRT-5 and QRT-5 ac (which both have L4 license and we are
using QRT-5 as APs for medium range p2mp connections).
Mikrotik, please make cheap 5GHz high gain CPE unit, SEXTANT is neither cheap (for what it is)
nor a high gain device (just 2dBi higher than SXT Lite5).
We need 22-25dBi CPE under $100 price (even single pol device 1x1 would be excellent for the right price).
MTCRE, MTCTCE, MTCSE
DiabolixZA
Wed Jul 08, 2015 11:58 am
Normis, any news on the DynaDishes?
Distributors here in South Africa say they are waiting on ETA's from Mikrotik?
wojtekc
Mon Jul 13, 2015 10:34 pm
Almost all ISPs from Poland waiting for CPE with 22-25 dBi antennas from Mikrotik :)
normis
Tue Jul 14, 2015 9:00 am
more dBi means bigger antenna
wojtekc
Tue Jul 14, 2015 2:38 pm
300-400mm, no problem.
Łukasz
Wed Jul 15, 2015 2:37 pm
Yes 300-400mm is no problem.
normis
Wed Jul 15, 2015 2:49 pm
DynaDish is for you then. 400mm diameter, 25dBi gain.
soulflyhigh
Thu Jul 16, 2015 6:34 am
Dear Normis,
for a less than 1/2 of DynaDish's price we are assembling Mikrotik
based 23dBi 1x1 5GHz CPE unit (with third-party single-pol antenna).
I'm sure you could do it better in the same price range and still make a decent profit.
normis
Thu Jul 16, 2015 9:27 am
Dear Normis,
Your assembly workers do it for free?
soulflyhigh
Thu Jul 16, 2015 2:28 pm
Dear Normis,
No they don't work for free, we're paying our workforce :) .
But we do need just about 100pcs a month so it's not too much to handle - it takes about
10 minutes per 1 CPE and our crews are completing them just before installation at costumer site.
It is for our home-users who are too far away for regular SXTs.
So, we're not reselling those CPEs on open market.
We are in WISP business, mass-manufacturing CPEs (or anything else) isn't something we want to do but
there is nothing like Airgrid with 22-27dBi antenna in your current product line (in "below 100$" price category).
Economic situation is far from great today (especially in my country) and we're simply trying to
minimize costs for us and our less-demanding costumers.
For higher demanding (and paying) services QRT and Dynadish are just fine.
That's all.
Regards,
M.
HaQs
Thu Jul 16, 2015 4:08 pm
+1 for cheap CPE 22-23 dbi version
SXT is super , cheap for 500-700 metres max
SEXTANT hmm - This product is no longer necessary
we need cheap QRT :) L3 licence, 100mbit port is enough, but need 23dbi antena with cheap price 110-120USD
or smaller dynadish (22-23 dbi fi 33cm) 100mbit port L3 licence , and this low price
Total QRT better than DynaDish with standard RB in the middle.
Only do handle suggested simpler and less expensive for QRT such as dynadish
normis
Thu Jul 16, 2015 4:19 pm
We have some really exciting stuff for you, coming soon ;) Just follow the news and MUM events.
HaQs
Thu Jul 16, 2015 9:34 pm
Thanks. Normis. I am waiting :)
TikUser
Mon Jul 20, 2015 1:29 pm
Where are the DynaDish 5 antenna patterns (vertical / horizontal polarization return loss, vertical / horizontal polarization gain)? At which frequencies DynaDish works the best?
rado3105
Thu Aug 06, 2015 1:38 am
https://www.ubnt.com/airmax/litebeam-m5/
you could make something like this. Great price - 50 Eur, great power.very lightweight..but if it was MIMO it would be killer product...so Mikrotik make that killer product....
ste
Thu Aug 06, 2015 7:32 am
What I don't like with QRT are the sealed screws. I want to upgrade QRT 5 with an .ac board.
Why not ??
spacemind
Sun Aug 23, 2015 10:31 pm
Dynadish 5 ac, Qrt 5 ac wich one to choose for a 6km ptp link, just one dbi difference.
Dynadish 8º QRT5 10.5º both dual pol and same cpu and wifi chip.
normis
Mon Aug 24, 2015 12:37 pm
The QRT and DynaDish are quite similar.
Same CPU, same ports.
The differences:
- Dynadish has 1 dBi more
- Dynadish is cheaper
- QRT is more compact and flat design
- QRT has L4 license for multipoint support
larocca
Tue Aug 25, 2015 1:17 pm
Good morning,
We bought 2 DynaDish 5 and on the Lan connector that it work from 24V to 48V. On the Product specifications website are Supported input voltage 11 V - 60 V.
Can you tell us what's the correct information?
Best regards
phendry
Wed Sep 09, 2015 3:50 am
Hey Normis. You do know that both the routerboard website (http://routerboard.com/RBDynaDishG-5HacD) and many resellers say these are 23dBi gain antennas don't you?
normis
Wed Sep 09, 2015 10:12 am
Website and Brochure say 25dBi. Also, our antenna engineers say so, I just asked :)
This means distributor made a mistake.
phendry
Wed Sep 09, 2015 10:34 am
Strange, I click on the above link and see it says "Antenna gain DBI 23" halfway down the page ;)
normis
Wed Sep 09, 2015 10:36 am
so that's where the confusion came from :) fixed. the description above and the PDF were right though. thanks!
phendry
Wed Sep 09, 2015 10:39 am
No worries. Looks like some resellers may have just copied and pasted.
spacemind
Wed Sep 09, 2015 5:07 pm
Did anyone already tested dynadish against QRT, i need it for 4 km ptp link with maximum speed of 200 mbits full duplex.
I think Dynadish has more wind resistance, but in performance ....
phendry
Thu Sep 10, 2015 12:22 am
400Mbps aggregate over 4km?
spacemind
Thu Sep 10, 2015 1:02 pm
Sorry, 200 half duplex with AC.
I already have 90 with 2 qrt5.
mysz0n
Tue Oct 20, 2015 3:51 pm
I'm waiting for sth like AirFiber 24Ghz from Mikrotik!
Can you tell me whats the Frequency Range for DynaDish?
spacemind
Fri Oct 23, 2015 1:03 am
Dynadish 5 means Dynadish 5ghz frequency.
mysz0n
Fri Oct 23, 2015 1:19 am
ohhh come on...
what i ment was the most optimal frequency for this antenna
e.g:
qrt5 - 4.9-5.875 GHz
sextant g - 5.17 - 5.825 GHz
sxt 4920-5920MHz
Do you see the difference?
spacemind
Fri Oct 23, 2015 2:47 pm
ohhh come on...
e.g:
sxt 4920-5920MHz
I don´t see the difference as i can only use from 5400mhz to 5800 mhz outdoor with 30db max.
normis
Fri Oct 23, 2015 3:03 pm
DynaDish 5 works best at 5.17-5.825 GHz with the center being slightly better
fasahat
Sat Oct 24, 2015 10:08 am
what is transmission power of Dynadish 5
wojtekc
Mon Oct 26, 2015 8:17 pm
Do you know something about cheap QRT5 L3?
We waiting for Mikrotik devices with antenna 20-23 dBi (e.g. Ubiquiti PBE)!!!
normis
Tue Oct 27, 2015 10:06 am
Yes, some really cool looking low cost CPE devices are coming soon
Łukasz
Tue Oct 27, 2015 10:15 am
This year?
Normis, please write something more.
normis
Tue Oct 27, 2015 10:18 am
This year?
very low cost, very good gain, light and nice design. had it in my hands just yesterday :D
I am not sure about the date at the moment.
Łukasz
Tue Oct 27, 2015 10:30 am
I also want to have it in my hands :D
Thank you for answer and good information.
wojtekc
Tue Oct 27, 2015 4:21 pm
normis,
Thanks for your reply.
SBBvince
Fri Oct 30, 2015 3:24 am
I have one 6.81km (4.23mi) link going right now. I have had it up for a month or two. I would say that it performs about as well as the rest of our MT BHs. We generally use ARC dual polarity panels in an ARC integrated enclosure with RB922s.
I do like the mount for the DynaDish. The capability to aim the dish but keeping it from slipping down the mount is a plus.
The one issue I am having with it right now is similar to the issues I have with the RB922s, they have a tendency to lock up for no reason at all. While the RB922 is a huge improvement over the RB711s, I don't have this issue with the RB711s.
Other than that, I can see using these more often as the cost to build an ARC IE with a panel and board is much more significant. While they have been really reliable for us, having an all-in-one unit is nice.
PaulsMT
Fri Oct 30, 2015 8:51 am
Can you please specify in more detail about this issue, which RouterOS verision are you using, how the board locks, are you unable to connect the board trough wifi and ether ?
SBBvince
Fri Oct 30, 2015 9:02 am
The board stops responding to pings. On the DynaDish, it will stop passing traffic and be non-resposive to anything other than mac-telnet (because I can always access it via mac-telnet, I have not tried). On some of the RB922s, the board will be come unresponsive to pings, no winbox access, but will still pass traffic.
The DynaDish is currently running 3 We experienced this issue starting around 6.26 if I not mistaken.
PaulsMT
Fri Oct 30, 2015 9:14 am
It would be very useful if you could repeat this issue on the latest RouterOS, generate the supout file:
http://wiki.mikrotik.com/wiki/Manual:Su ... utput_File
And send it to support:
http://www.mikrotik.com/support.html
SBBvince
Fri Oct 30, 2015 3:42 pm
I apologize, both sides of the link are running 6.32.3. I had a snafu while typing on my mobile last night. They are also running the most current firmware (3.24).
I will try to get the supout information sent in today.
tealc
Thu Jan 28, 2016 5:40 pm
I can confirm ethernet problem. ROS 6.33.1. Ethernet not accessable by any service, only visible in neighbors. No access on MAC telnet also. Wireless interface keeps connection. Hard reboot (power cut) returns normal function.
Poslano sa mog Mi-4c koristeći Tapatalk
SBBvince
Fri Jan 29, 2016 1:03 am
If the wireless interface keeps connection, you should be able to login from either from the router on the far end or the device on the near end. I am going to assume your ether and wlan are bridged and an address is assigned to the bridge. If so, a MAC telnet will not work from the registration table. You need to go to IP > Neighbors and mac-telnet from there. It will work, as this hasn't only happened on the DynaDish5, but also RB922s we use across our network.
pukkita
Trainer
Trainer
Fri Jan 29, 2016 11:54 am
Even better, enable Tools > RoMON and you'll be able to access, as long as both units are connected.
I would however netinstall and reset to no defaults the units using latest 6.33.5 ,then reload the configuration exports and test.
wojtekc
Fri Jan 29, 2016 4:46 pm
This year?
Any news about this?
gmeden
Fri Jan 29, 2016 7:14 pm
I would like to know the total EIRP possible . Sure , it has a 25 dBi antenna , but what is the radio power output? Logging into unit and looking at TX power I see 17dB as default. Is that the maximum?
pukkita
Trainer
Trainer
Sun Jan 31, 2016 3:35 pm
Maximum Power Levels depend on modulation rates (MCS) according to http://routerboard.com/RBDynaDishG-5HacD
So maximum is 31dBm, before applying local regulatory restrictions and taking into account antenna gain; PIRE at this MCS would be 54dBm which I doubt is allowed on any country; also if your PTP will only work with these settings, your design and equipment pick is simply not right.
Stop looking at power as the sole criteria to get PTP equipment. Higher power levels also introduce higher distortion and reduces SNR.
pukkita
Trainer
Trainer
Sun Jan 31, 2016 3:37 pm
This year?
Some teasing please Normis! Will it be possible to see it at Slovenia MUM? :D
Marc85
Mon Apr 11, 2016 5:49 am
Is there a way to do the 5 sec reset without going up a tower to push the button? I have installed one of these already at 150' and it would not communicate with the mac address software or via IP. The other one had the same issue which I was able to resolve on the ground by performing a 5 sec reset with the button.
pukkita
Trainer
Trainer
Tue Apr 12, 2016 12:04 am
@Marc85: Is it completely unresponsive? Is it linked by wireless to any other equipment?
Marc85
Fri Apr 15, 2016 9:34 am
It's completely unresponsive via mac or IP, the first unit was installed before we realized there was a problem. I am actually the climber who installed it, I took the other dish home with me as an offer of good will to the customer to figure out if I could get it working. And I able to only by performing a 5sec reset, we attempted this onsite but the directions were misread while I was on the tower. After the 5sec reset it showed the default IP of XX....88.1 Is there a way to do this via some ethernet short without climbing up 200'?
pukkita
Trainer
Trainer
Fri Apr 15, 2016 11:49 am
Not that I am aware of... that would certainly be a welcome feature, implementing a "remote reset" signalling it from the ether poe wires.
jarda
Fri Apr 15, 2016 4:37 pm
Ros is able to detect cable length and pair status of pins with many of devices. It should not be so complicated to have a feature in routerboot to check it during the boot process or in ros to check it once per some interval during normal run or so.
TomjNorthIdaho
Re: Mikrotik DynaDish 5 - verses 922UAGS-5HPacD with external dish
Wed May 04, 2016 9:30 pm
Mikrotik DynaDish 5 - verses 922UAGS-5HPacD with external metal dish
FYI
I had a 12 km link using a DynaDish for both sides of the link. One DynaDish was located about 80 feet up a tower in a high RF noise environment (radio stations & radar & other APs). I experienced the following problems:
A) The POE Ethernet would almost never link at 1-gig. If it did, it would normally fall back to 100 meg full duplex in a few hours or so.
B) I could not get a good link connection rate and decent CCQ (bandwidth test could barely do 100 meg)
C) Lots of back-side noise getting into a DynaDish from other stuff (radio stations & radar & other APs) located behind the rear side of the DynaDish.
D) Lots of noise on the Ethernet
E) No second Ethernet port available.
We replaced both sides of the microwave link with a set of Mikrotik 922UAGS-5HPacD with external dishes. Wow - what a difference !!! Now things are much much much better :)
We now have the following:
A) Ethernet1 POE and SFP1 (with Ethernet SFP) both link at 1-gig
B) We have a link speeds of 650 & 702 with a CCQ in the 90s. I am now able to bandwidth test at 400 meg either way and can hold a solid 200 meg full-duplex (200 up and 200 down at the same time). And one side is not fully aimed correctly yet.
C) The back-side noise is now low and no longer creating link problem.
D) Noise on both Ethernet cables is now gone
E) Ability to use two Ethernet cables with both linked at 1-gig (now I can use spanning-tree on the Ethernet links)
So - in summary, I would suggest using a 922UAGS-5HPacD with external metal dish instead of a DynaDish with the integrated plastic dish.
I suspect the plastic DynaDish lets all kinds of noise leak in from the back-side and also that the front-side plastic reflector is not as good as a metal reflector would be.
So - anyways - now that I have two DynaDish Mikrotiks no longer in use, I am considering spray painting the front-side reflector and the entire back-side of the DynaDish with some kind of a metallic or chrome spray paint -or- getting them plated with a metallic shield. I suspect that metal plating would help reduce back-side noise leakage and also increase the front-side db antenna gain. Has anybody ever tried something like this ?
North Idaho Tom Jones
saintofinternet
Forum Veteran
Forum Veteran
Fri Aug 12, 2016 10:03 am
did you find any solution to reset the board without climbing the tower??
by professionals, for professionals....
Don't forget to give KARMA!!!
modsx
Tue Dec 20, 2016 1:19 am
If the moderator will allow, then:
>> large pic
>> large pic
nz_monkey
Tue Dec 20, 2016 3:34 am
That is quite an innovative design.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet NSE7 | Extreme Networks ENA
Users browsing this forum: No registered users and 20 guests
