KBoris
hAP lite - "die" after I run script
Thu May 14, 2015 9:38 pm
I unbox my new hAP lite and I upload configuration.rsc file. I start command in terminal window /system reset no-defaults=yes run-after-reset=configuration.rsc. Router reboot and after that access is not possible any more (Winbox does not see router MAC or IP address). If I tray to reset .... nothing happened.....
I try same procedure on next router and I find, if I made firmware upgrade first everything works fine. Router is reachable after I run script . Unfortunately before I find solution I destroy 3 routers. Can I fix them somehow ?
I made a lot of research but can not find proper solution....
Any advice ?
KBoris
Re: hAP lite - "die" after I run script
Fri May 15, 2015 5:36 pm
.......nobody ????? Procedure how to load default setings ???
uldis
Fri May 15, 2015 5:56 pm
please reinstall the hAP lite with the new RouterOS using Netinstall.
Press and hold the reset button and power on the board, keep holding the reset button for approx 10-15 seconds till it goes into the network boot.
Then use Netinstall tool to reinstall it.
http://wiki.mikrotik.com/wiki/Manual:Netinstall
Users browsing this forum: anserk, gfunkdave, mrshaba, neopike and 79 guests
