MUM Europe 2020
crhylove
VAP dhcp issue.
Wed May 06, 2015 9:30 pm
I'm trying to set up a Virtual AP that is not at all related to the local network. Something very much akin to a guest network.
I have it all set up, but any device on the Virtual AP only gets limited connectivity.
If I put the VAP on the bridge with my wan port (ether1), then they work, but other devices on the network start pulling dhcp from the VAP pool, which breaks connectivity in 100 different ways around my network.
What am I missing? Do I have to add the VAP to the bridge and then just somehow filter out the dhcp traffic to eth1? Would that affect my other AP which I DO want to pull dhcp from upstream?
Thanks in advance!
rhY
chechito
Re: VAP dhcp issue.
Fri May 08, 2015 12:28 am
i do that setup using a separate bridge por each vap
example:
bridge1 ports
wlan1
vlan10
bridge 2 ports
wlan2 (vap)
vlan20
bridge 3 ports
wlan3 (vap)
vlan 30
vlan interface using the same Ethernet, works as a trunk (multiple vlan) tho the LAN where vlans are mapped and have their dhcp server for each vlan serving all AP, and good for L2 roaming
if its only 1 ap you can set a ip address to VAP and set dhcp server directly on AP, does not work well for roaming
crhylove
Re: VAP dhcp issue.
Tue May 12, 2015 7:06 pm
I ended up getting it working without the vLans. I had to leave the srcnat masquerade rule pointed at the bridge, then suddenly everything was working.
If somebody else runs into this, I'd be happy to post screenshots of my config.
Rhy
009hnoor
Re: VAP dhcp issue.
Wed May 13, 2015 2:24 pm
Play solitaire Online on App Store Visit salitare For more Details.
Users browsing this forum: No registered users and 34 guests
