rwrocket
How can I log failures importing configuration
Fri May 08, 2015 5:06 am
Title says it all.
I am frustrated with my backup restore script not working so I need to see where it fails in the import process.
I need to log errors to a file because when I import the configuration file I get disconnected from winbox so I never see the output in the terminal.
PaulsMT
Re: How can I log failures importing configuration
Fri May 08, 2015 2:01 pm
Do you have backup file, or .rsc file ?
rwrocket
Tue May 12, 2015 6:03 am
I can send it to you but don't really want to attach it here for obvious reasons.
But I don't see why that really matters because I just want to know how to log errors when importing a config file
PaulsMT
Tue May 12, 2015 9:47 am
If you are using rsc (export file) you can paste the file content in your terminal, and you will see if there are any errors.
rwrocket
Tue May 12, 2015 10:20 am
If I do that all that happens is I am disconnected from winbox
And when I reconnect doesn't appear like any of the config has been written.
Can I send you my config ? I will try PM you.
Seems to me like the memory is filling up or something, it is quite a large config
pukkita
Trainer
Trainer
Tue May 12, 2015 12:17 pm
Connect to router MAC via WinBox (i.e. layer2), upload the file to the RB, then go to terminal and issue
/import verbose=yes file-name=YourExport.rsc
That way you should see where the error is.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
rwrocket
Wed May 13, 2015 2:22 am
Thanks Pukkita, making progress
Found a couple of errors in my config and fixed them but now I got to the point where it just drops the Winbox connection and I cannot get back in. (my config has no config changes to the port I am using to connect to the router and winbox is allowed on all interfaces)
Have not tried rebooting the router yet.
I might try to import my config verbosely from serial console and see what happens.
skot
Long time Member
Long time Member
Wed May 13, 2015 2:33 am
What I would do is look through the config and try to find the setting that is kicking you out. Then, just comment the line(s) out with pound signs #, and copy/paste the whole script into the terminal. It's probably an /interface related setting...
I don't need any karma... I have Ιησους Χριστος!
chechito
Wed May 13, 2015 2:46 am
when you paste the commands on terminal, look at the last command you can see pasted, that command or the following command its the source of your disconnection.
Or try pasting the config by pieces to find which contain the problematic command
rwrocket
Wed May 13, 2015 3:17 am
Ok so I think I found what is causing the disconnect
set [ find default-name=ether12 ] l2mtu=1590
From what I can see, the ROS defaults for 6.28 on a CCR1036-12G-4S are 12mtu=1580
it must have previously been 1590 because I certainly did not change this but it is in my config file
Also this causes the script to stop asking for interface
/romon port
add disabled=no
Assume this may be a bug caused by the newly added ROMON. (I have ROMON disabled under tools)
Users browsing this forum: No registered users and 29 guests
